Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-18-2011, 10:16 AM   #1
Dr L-88
CF Senior Member
Dr L-88's Avatar
Default 283 & 327 w/4 bolt mains
Does anyone have any original GM 4 bolt main caps for a small journal crank? These are the straight bolt type, not splayed.
Dr L-88 is offline   Reply With Quote
Old 03-18-2011, 10:36 AM   #2
gkull
CF Senior Member
gkull's Avatar
R U talking about 2.300 inch? Like pre 1967
gkull is offline   Reply With Quote
Old 03-18-2011, 11:07 AM   #3
Solid LT1
CF Senior Member
Solid LT1's Avatar
The small journal block never had OEM 4 bolt main caps, if you have a early block with 4 bolt main caps they are aftermarket pieces. Program Engineering, Milodon, Summers Brothers are some of the suppliers for these pieces. Your best bet would be to get a machine shop to look at your motor and help you out. Posting some pictures of the pieces your talking about would be helpful.
Solid LT1 is online now   Reply With Quote
Old 03-18-2011, 11:48 AM   #4
gkull
CF Senior Member
gkull's Avatar
Quote:
That is why I ask about the actual small journal size 283. 307, 327. Those are not desirable for hot rodding. 4 bolt only appeared when the journal went to 2.400
Old 03-18-2011, 01:39 PM   #5
Dr L-88
CF Senior Member
Dr L-88's Avatar
Quote:
Originally Posted by gkull View Post
r u talking about 2.300 inch? Like pre 1967
1959 283
Old 03-18-2011, 02:53 PM   #6
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
Quote:
Originally Posted by Dr L-88 View Post
1959 283
Not originally 4 bolt.
Go Cats.
Easy Mike is offline   Reply With Quote
Old 03-18-2011, 03:01 PM   #7
Dr L-88
CF Senior Member
Dr L-88's Avatar
Quote:
Go Cats.
This one was.............................not your everday production block, but a GM block anyway.
GO CATS!
Old 03-18-2011, 03:13 PM   #8
gkull
CF Senior Member
gkull's Avatar
I went to college at UNLV and live in this great state. They are number 8 seed in southwest Tourn. I hope that they make it a couple of rounds!
I just can't remember a 283 with a 4 bolt. anything is possible though.
Here's the list of all the small block casting #'s
CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES
140029.....350...80-84...2
330817.....400...72-80...2
355909.....262.....75....2
360851.....262...75-76...2...Monza V-8
361979.....305...78-79...2
366245.....350...78-79...2
366287...................4...Bowtie, Aluminum, siamesed,
straight nodular iron main
caps, 2-piece seal, 4.00-4.150"
bores, 2.45" main journals
366299...................4...Bowtie, Aluminum, nodular
iron splayed caps, wet sump,
4.00" bore
389257.....302.....67....2
393288.....283...65-67...2
460703.....350.....78....4
460776.....305...78-79...2
460777.....305...78-79...2
460778.....305...78-79...2
471511.....267...79-82...2
3556519....283...58-61...2
3703524....265.....55....2...No oil filter
3720991....265...56-57...2
3731548....265...57......2...No side motor mounts
3731548....283...57......2...No side motor mounts
3737739....283...58-64...2
3756519....283...58-62...2
3782870....327...62-67...2
3789817....283...62-64...2
3789817....327...62-67...2
3789935....283...61-64...2
3790721....283...62-64...2...Chevy II recessed oil filter boss
3790721....327...65-66...2...Chevy II recessed oil filter boss
3791362....327...62-67...2...Chevy II recessed oil filter boss
3792563....327.....65....2
3792582....283...64-65...2
3794226....283...58-63...2
3794460....327...62-64...2
3814660....327...68-69...2
3830944....327.....63....2
3834810....283...64-66...2
3834812....283...62-63...2
3837739....283...58-62...2
3849852....283...64-68...2
3849935....283...65-67...2
3852174....327...62-64...2
3858174....327...64-66...2
3858180....327...64-67...2
3858618....350...68-76...2
3862194....283...65-67...2...Chevy II recessed oil filter boss
3862812....283...62-64...2
3892657....302.....67....2...Z-28 Camaro
3892657....327.....67....2
3892657....350.....67....2...Camaro
3896944....283.....67....2
3896948....283...66-67...2
3903352....327.....67....2
3914636....307.....68....2
3914653....307...68-73...2
3914660....327.....68....2
3914678....302.....68....2...Z-28 Camaro
3914678....327.....68....2
3914678....350.....68....2
3932371....307...69-73...2
3932373....307...68-73...2
3932386....302.....69....4...Z-28 Camaro
3932386....327.....69....2
3932386....350.....69....4
3932388....350.....69....2 or 4
3951509....400...70-71...4
3951509....400...74-80...2
3951511....400...70-71...4...Some replacement blocks had 2-bolt main caps
3956618....302.....69....4...Z-28 Camaro
3956618....327...68-69...2
3956618....350.....69....2 or 4
3956632....307.....69....2
3959512....327...62-63...2
3970010....302.....69....4...Z-28 Camaro
3970010....350...69-80...2 or 4
3970014....350...70-74...2 or 4
3970020....307...70-73...2
3970024....307...69-71...2
4715111....305.....80....2
6259425....350...69-76...2
10036033...350...........4...Goodwrenc… crate motor, 2-piece rear
seal, "Hecho en Mexico"
10051182.................2...Bowtie, non-siamesed, 3.75" bore
10051184.................4...Bowtie, non-siamesed, 4.00"-4.160" bores
10054727...350...86-up...2 or 4...one piece rear seal, some "Made in Canada"
10066036...350...........4...Goodwrenc… crate motor, 2-piece rear
10066038...350.....94....4...Goodwrenc… crate motor, 2-piece rear
10090511...350.....90....2...LT-5, ZR1 Vette, 375hp
10125327...350...92-up...4...Gen.II LT-1, reverse flow cooling
10125327...350...96-up...4...Gen.II LT-4, reverse flow cooling
10134996.................4...Bowtie, Aluminum, 4.125" bore
2.65" main journals
10153558...350...91-92...4...LT-5, ZR1 Vette, 375hp
10199001...350...93-95...4...LT-5, ZR1 Vette, 405hp
10243878...305...96-97...2...Vortec truck, roller cam, one-piece rear seal
10243880...350...95-99...4...Gen.I crate motor, "ZZ4", roller cam, one piece rear seal
12550592...350...97-up...crossbolted block, Gen.III, "LS1"
12559846...350...98-up...crossbolted block, Gen.III, "LS1"
12560621...350...98-up...crossbolted block, Gen.III, "LS1"
12562174...350...98-up...crossbolted block, Gen.III, "LS1"
14010201...305...80-84...2
14010202...305...80-84...2
14010203...305...80-84...2
14010207...350...80-85...2 or 4
14010209...350...80-85...4
14010280...
Old 03-18-2011, 03:42 PM   #9
CaseyJones
CF Senior Member
CaseyJones's Avatar
I thought the first 4 bolt block was the 4" bore block used for 68 and up 302 and 350. Never in my searching have I ever seen a GM 4 bolt 327 or smaller.
CaseyJones is offline   Reply With Quote
Old 03-18-2011, 06:40 PM   #10
SanDiegoPaul
CF Senior Member
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
I never saw one either.
SanDiegoPaul is offline   Reply With Quote
Old 03-18-2011, 07:03 PM   #11
Dr L-88
CF Senior Member
Dr L-88's Avatar
Quote:
Me neither...........................until yesterday.
Old 03-18-2011, 08:49 PM   #12
Indiancreek
CF Senior Member
I've a 265, 3 or 4 283s to of them Nova blocks and a half dozen 327s all small journal and all 2 bolt. Never have seen a 4 bolt from the factory version.
Indiancreek is offline   Reply With Quote
Old 03-18-2011, 09:58 PM   #13
Solid LT1
CF Senior Member
Solid LT1's Avatar
Quote:
4Bolt main caps didn't happen until 1969 model year. All 350/302 SBC built in the 67-68 model years have 2 bolt main caps. Also hi-perf motors have nodular iron caps where low HP motors have regular iron caps.
Here is a nodular iron hi-perf cap on my 70 LT-1 motor build:
Click the image to open in full size.
Reload this Page 283 & 327 w/4 bolt mains
Tags
283, 327, 3903352, 4bolt, bolt, cap, caps, corvette, engine, gm, main, mains, make, purchase, specs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
