How to remove/replace 86 Low Coolant Sensor?
Stock 1986 Corvette Coupe: My radiator is confirmed absolutely full but the "coolant low" light comes on intermittently, around every 10-15 mins. I found this thread which helped clean the sensor connector:
http://forums.corvetteforum.com/c4-t...-light-on.html But if the light persists how do I remove the sensor from the radiator to clean it and put it back? I tried to give it a twist but it only moved a millimeter or two, is there a specific technique required? Will coolant come flowing out if/when I am able to remove it? Any help/advice would be appreciated, bossfan |
You need to burp your radiator. You have trapped air pockets in your cooling system.
I use my ramps and put the front of the vette on the ramps. This makes my radiator a higher water level. With car at 180 degrees, I give it gas to about 1500 rpm's with the cap off. I fill the radiator then. Before letting rpm's drop put cap back on. |
Originally Posted by bossfan
(Post 1576052426)
http://forums.corvetteforum.com/c4-t...-light-on.html But if the light persists how do I remove the sensor from the radiator to clean it and put it back? I tried to give it a twist but it only moved a millimeter or two, is there a specific technique required? Will coolant come flowing out if/when I am able to remove it? Any help/advice would be appreciated, bossfan Forget about cleaning it, and replace it. |
2 Attachment(s)
(Post 1576052426)
http://forums.corvetteforum.com/c4-t...-light-on.html But if the light persists how do I remove the sensor from the radiator to clean it and put it back? I tried to give it a twist but it only moved a millimeter or two, is there a specific technique required? Will coolant come flowing out if/when I am able to remove it? Any help/advice would be appreciated, bossfan http://www.ecklers.com/corvette-low-...1984-1989.html Finally, you need to burp your cooling system to purge the trapped air out from under the thermostat. See attached write-up. :cheers: |
That explains it perfectly, thanks. Mine has a black zip-tie covering the claw section so I couldn't see they were claws.
Thanks again, bossfan |
