GM LS3 Connect and Cruise Package
Old 02-17-2012, 09:07 AM
dkeith
dkeith's Avatar
Default GM LS3 Connect and Cruise Package
Has anyone saw this GM Performance LS3 Connect and Cruise package at Pace Performance.
http://paceperformance.com/i-7806134...65e-trans.html
I am looking to do a LS3 swap, so it looks tempting.
Old 02-17-2012, 03:53 PM
riggs 74
riggs 74's Avatar
I think it would make for a very simple install, plus you will be using a New motor and transmission instead of a unit with a history.
If this is what you chose to go with I would budget in another 1500 to 2000 to complete the swap, there are a lot of small hidden cost in an LS swap, fuel system, exhaust, motor mounts, shorten the drive shaft, a starter for this setup and belts and hoses, plus more. And then there are the, while I'm here items that will pop up.
If and when you do a LS swap, I would love to see you project as it's being put together.
Riggs
Old 02-17-2012, 04:28 PM
dkeith
dkeith's Avatar
Thanks Riggs,
I don't mind spending a few extra bucks for simple.
Once I get the project scope and budget defined I will start posting on the build.
Old 02-17-2012, 06:40 PM
72LS1Vette
72LS1Vette's Avatar
Originally Posted by dkeith
Thanks Riggs,
I'd edit that to say "I don't mind spending a few extra bucks for relatively simple." There isn't anything simple when it comes to a LS swap unless you're just writing checks to have someone else do the work. You still have to build the fuel system, buy the accessories for the motor, change your cooling system to use an electric fan, etc.
Not easy but IMO worth every bit of the aggravation.
Rick B.
Old 02-17-2012, 07:29 PM
mffi115
mffi115's Avatar
No project turns out simple. Check out my blog on my LS2 73 project. The link is in my signature below. Feel free to ask questions. I got lots of help from forum members and have a few lessons learned of my own
Old 02-17-2012, 09:11 PM
Gordonm
Gordonm's Avatar
Budget is really non existant. You go way over budget. Whatever yo uthink you can spend double it and double the time and you may be close.
Old 02-17-2012, 09:13 PM
dkeith
dkeith's Avatar
Thanks Mffi15 for the website.
Trust me I will have a lot of questions.
I understand it's not simple, but also not impossible.
My point was that this setup by GMP might take some problems out of installation with the wiring harness and tune.
I am ready to start and wanting to make the best choice
Thanks for the input.
Old 02-17-2012, 09:16 PM
dkeith
dkeith's Avatar
I agree what you say here........Ive been putting money into this car for the last 7 years and now I want to spend more money.
So I am limiting myself for this build....or so I say...LOL
Old 02-17-2012, 09:17 PM
lionelhutz
lionelhutz's Avatar
For $2k more you might as well get the 525hp version.
Old 02-17-2012, 09:21 PM
dkeith
dkeith's Avatar
Yeah that is where I am heading.
Old 02-17-2012, 09:48 PM
mffi115
mffi115's Avatar
Default Don't worry about tune.
If you find a good used motor like I did, there are plenty of after market vendors to either tune or provide you a custom ECM harness. Since I didn't get the ECM/harness, Speartech provided a custom set up for a reasonable price. VettAid also builds custom harness/ECM. VettAid has been building me a complete custom wiring sytem, modding all the stock and LS harness to integrate and support the electronic upgrades I'm doing.
If plug and play is your primary concern, then teh GM
Old 02-17-2012, 09:55 PM
mffi115
mffi115's Avatar
If you find a good used motor like I did, there are plenty of after market vendors to either tune or provide you a custom ECM and harness. Since I didn't get the ECM/harness with the motor, Speartech provided a custom set up for a reasonable price. VettAid also builds custom harness/ECM. VettAid has been building me a complete custom wiring system, modding all the stock and LS harness to integrate and support the electronic upgrades I'm doing.
If plug and play is your primary concern, then the GMPP set up is for you. Does it also provide the electric fuel pump? You might want to research some and read other LS conversion threads on the forum. There are several vendors who provide all the conversion parts you need, motor mounts, etc. Josh at Custom Image Corvettes is another good source. He spent hours on the phone with me when I first started the project a couple years ago.
If you have any more questions, pm me for my phone number.
Good luck
Old 02-18-2012, 02:53 AM
Corey_68
Corey_68's Avatar
This right here above...
I have almost as much in "extras" and hidden costs as I have in a complete low mile LS2/t56 6speed pull out.
Old 02-18-2012, 04:18 AM
Vette5.5
Vette5.5's Avatar
I've been following some of "Gordonm's" progress on the LS swap he's doing, and knows a few things. GM performance, sells engine transplant computer kits for LS and auto tranny's. Are about $1K ea for the engine, plus another $1K for the tranny. Josh, at Custom Image Corvettes in SD can put you together on everything needed for the conversion. Assuming, you'd be going with a used engine/tranny, which most do.
Old 02-18-2012, 10:43 AM
jnb5101
jnb5101's Avatar
Corey-will you please change your avatar! when i get to your posts, i can't go any further.
Old 02-18-2012, 11:26 AM
Corey_68
Corey_68's Avatar
Sorry about that, I do need to/will change it but not sure if it will be any better. Hopefully she will be game for another avatar pic by start of football season.
Old 02-19-2012, 06:36 PM
mark6669
mark6669's Avatar
That package sound like a good deal but figure $4-5000 extra for Fuel system, Front runner, Air intake, Radiator, Fans, Motor Mounts, Exhuast
+ + + + + I have built one of these cars and building another right now and I do all of my own labor. When you are done you have a 1'' tall stack of parts invoices.
Mark
To GM LS3 Connect and Cruise Package
Quick Reply: GM LS3 Connect and Cruise Package
