Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-09-2012, 11:18 PM   #1
tteich01
Junior Member
Ty_teich
Default C5 B & M Shifter Review
Does anyone run a B&M Shifter in their C5? How do you like it? How much of a shorter throw is it? Any other info is great!
tteich01 is offline   Reply With Quote
Old 07-09-2012, 11:56 PM   #2
BOUT X
Corvette Cowboy
Support Corvetteforum!
BOUT X's Avatar
Check out the TPS ATTACK shifter I think you might like it forum vendor here
Pops
BOUT X is offline   Reply With Quote
Old 07-10-2012, 08:53 AM   #3
Tuscany
nobody
Tuscany's Avatar
I have a B&M in my '02 Z06 and really like it. I haven't measured it, but the overall throw seems to have been reduced from stock by about 35-40%. The B&M adds no superfluous feels, notches, springs, or otherwise, which I find nice. More force is required to shift, of course, since some leverage is lost in the shorter height, but it's far from uncomfortable. Stop-and-go traffic may give you more of a workout, though. There are no rattles or inappropriate vibrations or noises. Their new (?) shifter design provides a little buffer between the physical linkage and the stick via rubber o-rings. This seems to dampen vibrations without inhibiting any feel of the transmission. The gear positions are closer together, of course, so if you have any concerns about getting your desired gear with the stock shifter, a shorter one will exacerbate the problem a bit. I haven't had any issues, but it did take a few minutes to get used to it. The stick has a slight cant rearward but this can be reversed (cant forward), if desired--I suppose the length of one's arm would determine this. It shouldn't take an hour to install and presents no hiccups.
Click the image to open in full size.
I did not retain the stock **** but replaced it with an MGW "race" **** (somewhat vertically cylindrical) and screwed it down low to keep the shifter short. I prefer this to a spherical ****, but it's slightly less comfortable in an over-the-**** grip, if that's what you prefer. I find it more comfortable in any style grip, though, than the stock ****.
Under heavy acceleration, my shift speeds are now limited only by my left leg speed, since the shifter throw is now short enough that I can comfortably shift without pausing clutch travel at all. Again, I haven't measured it, but my feel is that I shaved about a quarter second off my shift times.
I've been very pleased with my B&M and recommend it without reservation.
Tuscany is offline   Reply With Quote
Old 07-10-2012, 09:11 AM   #4
FNFastZ06
CF Senior Member
FNFastZ06's Avatar
Love mine too. I also found doing the Anti-Venom mod (adding washers to the detent spring at the tranny) helped with the added notchy feel and really smoothed out the action.
__________________
'03 Z06 - Black
Comp Cams 281/283 .595"/.598" 112 deg. XFI/XER Cam
LG Longtube Headers with high-flow cats
Vararam cold air
B&M Ripper shifter
LG GT2 Coilovers
Drilled + Slotted rotors, Hawk HP+ brake pads
BFG GForce KDW2s
FNFastZ06 is offline   Reply With Quote
Old 07-10-2012, 09:16 AM   #5
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Nice review Tuscanycircle. I'm sure that will help someone considering the purchase of that shifter.
Vetteman Jack is offline   Reply With Quote
Old 07-10-2012, 11:09 AM   #6
v03z06
CF Senior Member
v03z06's Avatar
Personally, I hate mine. When I first installe it I didn't mind the notchiness of it because I didnt drive it much. But the shifter doesn't feel very "fluid" rowing through the gears and is extremely aggressive
v03z06 is offline   Reply With Quote
Old 07-10-2012, 11:32 AM   #7
havocdog
Junior Member
havocdog's Avatar
I'm loving mine. My inpression is about 20% shorter throw and a much more connected feel using the solid mount bushings to replace the stock rubber coupe ones. I also did the Anti-Venom mod a week after the shifter install and was suprised at how much it smoothed out the shift action.
havocdog is offline   Reply With Quote
Old 07-10-2012, 12:22 PM   #8
Tuscany
nobody
Tuscany's Avatar
Quote:
I'm gonna give this a try. Just as you say, I think this would complement a short-throw shifter very well. Thanks! And thanks for your how-to page!
Old 07-11-2012, 02:42 AM   #9
BOUT X
Corvette Cowboy
BOUT X's Avatar
I have to ask what is it that you coinsider shorter throw the distance the shifter moves at the top or the amount it moves at the bottom. This has been a question I have had since I have read about short throw shifters.
Pops
Old 07-11-2012, 03:52 AM   #10
steven31371
CF Senior Member
I'd go with the MGW Short Throw Shifter
It is without question the most precise and best designed shifter on the market, and has about a 35% reduction in throw over the stock shifter.
The benefits of that shifter go beyond its shorter throw, the thing is so precise and well made that everything else about my car feels like it needs an upgrade now to keep up lol
It takes a couple days getting use to it, but once you do its amazing
plus, most of the hard core road and autocross racers with the most experience almost all have the MGW.
If your going to switch out the shifter, why pit something second best in when there isn't all that big of a price differance?
I pretty confident saying that no other shifter is in it's league....
steven31371 is offline   Reply With Quote
Old 07-11-2012, 08:03 AM   #11
Tuscany
nobody
Tuscany's Avatar
Quote:
I'm not sure if you're addressing the OP or the general audience, but I'll take a crack at answering.
The throw is measured at the top, specifically where you grip the stick. It's the distance your hand travels when shifting. Here's a good illustration.
Old 07-11-2012, 08:36 AM   #12
DarkBlueC5
CF Senior Member
DarkBlueC5's Avatar
To the OP, I don't have any info on the B&M, but my research all led to me getting the MGW unit. It is awesome. To get a really good idea of the change in height and throw you get with the MGW check out the post I made this spring after my install...http://forums.corvetteforum.com/c5-g...ifference.html
DarkBlueC5 is offline   Reply With Quote
Old 07-11-2012, 09:52 PM   #13
BOUT X
Corvette Cowboy
BOUT X's Avatar
It was for anyone and thank you for your answer and here is why I asked it. I am a Machnist and a Mechanical Engineer of 35 yrs. So what I did is draw this up in Solidworks to try and define and Develop a real to me short throw shifter. While doing this I relized the only way to do this is to Change the fulcrum of the Shifter ie. change where the Shifter pivots. I then relized that by cutting the top of shifter handle all it changes is the travel of the top of the shifter. It didn't make it a true short throw I also was in the middle of changing out my Clutch so I was able to take my tranny a part and look at the shift gate plate in it. I also reliezed that the Anti Venom Mod is a Valid Mod as by adding the shims in the Bolt detent moved it away from the Linkage allowing it to move freely and become less Notchy. So what I have done is made a adjustment in the height of my Shifter and my mounting block to achive a true short throw Based on the Gate plate GM put in our cars Transmission. I also made modifications to my shift lower box to handle the changes made at this time the upper handle moves about a inch from first to second. I also think that with the anti venom mod reduces the shifter ability to align between 3-4 gear not sure just a small theory will need more testing to figure it out.
Pops
Old 07-15-2012, 12:43 PM   #14
Tuscany
nobody
Tuscany's Avatar
I just did the antivenom mod with two washers/gaskets, and I love it! It really takes the edge off the notchiness that tends to be exaggerated by the shorter-than-stock B&M shifter. Much less effort is needed for shifting now, eliminating the only down side to a shorter shifter. Thanks, all!
Old 07-15-2012, 02:13 PM   #15
knewblewkorvette
CF Senior Member
knewblewkorvette's Avatar
Quote:
I have it in my 98. Don't care for it.
knewblewkorvette is offline   Reply With Quote
Old 07-15-2012, 04:09 PM   #16
peter pan
Life Time NCM #2196
peter pan's Avatar
I had one in my deceased C5 and it was very good, I never missed shifts at the Texas Mile at 7k and even into 5 lots of other miss gears out there. I think being a tad notchy helps in high RPM shifts and I did plenty of those
peter pan is offline   Reply With Quote
Old 07-15-2012, 09:49 PM   #17
z06scentair
CF Senior Member
z06scentair's Avatar
I'm pretty sure there are two B&M Shifters available for the c5. One is called the ripper and the other is called something else???
Am I correct? And if so what the difference?
z06scentair is offline   Reply With Quote
Old 07-16-2012, 03:45 AM   #18
Coach62
CF Senior Member
St. Jude Donor '12
I do like mine, but it can be tricky to get it into 1st on occasion.
I can't find a link to the anti-venom mod. Where can I find that? I'll try it and report back.
Coach62 is offline   Reply With Quote
Old 07-16-2012, 06:27 AM   #19
Tuscany
nobody
Tuscany's Avatar
The one I have, pictured above, is called "Precision Sport Shifter". I've seen pictures of another, without the vibration-isolating design and with a single straight-through shaft. I think that's the Ripper.
Quote:
This is a trait inherent in the transmission, having nothing to do with the shifter. Even the owner's manual references it. The most effective recovery is to double-clutch (while in neutral, release and re-depress the clutch, then try again to engage first gear). It's just how the synchros and dog teeth are structured in the transmission, I believe.
This is the link I just used to do mine and found it to be awesome: http://www.toquez06.com/avm.html (Thanks, Mark!) I had some minor difficulty finding the right washer/gasket, but eventually found the Dorman 095-023 matches the Oil-Tite 65277 pictured on Mark's page.
Old 07-16-2012, 08:04 AM   #20
nvusgt
CF Senior Member
nvusgt's Avatar
Send a message via MSN to nvusgt
Pops
That's incredible, do you have a way to reproduce this if by some chance I or someone else wanted to compensate you for said mod?
Different car but very relevant. Had a 90 Celica and spent months reading about short shifters. Only found one that changed the fulcrum point (ball joint in shifter box) tthus creating an actual short throw shifter rather than a short rod shifter.
Could you take photos or video of the setup, I'd be very interested in seeing the final assembly.
nvusgt is offline   Reply With Quote
Reload this Page C5 B & M Shifter Review
Tags
b&m, shifter
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
