Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-24-2011, 11:16 AM   #1
mizellbe
Junior Member
Default 6 speed Shift Problems
I recently purchased a 2007 ZO6 from an individual. I have had the car about 3 months and am now having probvlems shifting into 2nd gear.
Shifting into 2nd gear had a slight bind and now most of the time it refuses to go into gear.
At idle I can shift into 2nd with no problem, it is only when I am under acceleration. This car only has 7300 actual miles.
mizellbe is offline   Reply With Quote
Old 12-24-2011, 11:29 AM   #2
Dave S
CF Senior Member
Support Corvetteforum!
Dave S's Avatar
Hard to say based upon limited info, but my first thought would be the 2nd gear synchro going bad. Presuming you were able to tranfer the warranty when you bought the vehicle, I would have it looked at by a reputable dealer mechanic, i.e. one who regularly works on Vettes.
Dave S is offline   Reply With Quote
Old 12-24-2011, 11:37 AM   #3
budgreen3564
CF Senior Member
budgreen3564's Avatar
is it the CAGS. Make sure you're at or over 19 mph to shift into second.
budgreen3564 is offline   Reply With Quote
Old 12-24-2011, 11:43 AM   #4
REVAK
CF Senior Member
REVAK's Avatar
about ditching the cags. Also check or change the fluid in the clutch master cyl. Check and or change trans. oil.
REVAK is offline   Reply With Quote
Old 12-24-2011, 12:24 PM   #5
CO Lightfoot
CF Senior Member
CO Lightfoot's Avatar
Might be a combination of things that are slightly off, such as a weak/damaged synchro, shift linkage, etc. Cooler weather (longer warm-up) might also contribute.
For starters, look at the clutch fluid. Changing it might be worth a try:
But I'm guessing that won't fix the problem. Might need a trip to the dealer.
Also if you get a chance, drive another C6 and see how it compares.
CO Lightfoot is offline   Reply With Quote
Old 12-24-2011, 01:01 PM   #6
Mrc100
CF Senior Member
Mrc100's Avatar
Quote:
.... Possibly the skip shift locking out 2nd as designed?
Mrc100 is offline   Reply With Quote
Old 12-24-2011, 02:02 PM   #7
JoesC5
CF Senior Member
Like others have noted, it appears you are trying to shift into 2nd gear when the CAGS is locking you out. Have you noticed the 1->4 light on the face of the tach lighting up? When it's lit, a solenoid in the transmission is locking out 2nd gear and makes you shift to 4th gear. You can purchase a CAGs eliminator that gets rid of this nuisance for $20. Then you can drive your car and shift it into second gear when it feels natural to you, instead of when the computer thinks it's appropriate.
It's covered in your owners manual.
JoesC5 is offline   Reply With Quote
Old 12-24-2011, 02:09 PM   #8
JimTN
Moderator
JimTN's Avatar
2007 owner's manual, page 193.
Quote:
One-to-Four Shift Light
(Manual Transmission)
When this light comes
on, you can only shift
from FIRST (1) to
FOURTH (4) instead of
FIRST (1) to
SECOND (2).
You must complete the shift into FOURTH (4) to
turn off this feature. This helps you get the
best possible fuel economy.
After shifting to FOURTH (4), you may downshift
to a lower gear if you prefer.
Notice: Forcing the shift lever into any gear
except FOURTH (4) when the 1 TO 4 SHIFT light
comes on may damage the transmission.
Shift only from FIRST (1) to FOURTH (4) when
the light comes on.
This light will come on when:
The engine coolant temperature is higher than
169F (76C),
the vehicle is going 15 to 19 mph
(24 to 31 km/h) and
the vehicle 21 percent throttle or less.
JimTN is offline   Reply With Quote
Old 12-24-2011, 03:02 PM   #9
Mrc100
CF Senior Member
Mrc100's Avatar
I generally shift from 1 to 3 if I'm just putting around...4th seems to bog the motor a little. Sorry for going off topic.
Old 12-26-2011, 06:06 PM   #10
GS-Zero
CF Senior Member
GS-Zero's Avatar
This is an issue that is relatively common with the T56 / TR6060, so I am told.
I am having an identical issue with my 2007 Z51 equipped C6. 2nd works just fine at low revs and even at high, steady revs but rapidly increasing revs (acceleration) will cause it to grind every single time.
I have changed my clutch fluid, flushed the transmission fluid, installed a CAGS eliminator, installed an MGW short throw shifter and installed a TICK adjustable clutch master cylinder and ALL have failed to solve the problem.
Therefore I have come to the conclusion that it must be a 2nd gear synchro. You may be having the same issue as I am. I'll be getting this fixed ASAP, and I'll let you know how hard I was banged for it.
GS-Zero is offline   Reply With Quote
Old 12-26-2011, 08:25 PM   #11
AH-PSHAW
Junior Member
R.Gene Shaw
My hard shift turned out to be a rebuild and main shaft upgrade. 3 grand later shifts great. Mine had 90000 mi. so I would get it done under warranty if I were you.
AH-PSHAW is offline   Reply With Quote
Old 12-26-2011, 08:29 PM   #12
Detoxx03
CF Senior Member
Detoxx03's Avatar
https://www.facebook.com/DetoxxAtomic Detoxx03 Detoxx03 Detoxx03 Detoxx03
Most likely the skip shift if not anything major.
Detoxx03 is offline   Reply With Quote
Reload this Page 6 speed Shift Problems
Tags
2006, 2011, 2nd, c5, c6, corvette, corvettte, hard, issues, problem, problems, shift, shifting, speed, synchro
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
