it doesnt take 2000whp to run 8's...with the right setup and putting the power to the ground, 800whp will go 8's.
Originally Posted by Frans96ss
(Post 1576091869)
Why dont you stop talking **** and worry about your own car.
to 8's with a converter change, that car is a heavy bitch over 3700lbs, not talking sh t you said it will go 8's i'm willing to bet it will not, would you care to put a wager on it? |
Originally Posted by m R g S r
(Post 1576092287)
Somebody in hear has been drinking the haterade.:D
Originally Posted by rattt g
(Post 1576092435)
@over 3700lbs it's going to be tuff to go 8's with 800rwhp
Why dont you g online and do the calculator on how much power it takes to get a 3770 lb car to go 147 MPH.... its a bit more than 800. |
(Post 1576093580)
(Post 1576094318)
so what is the max hp those 62mm turbo's can support
Precision Turbo HP Technology Series Turbo - 62mm Billet Compressor Wheel, 65mm Turbine Wheel: 400-6265 Model: 6265S Bearing Type: HP Technology HP: 680-hp USP MotorSports presents Billet Wheel Precision Turbo Specials! All of these Precision HP technology/Ball Bearing turbos come standard with PTE Billet Compressor Wheel technology. This allows for faster spool up, wider powerband, and more horsepower overall compared to standard Garrett GT ball bearing turbos. These turbos are rated way below their maximum output, as we were able to extract 780awhp out of a 62/62 which is only rated to 670chp Look how this thing leaves and you tell me the converter isnt terrible in it. http://www.youtube.com/user/Frans96ss?feature=mhum |
(Post 1576094849)
(Post 1576095164)
it did leave like a pig, but 9.66 to 8.90 is a world away, and from what i heard the boost is maxed out on it, 18psi on the stock heads is a lot
(Post 1576095259)
It went 9.47 the next pass leaving the same way. It didnt push an ounce of water with the tune that was in it. We can prob get it to go 9.2 with the converter thats in it now but dont wanna waste our time.
Other twin turbo c6s?
Originally Posted by ghostmech
(Post 1576082690)
Where did you get that gauge pod for the center console?
:thumbs:
Originally Posted by 07MontRedcp
(Post 1576084239)
:bigears
BJK http://i46.tinypic.com/fxcoc9.jpg http://i47.tinypic.com/14ccep3.jpg |
(Post 1576095164)
(Post 1576105490)
Thats also leaving off 18psi on the trans brake. It should be able to leave harder than that on 8psi. The converter is WAYYYY too tight.
(Post 1576105533)
not if it was making 1000rwhp:eek:
(Post 1576106059)
From the mph calculator to weight its making in between 950-1k
.5 second is a lot...goodluck :thumbs: |
Originally Posted by Quiky One
(Post 1576106561)
What did it make on the dyno?
(Post 1576106561)
(Post 1576094849)
(Post 1576093580)
and thats about rite for 800 rwhp,check this site out for yourself http://www.dragtimes.com/horsepower-...calculator.php |
