Originally Posted by FNFastZ06
(Post 1581277915)
:iagree:
Love mine too. I also found doing the Anti-Venom mod (adding washers to the detent spring at the tranny) helped with the added notchy feel and really smoothed out the action. |
I replaced a C6-Z06 shifter, with a B&M, in my car yesterday and so far I love it...:yesnod: The throw is amazingly shorter. It definitely takes some getting used to. It does take more effort, and I've done the anti-venom (1 washer) mod. I can't imagine this shifter without the mod.
But the shifts are much more precise, and did I say the quick...:thumbs: Anybody interested in a shortened '07 Z06 shifter??? :D :cheers: |
Originally Posted by roscoe118
(Post 1581329016)
can someone explain the Anti-Venom mod? How it works and what it does? Is there any way that this over time will harm the transmission?
Originally Posted by tteich01
(Post 1581332919)
transmission? Do a search on this forum. There's a great write up. I can't look for it now, but if I get time later I'll post the link. It takes about 10 minutes once you get the rear of the car in the air. Basically, you remove the detent from your trans (backs right out with a ratchet and socket, toughest part is finding the detent - it's easy to access and get out once you find it), and add one or two copper washers. This decreases the amount of detent on the detent bolt and makes shifting easier. I started with one and went to two. Check it out, it's a really cheap mod! :cheers: Zuti Here you go: http://forums.corvetteforum.com/c5-t...ever-need.html |
Originally Posted by tuscanycircle
(Post 1581325556)
The one I have, pictured above, is called "Precision Sport Shifter". I've seen pictures of another, without the vibration-isolating design and with a single straight-through shaft. I think that's the Ripper.
This is a trait inherent in the transmission, having nothing to do with the shifter. Even the owner's manual references it. The most effective recovery is to double-clutch (while in neutral, release and re-depress the clutch, then try again to engage first gear). It's just how the synchros and dog teeth are structured in the transmission, I believe. This is the link I just used to do mine and found it to be awesome: http://www.toquez06.com/avm.html (Thanks, Mark!) I had some minor difficulty finding the right washer/gasket, but eventually found the Dorman 095-023 matches the Oil-Tite 65277 pictured on Mark's page. I don't remember seeing the 1st gear issue in the owners manual, I'll look again. I find that if I go into second gear it pops right into first. That and going into first before coming to a dead stop also helps. It clearly seems to be a synchronizer issue to me. |
Originally Posted by nvusgt
(Post 1581329088)
Does it come with the shifter box?
Originally Posted by Coach62
(Post 1581333627)
You can shift into FIRST (1) when you’re going less than 40 mph (64 km/h). If you’ve come to a complete stop and it’s hard to shift into FIRST (1), put the shift lever in NEUTRAL and let up on the clutch. Press the clutch pedal back down. Then shift into FIRST (1). I too find that going into second usually works, but sometimes this isn't sufficient and the double-clutch (to get the synchro spinning again, I think) is needed. Because of this, I've been favoring the double-clutch action instead of relying upon second, but it takes some practice to be as fast as using second. |
(Post 1581329016)
But the shifts are much more precise, and did I say the quick...:thumbs: Anybody interested in a shortened '07 Z06 shifter??? :D :cheers: :cheers: |
Give our new shifter a try... the TPS Attack. I'm sure your like it alot. We're running a promotion on it for $129.99 shipped to your door right now and it comes with a straight or angled handle :)
http://www.tpsmotorsports.com/media/...shifter2_1.jpg http://www.tpsmotorsports.com/media/...sshifter_4.jpg http://www.tpsmotorsports.com/media/...ifter3_1_2.jpg |
Originally Posted by Cardinal Flyer
(Post 1581341571)
I'm hoping to make the same swap this weekend. But I want to use 2 washers on the anti-venom mod based on the posts above, and so far I've only been able to get one from NAPA---the only one my store had. Apparently their inventory control leaves a lot to be desired; they've ordered one in from other stores that showed inventory, and twice the other stores have been out of stock too! Must be a lot of anti-venom mods being done out there :D
:cheers: Shifter's been in for 2 weeks now, and thanks to Tuscany I've got plenty of washers. Based on how it feels without the anti-venom mod (Really, Really Good!), I've decided to try only 1 washer--and I'm in no rush to find a hoist. I'm actually glad now that I wasn't able to lift the car and do the mod at the same time as I installed the shifter! As someone else said, the "feel" of a shifter is really a personal thing. :cheers: |
(Post 1581466404)
I ran with my shorter shifter but without any antivenom mod for several months and didn't mind at all. Adding the washer certainly helped some, but it's not nearly significant enough to be a make-it-or-break-it kind of factor in choosing a shorter shifter. Is this similar to others' experiences? |
