Speedometer gears for 3.54 rear ratio- C4
Old 05-17-2002, 11:43 AM
Vettelover8360
Vettelover8360's Avatar
Default Speedometer gears for 3.54 rear ratio- C4
I have a 1991 that is stock ( 275/40 ZR 17 stock tires ) and I installed a 3.54 ring and pinion. I am trying to find out the two speedo gears inside my 700R4. Can anyone help with GM part #'s or tooth counts? Thanks!! :chevy
Old 05-17-2002, 12:48 PM
dgoodhue
dgoodhue's Avatar
Default Re: Speedometer gears for 3.54 rear ratio- C4 (Vettelover8360)
What ratio did you have previously?
Old 05-17-2002, 01:34 PM
2012 coupe
Support Corvetteforum!
2012 coupe's Avatar
Take a look at this page: http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
:flag
Old 05-17-2002, 01:38 PM
dgoodhue
dgoodhue's Avatar
Default Re: Speedometer gears for 3.54 rear ratio- C4 (dgoodhue)
Since IM me saying you had 2.59's you will need
Drive Gear 12507670 Grey 15
Driven Gear 25513050 Purple 43
Vehicle Speed Sensor 10456091
Old 05-17-2002, 01:39 PM
Vettelover8360
It had a 2.58 ratio.
Old 05-17-2002, 02:06 PM
Vettelover8360
Thanks for the info!!! I looked at the page listed above ( ... Speedometergearshtm...) and I couldn't figure out how you knew the drive gear, the driven gear and the vehicle speed sensor. How did you do it? Thanks again!!!
Old 05-17-2002, 02:09 PM
Vettelover8360
Actualy, how did you know which vehicle speed sensor? ;)
Old 05-17-2002, 03:05 PM
dgoodhue
dgoodhue's Avatar
For auto there are 2 different VSS; which one used depends on how many teeth the driven gear has. (Off the top of my head) one is for driven gear 41-45 teeth and the other is for 35-40 teeth. In 1991-3, the 6 speed and auto use different VSS. So I picked the auto VSS for the appopriate number of teeth (41-45 totth VSS)
To Speedometer gears for 3.54 rear ratio- C4
Quick Reply: Speedometer gears for 3.54 rear ratio- C4
