Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-27-2010, 09:42 PM   #1
bossfan
Junior Member
Default How to remove/replace 86 Low Coolant Sensor?
Stock 1986 Corvette Coupe: My radiator is confirmed absolutely full but the "coolant low" light comes on intermittently, around every 10-15 mins. I found this thread which helped clean the sensor connector:
http://forums.corvetteforum.com/c4-t...-light-on.html
But if the light persists how do I remove the sensor from the radiator to clean it and put it back? I tried to give it a twist but it only moved a millimeter or two, is there a specific technique required? Will coolant come flowing out if/when I am able to remove it?
Any help/advice would be appreciated,
bossfan
bossfan is offline   Reply With Quote
Old 11-27-2010, 09:48 PM   #2
CorvetteMike2004
CF Senior Member
Support Corvetteforum!
CorvetteMike2004's Avatar
You need to burp your radiator. You have trapped air pockets in your cooling system.
I use my ramps and put the front of the vette on the ramps. This makes my radiator a higher water level. With car at 180 degrees, I give it gas to about 1500 rpm's with the cap off. I fill the radiator then. Before letting rpm's drop put cap back on.
CorvetteMike2004 is offline   Reply With Quote
Old 11-27-2010, 10:45 PM   #3
Pete K
CF Senior Member
Pete K's Avatar
bossfan
After 25 years, you can expect it to snap like a twig when you remove it.
Forget about cleaning it, and replace it.
Pete K is offline   Reply With Quote
Old 11-28-2010, 06:00 AM   #4
pmihaltian
CF Senior Member
pmihaltian's Avatar
Send a message via AIM to pmihaltian
bossfan
You simply pry open the side claws and it pops right out. Put some petroleum jelly on the o-ring and pop the new one back in. Do it quickly as when you pull it out anti-freeze will run everywhere if you don't plug the hole or reinstall the sensor quickly.
http://www.ecklers.com/corvette-low-...1984-1989.html
Finally, you need to burp your cooling system to purge the trapped air out from under the thermostat. See attached write-up.
File Type: pdf Corvette L98 Radiator Burp Procedure.pdf (72.8 KB, 223 views)
pmihaltian is offline   Reply With Quote
Old 11-28-2010, 10:04 AM   #5
bossfan
Junior Member
That explains it perfectly, thanks. Mine has a black zip-tie covering the claw section so I couldn't see they were claws.
Thanks again,
bossfan
Reload this Page How to remove/replace 86 Low Coolant Sensor?
Tags
1984, 1986, 1989, 86, c4, coolant, coolent, corvette, level, location, low, radiator, remove, replace, sensor, sensors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
