How many twin turbo c6s are here?
I make a research about how many twin turbo c6s are here.
And asking for help from the owners of twin turbo c6s please come in and tell about your cars spec and share videos i am not searching the fastest or most powerfull c6 i only wonder how many so does not matter bolt on or fully built thanks Halil |
Race Proven Motorsports Fully Built ttix, 880 rwhp 880rwtq on pump gas and meth @ 16 psi
pics: http://i262.photobucket.com/albums/i...e/689fe4f9.jpg http://i262.photobucket.com/albums/i...dandZ06009.jpg http://i262.photobucket.com/albums/i...dandZ06012.jpg video: http://i262.photobucket.com/albums/i...esounds019.jpg http://i262.photobucket.com/albums/i...esounds020.jpg |
How mpg city?
Thanks jrubicon
cool car and cool info and you are from charlott nc right? |
My newest TT build by Late Model Racecraft is a rear mounted billet 82mm setup with air to water intercoolers. Car has made over 1300rwhp on 93 octane with meth at 16-18psi. Planning on turning the boost up to 30psi with Q16 which should get me in the 1700-1800rwhp range.
Heres a few pics: http://i300.photobucket.com/albums/n...20Pics/rc3.jpg http://i300.photobucket.com/albums/n...20Pics/rc4.jpg http://i300.photobucket.com/albums/n...20Pics/rc5.jpg http://i300.photobucket.com/albums/n...20Pics/rc9.jpg http://i300.photobucket.com/albums/n...0Pics/rc17.jpg |
I like the TurboWerx pump. I'm almost finished with the conversion from the Weldon 9200A that was part of my APS TT. I am not using the heat sink due to space considerations. BJK |
Are there any Lingenfelter twin turbos on the forum?
I'll be adding the TTi Stage X kit this winter.
Originally Posted by Fredro Starr
(Post 1576078308)
LPE TT 427ci 8.7:1 LS7 LS2 heads / LS2 intake / ZR1 Cam Stock cats / no meth / MAF tune 600hp/650tq @ 10psi on California 91 octane 755hp/845tq @ 15psi on VP100 octane |
I got RC's old APS modified turbo kit . Billet wheel 62's. 840 rwhp @ 14 psi. All work was done by Vengeance Racing.
A.P.S kit going on started today. Just stock motor for now LS9X clutch.
It seems like we are building one at all times. Here is 2 we just finished.
http://i121.photobucket.com/albums/o...2/IMG_6971.jpg http://i121.photobucket.com/albums/o...2/IMG_6973.jpg http://i121.photobucket.com/albums/o...2/IMG_6980.jpg http://i121.photobucket.com/albums/o...2/IMG_6979.jpg http://i121.photobucket.com/albums/o...2/IMG_6978.jpg This car has bee 9.49 at 147 so far. We are changing the converter now bc its REALLY slowing the car down. Car will go 8's once we turn it up some more. Here is another we just finished. This is a 6 speed version of the car above. http://i121.photobucket.com/albums/o...2/IMG_6958.jpg http://i121.photobucket.com/albums/o...2/IMG_6954.jpg http://i121.photobucket.com/albums/o...2/IMG_6963.jpg http://i121.photobucket.com/albums/o...2/IMG_6949.jpg |
Originally Posted by Frans96ss
(Post 1576082220)
Here is another we just finished. This is a 6 speed version of the car above. http://i121.photobucket.com/albums/o...2/IMG_6954.jpg Where did you get that gauge pod for the center console? :thumbs: |
Originally Posted by ghostmech
(Post 1576082690)
:thumbs: BJK |
The black Z06 Fran posted above happens to be mine. It’s a 9.0:1 comp. 434 fed by a TTIX 6265 kit. At the present time, set at the lowest boost setting of roughly 8.5lb and no meth it makes 653rwhp/583rwt. Race Proven did a first class job putting that build together for me. I am still amazed at how civil the car drives considering the power it is currently putting down, let alone the power it's going to put down when we turn the boost up.
As for the center console, as the car build took place I had Dennis from Double D-Mods modify my stock console to accommodate the gauges as you see in the picture. Reach out to Dennis if you are considering this option, he does great work. |
How fare or much boost/power can I push the stock short block I've seen some making 700plus with the stock motor. A.P.S just pushed it to 625rwh on there website. Will meth injection help? Thanks
:seeya
(Post 1576082220)
http://i121.photobucket.com/albums/o...2/IMG_6971.jpg http://i121.photobucket.com/albums/o...2/IMG_6973.jpg http://i121.photobucket.com/albums/o...2/IMG_6980.jpg http://i121.photobucket.com/albums/o...2/IMG_6979.jpg http://i121.photobucket.com/albums/o...2/IMG_6978.jpg This car has bee 9.49 at 147 so far. We are changing the converter now bc its REALLY slowing the car down. Car will go 8's once we turn it up some more. Here is another we just finished. This is a 6 speed version of the car above. http://i121.photobucket.com/albums/o...2/IMG_6958.jpg http://i121.photobucket.com/albums/o...2/IMG_6954.jpg http://i121.photobucket.com/albums/o...2/IMG_6963.jpg http://i121.photobucket.com/albums/o...2/IMG_6949.jpg turbo's on there, and i do not think you have any room to turn it up 17lbs of boost on the stock heads, good luck on turning it up from there |
Originally Posted by rattt g
(Post 1576090236)
i would be willing to bet that yellow car never see's the 8's with those turbo's on there
(Post 1576090236)
turbo's on there, and i do not think you have any room to turn it up 17lbs of boost on the stock heads, good luck on turning it up from there Why dont you stop talking **** and worry about your own car. |
