Vararam-ONLY results?
Question about VR-B2 performance results...
Actually could not find a single post on this. All I can find on the entire internet was Vararams very technical/convoluted claims. Anyone here actually dyno the car before and after the install? Since the system works via moving air, anyone have time slips from the same track with very similar weather conditions from before and after the install? Reason I'm asking is simple: I always wanted one because it pulls air directly from the outside front of the car. In theory, this should be extremely effective, but never did much reading on the system. The car I bought came with one -- never installed. So I thought, "awesome!" and installed it the other day. I took it out to check for codes and it pulled like a freight train! So I came back in and researched it and found the usual jargon on Vararam's site. So, I'm wondering, does it perform as they claim and what have been other members' experiences with this system. |
Originally Posted by roadrage06
(Post 1580381230)
Vararam change only, I went from 13.2 @ 107mph (Showroom stock) to 13.2 @ 108mph with a Halltech Stinger CAI, then 13.0 @ 111mph with only a swap from the stinger to vararam.
Originally Posted by All_Motor_C5LS6
(Post 1580385109)
(Post 1580385109)
Originally Posted by RonSSNova
(Post 1580385561)
No tune? Nothing other than the Vararam and you picked up 5mph?
Wow, sounds like this thing really works.
Thanks guys. Anyone else have any experiences? Mine is also untuned at the moment. |
they say on the dyno itll pick up like maybe 5 hp but it all works when driving because of how it is a ram air (literally) setup that you pick up alot more power when driving
I went to an LS6 intake, massaged throttle body, VR-B2, and tuned for the mods in one shot. With the addition of these parts and the tune, I went from 12.640 @ 111 to 12.190 @ 114.76.
Originally Posted by j0n
(Post 1580401068)
Welcome back. I haven't seen you around in a while. I watched your passtime episode the other day. |
Originally Posted by Capthuff
(Post 1580401288)
I went from 13.01@106 to 13.04@108 with just a vararam, untuned. Almost identical 60' times and the DA was better when I ran without the vararam.
so you sped up but got slower?
Originally Posted by baxsom
(Post 1580404459)
Damn I need to get a Vararam, Im just rocking a K&N CAI.... Probably make a huge difference on my Z... I am making pretty decent numbers though with just that K&N and Borla straight pipes.... 367/364
Well in my Z06 with E/T streets I ran an 11.6 no tune. Stock I was running 12.2s but that was on worn out street tires.
Originally Posted by Breze84
(Post 1580408946)
I had one of these but due to a previous wreck with the car, it wouldn't line up so i had to get a killer bee II instead. I wish I could have kept it for this reason.
Woops, went from 13.31@106 to 13.04@108. So I went quicker and faster.
I believe I went 12.5 @ 117 on my Vararam and tune....
