Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-30-2011, 02:04 PM   #1
cjcvette
CF Senior Member
cjcvette's Avatar
Default How to fix / repair HVAC climate actuators
After replacing my battery I started to have HVAC codes show up:
B0361 H
BO363 H
BO365 H
BO367 H
B0441 H C
B0446 H C
Some codes were marked H (history) but after resetting the codes they immediately come back.
Here are the symptoms I observed (These might help those who are trying to diagnose their problems):
  • After resetting the codes both the passenger and drivers side would default to full hot. The passenger side is unresponsive to any input on the temperature ****. The drivers side is also unresponsive to input on the temperature **** and stays full hot - until I get down to 60 then it switches to full cold and if I increase the temperature setting back up it stays full cold. Meanwhile the passenger side is still full hot.
  • As I decrease the temperature setting on the drivers side I can hear noises inside the dash - a plasticy clicking sound, even though the temperature remains the same coming out of the vents. The mode settings all work fine - I can select between upper, lower, defrost without issue – so I assume it is not an issue with the vacuum connection. After removing the drivers kickpanel I can just see the output shaft from the actuator. I put the key in and turn to ON. The fan is on and set to the lowest setting. I clear the HVAC codes and I observe the following:
  • First the actuator rotates clockwise roughly 90 degrees at a pretty fast rate - takes ~5 sec. It pauses breifly and then starts to step back counter clockwise rotating ~45 degrees in short bursts. This takes about 12 sec. Lastly it finishes the last 45 degrees counter clockwise at the same speed as when it moved clockwise. After all of this the same 6 HVAC codes have returned.
At this point Bill Curlee has given me feedback and thinks the actuator has broken teeth. The other possible issue is that the actuator needs to be reindexed. Thankfully this is the corvette forum and there is a wealth of information. I used the following up to this point in order to gain visual access to the drivers side actuator. This link also has a great report on how to reindex the drivers side actuator which I use later on.
Removing and reindexing drivers side actuator through drivers side kickpanel:
http://forums.corvetteforum.com/c5-t...actuators.html
Since I had issues with both drivers and passengers actuators I would need to remove the dash (only way to get to the passenger side actuator) and it would prove essential when attempting to repair the actuators since you need easy repeated access.
Here is the link to remove the dash:
http://forums.corvetteforum.com/c5-t...d-install.html
And how to access the passenger side actuator:
http://forums.corvetteforum.com/1557915431-post68.html
Finally I remove the drivers and passengers actuators, open them up and see:
Click the image to open in full size.
Both have a cracked drive gears. In fact they were broken in the exact same fashion – one crack split wide open and one smaller crack. At this point my car is in pieces and I need two new actuators ($100+ each).
I decided instead of buying and waiting for new actuators to arrive, to repair the cracked actuators. It appears they broke due to a manufacturing defect (clearly the hole in the middle of the plastic gear that was pressed onto the metal output shaft is too small of a diameter – by a significant amount – and therefore eventually cracked). It is possible that the new ones would have the same issue. Therefore, I found the best solution was to fix the broken gear with a little epoxy.
The first step is to mark the position of the blue gear where it contacts the drive gear. It is also important to mark the corresponding position on the metal shaft. I also found it necessary to mark the outside of the case since cleaning the plastic drive gear and output shaft prior to epoxy could remove the marks I made:
If you mess up the marks it isn’t a huge deal since you will have to reindex anyway, but it could help you reindex quicker.
After removing the driver gear the first step is to slide the plastic gear off of the metal output shaft. In order to increase the inner diameter I rolled some sandpaper onto a pen and then rolled the gear on my palm. This ensures that the inner diameter is uniformly sanded.
I used 100 grit sandpaper since it cuts pretty fast and keeps the surface rough which is important for epoxy adhesion. After several test fits, I got it down to a diameter that snugly fit over the metal output shaft and the large crack was completely closed.
I cleaned both the inner diameter and the metal shaft with brake cleaner (any non residue cleaner would work as well), and mixed up some 5 minute epoxy. I applied the epoxy to the metal shaft (and used a toothpick to stuff some into the crack of the white drive gear) and then slid the gear back on while splitting the crack slightly open to avoid rubbing the epoxy off the output shaft. A spring clamp was used to hold the crack shut and keep the gear tight on the output shaft:
After letting the parts dry while I took a break, I put them back in the actuators and aligned them the best I could with the marks that I made. During the reassembly I also lightly coated the drive gear with some of the excess grease slung around inside the case. Don’t use too much or you might foul the sensor under the blue gear and have to clean it later:
http://forums.corvetteforum.com/c5-t...-indexing.html
Now comes the tricky part. I put both back in the car (I only attached them with one screw since I needed to test them). Reconnected the battery, turned the key to ON, and .... nothing had changed. I still got the same exact 6 codes listed at the beginning of this saga. Not to worry though. In retrospect this isn’t unexpected since with the drive gear cracked, the blue (index) gear had moved several teeth out of position after a couple weeks of driving with this issue. So, I disconnected the battery, pulled the passenger side actuator (easier to get to) opened it up and pulled the drive gear and moved it two teeth relative to the blue gear. If you have questions about this look at the link given above that addresses how to reindex. Reassembled, and … I still got the same 6 codes. I repeated this process 4-5 times until all of the passenger side codes went away (3 driver side remained). Success! Now in order to make sure I wasn’t operating on the edge of an index issue, I advanced another 4-6 teeth or so till the codes came back and then I split the difference (went backwards 2-3 teeth) so I was right in the sweet spot. With the passenger blend door full closed (rotated counter clockwise) below is what my blue gear position looks like. The blend door I am referring to is the door that the actuator opens and closes. You can open and close this door by rotating the white shaft that the actuator attaches to when you install it in the car. This picture could very well be close to what you will need for the passenger side:
Note: Instead of the iterative approach above to align the blue gear, you can use an ohm meter (about 10 posts down in this thread: http://forums.corvetteforum.com/c5-t...post1577439590).
I repeated the same iterative process for the drivers side and after another 4-5 iterations I had no codes at all for the HVAC. After finding the sweet spot just as I did with the drivers side, here is the final tooth position for the blue gear (with the blend door closed – clockwise since this is the drivers side):
Hope this helps someone. Reindexing the blue gear relative to the drive gear takes some patience - at least in my case since mine was so far off - but eventually the codes did go away.
I would like to thank those who contributed to the other great write ups that helped me access and diagnose my (previously) broken actuators.
cjcvette is offline   Reply With Quote
Old 01-30-2011, 05:42 PM   #2
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Fantastic post and a fantastic job. I am going to put this in my "Post that must be saved" file for sure!!
Great job!
Bill Curlee is offline   Reply With Quote
Old 01-30-2011, 08:20 PM   #3
rpm462
CF Senior Member
rpm462's Avatar
Quote:
Great job!
Saving this thread for future use in case I end up with this problem. Thanks for taking the time to post this.
rpm462 is online now   Reply With Quote
Old 01-30-2011, 09:41 PM   #4
Kotlas
CF Senior Member
Kotlas's Avatar
With the actuator plugged in but not installed, i can adjust the hvac controls and the motor does not move. Im guessing indexing wont solve this problem and that either the motor or the circuitry is dead correct?
Kotlas is offline   Reply With Quote
Old 01-31-2011, 08:02 PM   #5
cjcvette
CF Senior Member
cjcvette's Avatar
My actuator would always try to rotate, even when it was throwing the codes. Yours does nothing even when you reset the codes?
Old 02-01-2011, 12:59 AM   #6
ericdwong
CF Senior Member
ericdwong's Avatar
Neat. Mine did that too (split the main gear). I just bought a replacement one, but what's not to say it won't happen again...
ericdwong is offline   Reply With Quote
Old 02-03-2011, 02:23 PM   #7
kh400
CF Senior Member
Those actuators list for near three hundred dollars at a chevy dealer!!!!!!
kh400 is offline   Reply With Quote
Old 02-03-2011, 09:57 PM   #8
cjcvette
CF Senior Member
cjcvette's Avatar
Quote:
Yeah. As long as the teeth aren't broken off you might as well just fix the cracked gear.
Old 02-04-2011, 01:49 AM   #9
00Corvette
CF Senior Member
00Corvette's Avatar
FANTASTIC POST!!! Thank you SO much for compiling this all in one thread
00Corvette is offline   Reply With Quote
Old 02-10-2011, 02:15 AM   #10
00Corvette
CF Senior Member
00Corvette's Avatar
Do you still have no codes using this fix?
Thanks,
Donnie
Old 02-14-2011, 07:15 PM   #11
JR_VETTE
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Excellent info for those who are fighting these nagging actuator issues. I'm updating my thread from several years ago with your link. I'm sure others will find it useful. Here's hoping I don't have to start a similar thread on my C6 in the C6 forums!
JR_VETTE is offline   Reply With Quote
Old 04-16-2011, 10:32 AM   #12
cjcvette
CF Senior Member
cjcvette's Avatar
Quote:
Thanks,
Donnie
No codes. Everything still works great!
Old 04-16-2011, 01:01 PM   #13
NealB
CF Senior Member
NealB's Avatar
Great post
copied it to my "how to" folder
following is not exactly on subject but may be related
don't know if the following applies to corvettes, but on my 2004 Silverado I changed the battery and upon starting the truck had heat and no A/C
talked to dealer service dept and they asked if I had turned the HVAC system to OFF before disconnecting the battery
I didn't and he said that caused the control module to lose memory and it had to be reset with their Tech 2 tool
$100 later it was good again
from now on I'll turn HVAC off in all GM cars when disconnecting the battery
NealB is offline   Reply With Quote
Old 04-16-2011, 04:29 PM   #14
00Corvette
CF Senior Member
00Corvette's Avatar
Quote:
Originally Posted by NealB View Post
Great post
With a C5, you can reset the AC by pulling fuse number 27 in the footwell fuse box or just resetting it through the DIC
Old 05-26-2011, 03:03 PM   #15
bluemaggot
CF Member
The codes B0365 and B0367 correspond to "right actuator feedback short to ground" and "right actuator feedback open." I'm surprised a broken gear would cause codes indicating electrical problems like this.
I have the same codes and if the ignition is on I can hear the actuator grinding and whimpering in there non-stop. I will be checking the gears and trying your fix before spending $300. I just don't understand why the broken gear would throw those codes.
bluemaggot is offline   Reply With Quote
Old 05-26-2011, 03:13 PM   #16
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
The feedback circuit provides a output signal (basically controls the resistance to ground, given a 5 volt position signal voltage). The control head is expecting a voltage(within a range) based on the actuator position. If the gear is broken, and position drives full scale(allowing the resistance to drop to zero)..the control head sees that as a short to ground.
lucky131969 is offline   Reply With Quote
Old 05-26-2011, 10:10 PM   #17
bluemaggot
CF Member
I see. Good stuff Lucky.
Old 05-29-2011, 07:33 PM   #18
ls1k5
Junior Member
ls1k5's Avatar
Default HVAC Passenger side always hot
I pulled the passenger actuator appart expecting to see broken gears but found all to be like new so I disconnected the motor from the circuit board and connected it to a 9V battery and it worked fine. Next I tested the potentiometer 8,000 Ohms between pins 7 and 10 on the board and variabe resistance between 9 and 7 or 10 as expected. I put the driver side actuator on the passenger side and it worked so I pulled it apart and found it to be like new as well. I checked all the resistors, capacitors and the diode on the board and compared the values to the bad one and they were all the same. The only thing left is the IC OP Amp L2722 $1.33 from Newark or Digikey. I'll post when I get a new one installed, anyone else had this problem?
ls1k5 is offline   Reply With Quote
Old 06-03-2011, 10:16 AM   #19
ls1k5
Junior Member
ls1k5's Avatar
I replaced the Op Amp yesterday and now the actuator works, I guess just dissassembling and reassemlbing the unit could have fixed it but for $1.33 why not try it.
Old 06-03-2011, 06:03 PM   #20
cjcvette
CF Senior Member
cjcvette's Avatar
Quote:
Great fix. Is there a good way to find out if the Op Amp is bad?
Reload this Page How to fix / repair HVAC climate actuators
Tags
actuator, b0446, blend, c3, c5, code, corvette, door, fix, gear, hc, hvac, motor, remove, repair
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
