Fog light bulb replacement
I have one out and saw somewhere here(cant find it now) that a brighter bulb can be put in. I think the factory bulbs are 25 and the brighter ones are 37.5.
What is the part # for the brighter ones? Dont want to change the harness and all that. Thanks. |
stock fog light bulb options
You have the option of 880 fog lights which are LOWER wattage (25W)
and the stock ones are 893 which are 37W HTH, Tommy |
Stick a HID bulb in the stock C5 housing and get some better light output.... :yesnod:
http://mysite.verizon.net/res0aae8/aca/aca2.jpg |
I agree with putting HID bulbs/ballasts in as they are not much money for what you get.
My car started with the weak-vacuum cleaner foglight bulbs 37.5W and I had promptly switched them with the 50W 885 bulbs, it was better but still so very weak. I have a set I'd love to give you but you are in FL. |
Use 885 50W bulbs and reaim the lights almost like headlights
Been using 885 bulbs for sevreral years. Its important to reaim the fog lights. Park about 15 feet in front of a light wall ar garage door. Use a Torx screwdriver and aim them about the same height as the low beam headlights. Switch to parking lights to just see the fog lights. Makes a terriffic difference for less than $5. I always use the fog lights when I have the headlights on. Fills in a lot of light close to the car.
BIGHANK:thumbs: |
Thanks for the info!
Check this link out...pretty handy reference tool for any bulb replacement number for any car.:flag:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Originally Posted by 00 NBFRC
(Post 1576696418)
GET HIDs
:iagree: Buy an HID setup from auction. I just installed one, its plug and play. The originalwiring plugs into the ballast. ballast plugs and then wires from ballast plugs into the HID bulb. They were only about $40 shipped. They are great, i don't even use my low beams anymore, drive with just the driving lights around town. HUGE change in light output.
Originally Posted by chadman
(Post 1576709587)
Mark |
How much are the 885 bulbs?
Think I paid about $2 each in a real auto parts store
Went to an auto supply not Advance, Auto Zone, or Pep Boys. Screw that $6 blister pack. Bought 2 loose. Very inexpensive. Make sure you re-aim the lights with the Torx wrench from the front of the light. Mine were way too low to do any good.
Originally Posted by Hard Core GM
(Post 1576710712)
What auction are you talking about? Where can I get some HID's for head lights and fog lights?
Mark check out JW Motoring....he's a supporting vendor. I purchased my HID headlights and fogs from him....very nice!!!!:flag: |
What auction??
You know, EBAY. Mine were between $40 and $50 with a lifetime warranty. PM me if you want the vendor.
Stock are 37 watts and 885 are 50 watts.
Nice, cheap upgrade |
when adding an HID kit are we able to get a cut off with the stock projector? is a 55watt kit safe to run? an 880 type fits? :smash:
Originally Posted by mickey_7106
(Post 1576846553)
Toque |
I'm running 885 50 watt Xenon filled bulbs in mine. Work GREAT and give a nice white light. A perfect match for the super-white PIAA's in the e-code headlights.
I am going to install HID lights in my low beam. I know they are 9006. But fog lights are 885 or 893 and i haven't been able to find the HID light with this number. Can I use another type of bulb?
interesting. This guy is selling an HID kit only but if you look at the comparison kit theres a sharp cut off :crazy:
Originally Posted by Toque
(Post 1576849084)
You don't get any cut off with a HID in the stock housing. Its the HID housing that gives you the distinct cut off.
Toque |
Fog light bulbs ?
Originally Posted by bighank
(Post 1576702655)
BIGHANK:thumbs: |
