Fog light bulb replacement
Old 02-03-2011, 06:55 PM
00 NBFRC
00 NBFRC's Avatar
Default Fog light bulb replacement
I have one out and saw somewhere here(cant find it now) that a brighter bulb can be put in. I think the factory bulbs are 25 and the brighter ones are 37.5.
What is the part # for the brighter ones?
Dont want to change the harness and all that.
Thanks.
Old 02-04-2011, 09:40 AM
TGstring
TGstring's Avatar
Location: cruising between USA and Canada... SAVE THE WAVE!
Default stock fog light bulb options
You have the option of 880 fog lights which are LOWER wattage (25W)
and the stock ones are 893 which are 37W
HTH,
Tommy
Old 02-04-2011, 09:50 AM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Stick a HID bulb in the stock C5 housing and get some better light output....
Old 02-04-2011, 10:55 AM
BenC5
BenC5's Avatar
I agree with putting HID bulbs/ballasts in as they are not much money for what you get.
My car started with the weak-vacuum cleaner foglight bulbs 37.5W and I had promptly switched them with the 50W 885 bulbs, it was better but still so very weak. I have a set I'd love to give you but you are in FL.
Old 02-04-2011, 01:00 PM
bighank
bighank's Avatar
Default Use 885 50W bulbs and reaim the lights almost like headlights
Been using 885 bulbs for sevreral years. Its important to reaim the fog lights. Park about 15 feet in front of a light wall ar garage door. Use a Torx screwdriver and aim them about the same height as the low beam headlights. Switch to parking lights to just see the fog lights. Makes a terriffic difference for less than $5. I always use the fog lights when I have the headlights on. Fills in a lot of light close to the car.
BIGHANK
Old 02-04-2011, 01:55 PM
craig04c5
craig04c5's Avatar
Thanks for the info!
Old 02-04-2011, 09:51 PM
ourblk96
ourblk96's Avatar
Check this link out...pretty handy reference tool for any bulb replacement number for any car.
http://www.sylvania.com/ConsumerProd...lacementGuide/
Thanks.
Old 02-05-2011, 08:57 AM
chadman
chadman's Avatar
Default GET HIDs
Buy an HID setup from auction. I just installed one, its plug and play. The originalwiring plugs into the ballast. ballast plugs and then wires from ballast plugs into the HID bulb. They were only about $40 shipped. They are great, i don't even use my low beams anymore, drive with just the driving lights around town. HUGE change in light output.
Old 02-05-2011, 11:07 AM
Hard Core GM
Hard Core GM's Avatar
What auction are you talking about? Where can I get some HID's for head lights and fog lights?
Mark
Old 02-05-2011, 04:40 PM
JonnyB
JonnyB's Avatar
How much are the 885 bulbs?
Old 02-05-2011, 05:16 PM
bighank
bighank's Avatar
Default Think I paid about $2 each in a real auto parts store
Went to an auto supply not Advance, Auto Zone, or Pep Boys. Screw that $6 blister pack. Bought 2 loose. Very inexpensive. Make sure you re-aim the lights with the Torx wrench from the front of the light. Mine were way too low to do any good.
Old 02-05-2011, 05:35 PM
ourblk96
ourblk96's Avatar
Mark
check out JW Motoring....he's a supporting vendor. I purchased my HID headlights and fogs from him....very nice!!!!
Old 02-05-2011, 07:23 PM
chadman
chadman's Avatar
Default What auction??
You know, EBAY. Mine were between $40 and $50 with a lifetime warranty. PM me if you want the vendor.
Old 02-07-2011, 09:06 PM
ALLEGRO
ALLEGRO's Avatar
Stock are 37 watts and 885 are 50 watts.
Nice, cheap upgrade
Old 02-20-2011, 05:29 PM
mickey_7106
mickey_7106's Avatar
when adding an HID kit are we able to get a cut off with the stock projector? is a 55watt kit safe to run? an 880 type fits?
Old 02-20-2011, 10:04 PM
Toque
Toque's Avatar
You don't get any cut off with a HID in the stock housing. Its the HID housing that gives you the distinct cut off.
Toque
Old 02-21-2011, 02:34 AM
mcm95403
Support Corvetteforum!
mcm95403's Avatar
I'm running 885 50 watt Xenon filled bulbs in mine. Work GREAT and give a nice white light. A perfect match for the super-white PIAA's in the e-code headlights.
To Fog light bulb replacement
Old 02-21-2011, 08:47 AM
JanCorvette
JanCorvette's Avatar
I am going to install HID lights in my low beam. I know they are 9006. But fog lights are 885 or 893 and i haven't been able to find the HID light with this number. Can I use another type of bulb?
Old 02-21-2011, 12:18 PM
mickey_7106
interesting. This guy is selling an HID kit only but if you look at the comparison kit theres a sharp cut off
Toque
Old 02-21-2011, 04:49 PM
killain
killain's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Default Fog light bulbs ?
BIGHANK
So you have been running the 885/50watt bulbs with no heat problems ? I'd light to install a set I have siting here. I have in been using sylvania SilverStars in the car, but I know that I'm going to have to resort to HID's if i want to have really good lighting ?
Quick Reply: Fog light bulb replacement
