Originally Posted by georgec114
(Post 1580502307)
BTW, one option so many people ignore is to burn some CDs with your MP3 music on and use the player built in to your radio. If you have the 6 CD player, it stores hundreds of files. All controlled from the steering wheel or radio.:thumbs: Personally, I could care less about listening to music my wife has on her iPhone ... She just asked me if there was a way to listen to her iPhone music through the car's audio system ... hense my silly questions to everyone here. |
Originally Posted by vettenevodrvr
(Post 1580502234)
Just buy a cable with the 3.5 on both ends. Plug one end into the headphone jack of the iPhone and the other into the car's stereo.
Just remember, this will drain the iPhone battery. You won't be able to control music tracks from the stereo. But, you have a point about not being able to control the music tracks from the car's radio or steering wheel controls ... but she can do that with the iPhone herself. I just wonder how good the sound quality would be from the iPhone being attached to the car's audio system though a wire with 3.5mm stereo plugs on each end? . |
Originally Posted by Turbo6TA
(Post 1580502367)
Well, my wife does have a recharger wire that plugs into the cigarette lighter, so she can keep the iPhone charged while in the car.
But, you have a point about not being able to control the music tracks from the car's radio or steering wheel controls ... but she can do that with the iPhone herself. I just wonder how good the sound quality would be from the iPhone being attached to the car's audio system though a wire with 3.5mm stereo plugs on each end? . As for quality I haven't noticed any drop in quality from the regular radio stations to my iPod. I would make sure the EQs are both set up fairly close to each other if you can change both of them. I have a cheap-o cable and it works great. Either get a good mix setup or have it somewhere where you can easily change the songs. |
Ok .... Thank's everyone for all the great info you have provided.
I am just going to buy a cheap wire with a 3.5mm stereo plug on each end from Radio Shack and connect that between the iPhones headset plug and the plug on the car radio. If it works, it works ... if it sounds like crap, I will dump the wire and tell my wife to start listening to CDs .. and use her iPhone to make telephone calls like it was intended for in the first place. . |
(Post 1580502476)
I am just going to buy a cheap wire with a 3.5mm stereo plug on each end and connect that between the iPhones headset plug and the plug on the car radio. If it works, it works ... if it sounds like crap, I will dump the wire and tell my wife to start listening to CDs .. and use her iPhone to make telephone calls like it was intended for in the first place. . |
If the music sounds good from the ipod, it will sound good from the cars stereo speakers. I use mine with my coupe that does not have the nav. Its a 4LT 09 GT1 coupe but if the car has nav, it will not have the mp3 connector on the dash. Enjoy, be sure to set the radio to Aux!
When you first plug it in and switch to AUX you might not hear anything. If this happens, turn up the volume on the iPod/iPhone. The first time I tried it I thought it was broken just because I had the iPhone volume too low.
Sound quality going this way isn't as good as going through USB, but it is acceptable. I just ordered a Kenwood DDX-719 from DoubleDMods so I can just plug in and charge the iPhone at the same time. This unit will also display the Garmin nav screen which is pretty cool. John |
Here is another option for you. Do a search for Techmart Wireless FM transmitter for Ipod iphone. I have one for my ipod it just plugs into the bottom of the ipod etc. and set the fm radio to an unused frequency and the same on the transmitter and your in business. Also it recharge the ipod through the cig lighter. Works like a damn.
Originally Posted by John in MD
(Post 1580503282)
John As a consequence, the newer Kenwoods do support streaming audio via bluetooth (including the DDX719). "Built-In Bluetooth A2DP Music Streaming - Enjoy wireless music playback from your Bluetooth device like a smartphone or tablet via Bluetooth through your in-dash receiver." |
All,
Just be aware that BlueTooth will degrade the sound quality noticeably versus being directly connected, and given that your iPod already degrades the sound significantly versus the CD, you are working your way back towards LP-like sound quality. Just wanted you to know. Don't use an FM transmitter unless you are VERY tolerant of poor sound quality, static and music bleeding over from others doing the same as you pass them on the street. |
Originally Posted by sportcruiser
(Post 1580507456)
All,
(Post 1580507456)
All,
Just be aware that BlueTooth will degrade the sound quality noticeably versus being directly connected, and given that your iPod already degrades the sound significantly versus the CD, you are working your way back towards LP-like sound quality. Just wanted you to know. Don't use an FM transmitter unless you are VERY tolerant of poor sound quality, static and music bleeding over from others doing the same as you pass them on the street. You're right though, I don't know why anyone would use an FM transmitter these days. |
(Post 1580501867)
Well, so much for that idea.
But here is another ... There is a little input connector on the upper right hand corner of the OEM radio. Can a wire with that type of plug on the end be connected between the iPhone and the car's radio so I can listen to music that playing on the iPhone through the car's audio system? If not, what the hell is that input jack on the car's radio even good for? |
(Post 1580507456)
All,
Just be aware that BlueTooth will degrade the sound quality noticeably versus being directly connected... Don't use an FM transmitter unless you are VERY tolerant of poor sound quality, static and music bleeding over from others doing the same as you pass them on the street. It's a shame that more companies haven't adopted the lossless Bluetooth audio codec that was published, and instead continue to use A2DP. :ack: But that's purely a reflection of consumer wants.
(Post 1580507456)
And LPs really don't have bad SQ either. Well mastered LPs with good quality playback devices (needle, turntable, etc) can arguably sound better than CDs. |
Originally Posted by WAwatchnut
(Post 1580518293)
:iagree:
It's a shame that more companies haven't adopted the lossless Bluetooth audio codec that was published, and instead continue to use A2DP. :ack: But that's purely a reflection of consumer wants. The iPod doesn't degrade song quality. Poor lossy recordings stored on an IPod degrade SQ. The iPhone/iPod use pretty high quality Wolfson DACs, so theyre really not the culprit. And LPs really don't have bad SQ either. Well mastered LPs with good quality playback devices (needle, turntable, etc) can arguably sound better than CDs. Regarding LP's, sure, with the very best equipment and a brand new LP that is not warn they sound pretty good, but in a practical sense, for the average person, there is little comparison; and if I recall, the CD has about 15db more dynamic range. In any event, do what I did, go buy Amaryllis by Shinedown on iTunes and CD (and LP if you so desire), and play them both in your car. The CD is markedly better sounding... more range and much sharper. I was surprised too. |
(Post 1580501867)
Originally Posted by Wideout
(Post 1580515957)
Yep, I think we all realize that CD is better quality than aux/Ipod or Bluetooth. It's also pretty obvious that buying digital media online has overtaken CD sales and is the norm now. Having more options to connect and play digital files or stream music is what I'm after. I don't blast my stereo very often so the slightly lesser quality sound doesn't typically bother me. It is hardly noticeable at low or medium volumes.
I have a DIY for what you want to do. Please see the following link.
http://forums.corvetteforum.com/c6-c...adio-08-a.html |
Use this for your iPhone as it will charge and control it with your controls on your steering wheel, Best unit out there.
http://forums.corvetteforum.com/c6-c...te-owners.html |
