injectors - F1TE-D5A - Ford 24lb? ... ford 24lb'ers?
so while i'm hunting down my vacuum leak at the back of block...
which i haven't found... and am almost wondering if I am A) hearing all 4 injectors on that side pulsing now... B) I found that the little vacuum line to the throttle body was loose... idle is stable now at 600rpm in park or in drive. C) a random tool I lost nights ago in my engine block and dropped down under it that I swear looked for and replaced yesterday.... I've heard these injectors are underrated... think they are good for my blocks modifications? |
The Ford injectors were the "thing" to use several years ago because they were plentiful and cheap. I would suggest that you PM Jon at FIC and get a good set of injectors from him. He can advise you on exactly what you need.
