GM LS3 Connect and Cruise Package
Has anyone saw this GM Performance LS3 Connect and Cruise package at Pace Performance.
http://paceperformance.com/i-7806134...65e-trans.html I am looking to do a LS3 swap, so it looks tempting. |
I think it would make for a very simple install, plus you will be using a New motor and transmission instead of a unit with a history.
If this is what you chose to go with I would budget in another 1500 to 2000 to complete the swap, there are a lot of small hidden cost in an LS swap, fuel system, exhaust, motor mounts, shorten the drive shaft, a starter for this setup and belts and hoses, plus more. And then there are the, while I'm here items that will pop up. If and when you do a LS swap, I would love to see you project as it's being put together. Riggs |
Thanks Riggs,
I don't mind spending a few extra bucks for simple. Once I get the project scope and budget defined I will start posting on the build. |
Originally Posted by dkeith
(Post 1580041187)
Thanks Riggs,
I don't mind spending a few extra bucks for simple. Once I get the project scope and budget defined I will start posting on the build. Not easy but IMO worth every bit of the aggravation. :cheers: Rick B. |
No project turns out simple. Check out my blog on my LS2 73 project. The link is in my signature below. Feel free to ask questions. I got lots of help from forum members and have a few lessons learned of my own
Budget is really non existant. You go way over budget. Whatever yo uthink you can spend double it and double the time and you may be close.
Thanks Mffi15 for the website.
Trust me I will have a lot of questions. I understand it's not simple, but also not impossible. My point was that this setup by GMP might take some problems out of installation with the wiring harness and tune. I am ready to start and wanting to make the best choice Thanks for the input. |
Originally Posted by Gordonm
(Post 1580043718)
So I am limiting myself for this build....or so I say...LOL |
For $2k more you might as well get the 525hp version.
Yeah that is where I am heading.
Don't worry about tune.
(Post 1580043728)
Trust me I will have a lot of questions. I understand it's not simple, but also not impossible. My point was that this setup by GMP might take some problems out of installation with the wiring harness and tune. I am ready to start and wanting to make the best choice Thanks for the input. If plug and play is your primary concern, then teh GM |
(Post 1580043728)
Trust me I will have a lot of questions. I understand it's not simple, but also not impossible. My point was that this setup by GMP might take some problems out of installation with the wiring harness and tune. I am ready to start and wanting to make the best choice Thanks for the input. If plug and play is your primary concern, then the GMPP set up is for you. Does it also provide the electric fuel pump? You might want to research some and read other LS conversion threads on the forum. There are several vendors who provide all the conversion parts you need, motor mounts, etc. Josh at Custom Image Corvettes is another good source. He spent hours on the phone with me when I first started the project a couple years ago. If you have any more questions, pm me for my phone number. Good luck |
(Post 1580043718)
I have almost as much in "extras" and hidden costs as I have in a complete low mile LS2/t56 6speed pull out. :crazy: |
I've been following some of "Gordonm's" progress on the LS swap he's doing, and knows a few things. GM performance, sells engine transplant computer kits for LS and auto tranny's. Are about $1K ea for the engine, plus another $1K for the tranny. Josh, at Custom Image Corvettes in SD can put you together on everything needed for the conversion. Assuming, you'd be going with a used engine/tranny, which most do.
Corey-will you please change your avatar! when i get to your posts, i can't go any further.
Originally Posted by jnb5101
(Post 1580046912)
That package sound like a good deal but figure $4-5000 extra for Fuel system, Front runner, Air intake, Radiator, Fans, Motor Mounts, Exhuast
+ + + + + I have built one of these cars and building another right now and I do all of my own labor. When you are done you have a 1'' tall stack of parts invoices. Mark |
