6 speed Shift Problems
I recently purchased a 2007 ZO6 from an individual. I have had the car about 3 months and am now having probvlems shifting into 2nd gear.
Shifting into 2nd gear had a slight bind and now most of the time it refuses to go into gear. At idle I can shift into 2nd with no problem, it is only when I am under acceleration. This car only has 7300 actual miles. |
Originally Posted by mizellbe
(Post 1579554647)
is it the CAGS. Make sure you're at or over 19 mph to shift into second.
(Post 1579554647)
Might be a combination of things that are slightly off, such as a weak/damaged synchro, shift linkage, etc. Cooler weather (longer warm-up) might also contribute.
For starters, look at the clutch fluid. Changing it might be worth a try: But I'm guessing that won't fix the problem. Might need a trip to the dealer. :( Also if you get a chance, drive another C6 and see how it compares. |
Originally Posted by budgreen3564
(Post 1579554847)
(Post 1579554647)
Shifting into 2nd gear had a slight bind and now most of the time it refuses to go into gear. At idle I can shift into 2nd with no problem, it is only when I am under acceleration. This car only has 7300 actual miles. It's covered in your owners manual. |
Originally Posted by JoesC5
(Post 1579555984)
Like others have noted, it appears you are trying to shift into 2nd gear when the CAGS is locking you out. Have you noticed the 1->4 light on the face of the tach lighting up? When it's lit, a solenoid in the transmission is locking out 2nd gear and makes you shift to 4th gear. You can purchase a CAGs eliminator that gets rid of this nuisance for $20. Then you can drive your car and shift it into second gear when it feels natural to you, instead of when the computer thinks it's appropriate.
It's covered in your owners manual. One-to-Four Shift Light (Manual Transmission) When this light comes on, you can only shift from FIRST (1) to FOURTH (4) instead of FIRST (1) to SECOND (2). You must complete the shift into FOURTH (4) to turn off this feature. This helps you get the best possible fuel economy. After shifting to FOURTH (4), you may downshift to a lower gear if you prefer. Notice: Forcing the shift lever into any gear except FOURTH (4) when the 1 TO 4 SHIFT light comes on may damage the transmission. Shift only from FIRST (1) to FOURTH (4) when the light comes on. This light will come on when: • The engine coolant temperature is higher than 169°F (76°C), • the vehicle is going 15 to 19 mph (24 to 31 km/h) and • the vehicle 21 percent throttle or less. |
I generally shift from 1 to 3 if I'm just putting around...4th seems to bog the motor a little. Sorry for going off topic.
This is an issue that is relatively common with the T56 / TR6060, so I am told.
I am having an identical issue with my 2007 Z51 equipped C6. 2nd works just fine at low revs and even at high, steady revs but rapidly increasing revs (acceleration) will cause it to grind every single time. I have changed my clutch fluid, flushed the transmission fluid, installed a CAGS eliminator, installed an MGW short throw shifter and installed a TICK adjustable clutch master cylinder and ALL have failed to solve the problem. Therefore I have come to the conclusion that it must be a 2nd gear synchro. You may be having the same issue as I am. I'll be getting this fixed ASAP, and I'll let you know how hard I was banged for it. |
My hard shift turned out to be a rebuild and main shaft upgrade. 3 grand later shifts great. Mine had 90000 mi. so I would get it done under warranty if I were you.
Most likely the skip shift if not anything major.
Originally Posted by GS-Zero
(Post 1579570176)
Could be that the cage is still activating and blocking you out of second.
http://xse.com/leres/z06/cags.html Could be that the clutch is not fully disengaging due to dirty clutch fluid. Or could be enough sling shot forced shifts into second gear that the second gear syncro needs to be replaced, since it so worn out slots to tabs that the two gears trying to lock together on the second gear shift are going point to point/over rotate to block out the shift isntead. |
OP's last post on this problem:
12/26/11 : " The problem with my 1st to 2nd shift will be solved by installing a skip shift eliminator. My local dealer was very helpful and explaining why the problem exists." 7 year old thread bumped for no good reason. The solution is in the owner's manual and has been posted here several dozen times. OP's more recent posts are in the C3 forum. |
Originally Posted by Vette_DD
(Post 1597896580)
I was well aware that this was an old post I had done a search for this problem and ran across this one. The person who posted never responded if the syncro repair did the job. I admit I am a noob but know enough to look at the date, I thought fellow Vette owners would be courteous enough to respond. Some do and for those I am very grateful. |
And a clarification to my problem the hard shifting happens well above the set point for the solenoid to lock out second gear. I see the light come on the dash when that feature kicks in. |
Originally Posted by Rayzsurfer
(Post 1597903213)
I agree. If you are newer to this forum it is fair to bring up old threads. If the bobble heads that insult you for asking for help just ignore them People with real answers will respond. And for you old crabby members that think they know everything just help the new C6 owners. They are not the enemy. Being rude seems nonproductive.
