injectors - F1TE-D5A - Ford 24lb? ... ford 24lb'ers?
Old 08-17-2011, 07:42 PM
mistaben
mistaben's Avatar
Default injectors - F1TE-D5A - Ford 24lb? ... ford 24lb'ers?
so while i'm hunting down my vacuum leak at the back of block...
which i haven't found... and am almost wondering if I am
A) hearing all 4 injectors on that side pulsing now...
B) I found that the little vacuum line to the throttle body was loose... idle is stable now at 600rpm in park or in drive.
C) a random tool I lost nights ago in my engine block and dropped down under it that I swear looked for and replaced yesterday....
I've heard these injectors are underrated... think they are good for my blocks modifications?
Old 08-17-2011, 08:54 PM
John A. Marker
John A. Marker's Avatar
The Ford injectors were the "thing" to use several years ago because they were plentiful and cheap. I would suggest that you PM Jon at FIC and get a good set of injectors from him. He can advise you on exactly what you need.
Quick Reply: injectors - F1TE-D5A - Ford 24lb? ... ford 24lb'ers?
