How to fix / repair HVAC climate actuators
6 Attachment(s)
After replacing my battery I started to have HVAC codes show up:
B0361 H BO363 H BO365 H BO367 H B0441 H C B0446 H C Some codes were marked H (history) but after resetting the codes they immediately come back. Here are the symptoms I observed (These might help those who are trying to diagnose their problems):
At this point Bill Curlee has given me feedback and thinks the actuator has broken teeth. The other possible issue is that the actuator needs to be reindexed. Thankfully this is the corvette forum and there is a wealth of information. I used the following up to this point in order to gain visual access to the drivers side actuator. This link also has a great report on how to reindex the drivers side actuator which I use later on. Removing and reindexing drivers side actuator through drivers side kickpanel: http://forums.corvetteforum.com/c5-t...actuators.html Since I had issues with both drivers and passengers actuators I would need to remove the dash (only way to get to the passenger side actuator) and it would prove essential when attempting to repair the actuators since you need easy repeated access. Here is the link to remove the dash: http://forums.corvetteforum.com/c5-t...d-install.html And how to access the passenger side actuator: http://forums.corvetteforum.com/1557915431-post68.html Finally I remove the drivers and passengers actuators, open them up and see: Attachment 48153240 Both have a cracked drive gears. In fact they were broken in the exact same fashion – one crack split wide open and one smaller crack. At this point my car is in pieces and I need two new actuators ($100+ each). I decided instead of buying and waiting for new actuators to arrive, to repair the cracked actuators. It appears they broke due to a manufacturing defect (clearly the hole in the middle of the plastic gear that was pressed onto the metal output shaft is too small of a diameter – by a significant amount – and therefore eventually cracked). It is possible that the new ones would have the same issue. Therefore, I found the best solution was to fix the broken gear with a little epoxy. The first step is to mark the position of the blue gear where it contacts the drive gear. It is also important to mark the corresponding position on the metal shaft. I also found it necessary to mark the outside of the case since cleaning the plastic drive gear and output shaft prior to epoxy could remove the marks I made: Attachment 48153241 If you mess up the marks it isn’t a huge deal since you will have to reindex anyway, but it could help you reindex quicker. After removing the driver gear the first step is to slide the plastic gear off of the metal output shaft. In order to increase the inner diameter I rolled some sandpaper onto a pen and then rolled the gear on my palm. This ensures that the inner diameter is uniformly sanded. Attachment 48153242 I used 100 grit sandpaper since it cuts pretty fast and keeps the surface rough which is important for epoxy adhesion. After several test fits, I got it down to a diameter that snugly fit over the metal output shaft and the large crack was completely closed. I cleaned both the inner diameter and the metal shaft with brake cleaner (any non residue cleaner would work as well), and mixed up some 5 minute epoxy. I applied the epoxy to the metal shaft (and used a toothpick to stuff some into the crack of the white drive gear) and then slid the gear back on while splitting the crack slightly open to avoid rubbing the epoxy off the output shaft. A spring clamp was used to hold the crack shut and keep the gear tight on the output shaft: Attachment 48153243 After letting the parts dry while I took a break, I put them back in the actuators and aligned them the best I could with the marks that I made. During the reassembly I also lightly coated the drive gear with some of the excess grease slung around inside the case. Don’t use too much or you might foul the sensor under the blue gear and have to clean it later: http://forums.corvetteforum.com/c5-t...-indexing.html Now comes the tricky part. I put both back in the car (I only attached them with one screw since I needed to test them). Reconnected the battery, turned the key to ON, and .... nothing had changed. I still got the same exact 6 codes listed at the beginning of this saga. Not to worry though. In retrospect this isn’t unexpected since with the drive gear cracked, the blue (index) gear had moved several teeth out of position after a couple weeks of driving with this issue. So, I disconnected the battery, pulled the passenger side actuator (easier to get to) opened it up and pulled the drive gear and moved it two teeth relative to the blue gear. If you have questions about this look at the link given above that addresses how to reindex. Reassembled, and … I still got the same 6 codes. I repeated this process 4-5 times until all of the passenger side codes went away (3 driver side remained). Success! Now in order to make sure I wasn’t operating on the edge of an index issue, I advanced another 4-6 teeth or so till the codes came back and then I split the difference (went backwards 2-3 teeth) so I was right in the sweet spot. With the passenger blend door full closed (rotated counter clockwise) below is what my blue gear position looks like. The blend door I am referring to is the door that the actuator opens and closes. You can open and close this door by rotating the white shaft that the actuator attaches to when you install it in the car. This picture could very well be close to what you will need for the passenger side: Attachment 48153244 Note: Instead of the iterative approach above to align the blue gear, you can use an ohm meter (about 10 posts down in this thread: http://forums.corvetteforum.com/c5-t...post1577439590). I repeated the same iterative process for the drivers side and after another 4-5 iterations I had no codes at all for the HVAC. After finding the sweet spot just as I did with the drivers side, here is the final tooth position for the blue gear (with the blend door closed – clockwise since this is the drivers side): Attachment 48153245 Hope this helps someone. Reindexing the blue gear relative to the drive gear takes some patience - at least in my case since mine was so far off - but eventually the codes did go away. I would like to thank those who contributed to the other great write ups that helped me access and diagnose my (previously) broken actuators. :flag: |
Fantastic post and a fantastic job. I am going to put this in my "Post that must be saved" file for sure!!
Great job!:flag::thumbs: |
Originally Posted by Bill Curlee
(Post 1576657600)
Great job!:flag::thumbs: :iagree: Saving this thread for future use in case I end up with this problem. Thanks for taking the time to post this. :cheers: |
With the actuator plugged in but not installed, i can adjust the hvac controls and the motor does not move. Im guessing indexing wont solve this problem and that either the motor or the circuitry is dead correct?
My actuator would always try to rotate, even when it was throwing the codes. Yours does nothing even when you reset the codes?
Neat. Mine did that too (split the main gear). I just bought a replacement one, but what's not to say it won't happen again...
Those actuators list for near three hundred dollars at a chevy dealer!!!!!!
Originally Posted by kh400
(Post 1576694120)
FANTASTIC POST!!! Thank you SO much for compiling this all in one thread
Do you still have no codes using this fix?
Thanks, Donnie |
Excellent info for those who are fighting these nagging actuator issues. I'm updating my thread from several years ago with your link. I'm sure others will find it useful. Here's hoping I don't have to start a similar thread on my C6 in the C6 forums! :willy:
Originally Posted by 00Corvette
(Post 1576752544)
Thanks, Donnie |
Great post
copied it to my "how to" folder following is not exactly on subject but may be related don't know if the following applies to corvettes, but on my 2004 Silverado I changed the battery and upon starting the truck had heat and no A/C talked to dealer service dept and they asked if I had turned the HVAC system to OFF before disconnecting the battery I didn't and he said that caused the control module to lose memory and it had to be reset with their Tech 2 tool $100 later it was good again from now on I'll turn HVAC off in all GM cars when disconnecting the battery |
Originally Posted by NealB
(Post 1577358615)
Great post
The codes B0365 and B0367 correspond to "right actuator feedback short to ground" and "right actuator feedback open." I'm surprised a broken gear would cause codes indicating electrical problems like this.
I have the same codes and if the ignition is on I can hear the actuator grinding and whimpering in there non-stop. I will be checking the gears and trying your fix before spending $300. I just don't understand why the broken gear would throw those codes. |
Originally Posted by bluemaggot
(Post 1577717877)
I see. Good stuff Lucky.
HVAC Passenger side always hot
I pulled the passenger actuator appart expecting to see broken gears but found all to be like new so I disconnected the motor from the circuit board and connected it to a 9V battery and it worked fine. Next I tested the potentiometer 8,000 Ohms between pins 7 and 10 on the board and variabe resistance between 9 and 7 or 10 as expected. I put the driver side actuator on the passenger side and it worked so I pulled it apart and found it to be like new as well. I checked all the resistors, capacitors and the diode on the board and compared the values to the bad one and they were all the same. The only thing left is the IC OP Amp L2722 $1.33 from Newark or Digikey. I'll post when I get a new one installed, anyone else had this problem?
I replaced the Op Amp yesterday and now the actuator works, I guess just dissassembling and reassemlbing the unit could have fixed it but for $1.33 why not try it.:cool:
Originally Posted by ls1k5
(Post 1577781173)
