Speedometer gears for 3.54 rear ratio- C4
I have a 1991 that is stock ( 275/40 ZR 17 stock tires ) and I installed a 3.54 ring and pinion. I am trying to find out the two speedo gears inside my 700R4. Can anyone help with GM part #'s or tooth counts? Thanks!! :chevy
Re: Speedometer gears for 3.54 rear ratio- C4 (Vettelover8360)
What ratio did you have previously?
Take a look at this page: http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
:flag |
Re: Speedometer gears for 3.54 rear ratio- C4 (dgoodhue)
Since IM me saying you had 2.59's you will need
Drive Gear 12507670 Grey 15 Driven Gear 25513050 Purple 43 Vehicle Speed Sensor 10456091 |
It had a 2.58 ratio.
Thanks for the info!!! I looked at the page listed above ( ... Speedometergearshtm...) and I couldn't figure out how you knew the drive gear, the driven gear and the vehicle speed sensor. How did you do it? Thanks again!!!
Actualy, how did you know which vehicle speed sensor? ;)
For auto there are 2 different VSS; which one used depends on how many teeth the driven gear has. (Off the top of my head) one is for driven gear 41-45 teeth and the other is for 35-40 teeth. In 1991-3, the 6 speed and auto use different VSS. So I picked the auto VSS for the appopriate number of teeth (41-45 totth VSS)
