283 & 327 w/4 bolt mains
Does anyone have any original GM 4 bolt main caps for a small journal crank? These are the straight bolt type, not splayed.
R U talking about 2.300 inch? Like pre 1967
The small journal block never had OEM 4 bolt main caps, if you have a early block with 4 bolt main caps they are aftermarket pieces. Program Engineering, Milodon, Summers Brothers are some of the suppliers for these pieces. Your best bet would be to get a machine shop to look at your motor and help you out. Posting some pictures of the pieces your talking about would be helpful.
Originally Posted by Solid LT1
(Post 1577090604)
Originally Posted by gkull
(Post 1577090318)
r u talking about 2.300 inch? Like pre 1967
Originally Posted by Dr L-88
(Post 1577092153)
1959 283
Go Cats. :thumbs: |
(Post 1577092852)
Not originally 4 bolt.
Go Cats. :thumbs: GO CATS! |
I went to college at UNLV and live in this great state. They are number 8 seed in southwest Tourn. I hope that they make it a couple of rounds!:D
I just can't remember a 283 with a 4 bolt. anything is possible though. Here's the list of all the small block casting #'s CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES 140029.....350...80-84...2 330817.....400...72-80...2 355909.....262.....75....2 360851.....262...75-76...2...Monza V-8 361979.....305...78-79...2 366245.....350...78-79...2 366287...................4...Bowtie, Aluminum, siamesed, straight nodular iron main caps, 2-piece seal, 4.00-4.150" bores, 2.45" main journals 366299...................4...Bowtie, Aluminum, nodular iron splayed caps, wet sump, 4.00" bore 389257.....302.....67....2 393288.....283...65-67...2 460703.....350.....78....4 460776.....305...78-79...2 460777.....305...78-79...2 460778.....305...78-79...2 471511.....267...79-82...2 3556519....283...58-61...2 3703524....265.....55....2...No oil filter 3720991....265...56-57...2 3731548....265...57......2...No side motor mounts 3731548....283...57......2...No side motor mounts 3737739....283...58-64...2 3756519....283...58-62...2 3782870....327...62-67...2 3789817....283...62-64...2 3789817....327...62-67...2 3789935....283...61-64...2 3790721....283...62-64...2...Chevy II recessed oil filter boss 3790721....327...65-66...2...Chevy II recessed oil filter boss 3791362....327...62-67...2...Chevy II recessed oil filter boss 3792563....327.....65....2 3792582....283...64-65...2 3794226....283...58-63...2 3794460....327...62-64...2 3814660....327...68-69...2 3830944....327.....63....2 3834810....283...64-66...2 3834812....283...62-63...2 3837739....283...58-62...2 3849852....283...64-68...2 3849935....283...65-67...2 3852174....327...62-64...2 3858174....327...64-66...2 3858180....327...64-67...2 3858618....350...68-76...2 3862194....283...65-67...2...Chevy II recessed oil filter boss 3862812....283...62-64...2 3892657....302.....67....2...Z-28 Camaro 3892657....327.....67....2 3892657....350.....67....2...Camaro 3896944....283.....67....2 3896948....283...66-67...2 3903352....327.....67....2 3914636....307.....68....2 3914653....307...68-73...2 3914660....327.....68....2 3914678....302.....68....2...Z-28 Camaro 3914678....327.....68....2 3914678....350.....68....2 3932371....307...69-73...2 3932373....307...68-73...2 3932386....302.....69....4...Z-28 Camaro 3932386....327.....69....2 3932386....350.....69....4 3932388....350.....69....2 or 4 3951509....400...70-71...4 3951509....400...74-80...2 3951511....400...70-71...4...Some replacement blocks had 2-bolt main caps 3956618....302.....69....4...Z-28 Camaro 3956618....327...68-69...2 3956618....350.....69....2 or 4 3956632....307.....69....2 3959512....327...62-63...2 3970010....302.....69....4...Z-28 Camaro 3970010....350...69-80...2 or 4 3970014....350...70-74...2 or 4 3970020....307...70-73...2 3970024....307...69-71...2 4715111....305.....80....2 6259425....350...69-76...2 10036033...350...........4...Goodwrenc… crate motor, 2-piece rear seal, "Hecho en Mexico" 10051182.................2...Bowtie, non-siamesed, 3.75" bore 10051184.................4...Bowtie, non-siamesed, 4.00"-4.160" bores 10054727...350...86-up...2 or 4...one piece rear seal, some "Made in Canada" 10066036...350...........4...Goodwrenc… crate motor, 2-piece rear seal, "Hecho en Mexico" 10066038...350.....94....4...Goodwrenc… crate motor, 2-piece rear seal, "Hecho en Mexico" 10090511...350.....90....2...LT-5, ZR1 Vette, 375hp 10125327...350...92-up...4...Gen.II LT-1, reverse flow cooling 10125327...350...96-up...4...Gen.II LT-4, reverse flow cooling 10134996.................4...Bowtie, Aluminum, 4.125" bore 2.65" main journals 10153558...350...91-92...4...LT-5, ZR1 Vette, 375hp 10199001...350...93-95...4...LT-5, ZR1 Vette, 405hp 10243878...305...96-97...2...Vortec truck, roller cam, one-piece rear seal 10243880...350...95-99...4...Gen.I crate motor, "ZZ4", roller cam, one piece rear seal 12550592...350...97-up...crossbolted block, Gen.III, "LS1" 12559846...350...98-up...crossbolted block, Gen.III, "LS1" 12560621...350...98-up...crossbolted block, Gen.III, "LS1" 12562174...350...98-up...crossbolted block, Gen.III, "LS1" 14010201...305...80-84...2 14010202...305...80-84...2 14010203...305...80-84...2 14010207...350...80-85...2 or 4 14010209...350...80-85...4 14010280... |
I thought the first 4 bolt block was the 4" bore block used for 68 and up 302 and 350. Never in my searching have I ever seen a GM 4 bolt 327 or smaller.
I never saw one either.
Originally Posted by SanDiegoPaul
(Post 1577095099)
I've a 265, 3 or 4 283s to of them Nova blocks and a half dozen 327s all small journal and all 2 bolt. Never have seen a 4 bolt from the factory version.
Originally Posted by CaseyJones
(Post 1577093327)
Here is a nodular iron hi-perf cap on my 70 LT-1 motor build: http://i601.photobucket.com/albums/t...LT1maincap.jpg |
