What are some stock 2008 LS3 1/4 mile times?
I have a 6 speed. Average times. Which ones are faster 6 speed or auto paddle shift?
BTW, they're all 6 speed.
Showroom Stock LS3 (2008 - ????) 11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590) 11.80 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3482) 12.10 @ 117.60 - Dingrao - 08 A6 - (3567) 12.10 @ 115.19 - Odin - 09 A6 2.73 npp - (4329) 12.12 @ 116.59 - Pettvette - 08 A6 - (4282) 12.15 @ 115.59 - Old Goat - 09 A6 2.73 - (3712) 12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744) 12.18 @ 117.72 - Hardhattg - 08 M6 Z51 - (2690) 12.23 @ 112.86 - 940CACC - 08 A6 - (2880) 12.26 @ 115.22 - Oklahoma - 08 A6 - (3767) 12.27 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3251) 12.35 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2759) 12.35 @ 116.67 - TNorman - 08 A6 NPP - (4231) 12.40 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2138) 12.41 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3190) 12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486) 12.42 @ 116.67 - pea jay - 08 A6 - (4453) 12.49 @ 115.54 - 1.8T - 08 M6 Z51 - (2314) 12.55 @ 114.70 - Larry R - 08 A6 2.73 - (4058) 12.60 @ 114.12 - Beefcake - 08 A6 - (2882) 12.65 @ 114.99 - PhillyLS1 - 09 M6 - (3156) 12.66 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2834) 13.35 @ 110.78 - M453W - 09 A6 NPP- (4061) 13.42 @ 109.32 - Dan Wendling - 09 A6 NPP - (4036) |
With my stock 08 A6 & 2.56 gears ... In the heat I run 12.4-12.5's.. In decent weather 12.2-12.3's.... In good weather 12.1's... Haven't made any passes in really great weather conditions...MPH ranges from 114 in the heat to almost 118 in better weather...
Originally Posted by corvet786c
(Post 1574985838)
is faster. Auto's on the other hand come out of the hole better with their ability to lay the power off the line. Some people can't drive a stick. So results vary! |
2008 Z51 MN6 NPP -My bone stock best was a 13.0 @ ~115mph IIRC
Getting a good launch with runflats is difficult :thumbs: |
Originally Posted by ///DarkSide\\\
(Post 1574989689)
I just bought a stock LS3 with 28,000 miles. I ran an 11.89 (118 mph) this morning. I adhered to the great advice of Ranger (Rangeracceleration.com) and was quite pleased as this was my second 1/4 mile run ever. I did have Mickey Thompson drag radials my buddy lent me.
I'd like to see full mile times........ ;)
Originally Posted by SilverC6
(Post 1579506424)
I'm certain that I couldn't run that time with my stock run-flats. I had a super lucky day: good tires, good weather, good track temp, good advice. The times listed above are with stock tires right?
(Post 1579506610)
Here's the update list and actual thread - https://www.corvetteforum.com/c6-tech-performance-101/showthread.php?t=1893326 |
Originally Posted by CDaniel525
(Post 1579506660)
Ya, in those class rules you need stock runflats... I hit a 12.24@117 after this thread was originally posted..
Here's the update list and actual thread - https://www.corvetteforum.com/c6-tec....php?t=1893326 http://forums.corvetteforum.com/1552486175-post4.html It's a link to the post of the times and trap speeds (see below). Showroom Stock LS3 (2008 - ????) 11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586) 11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478) 11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652) 12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051) 12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325) 12.102 @ 117.60 - Dingrao - 08 A6 - (3561) 12.127 @ 116.59 - Pettvette - 08 A6 - (4278) 12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708) 12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740) 12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686) 12.237 @ 112.86 - 940CACC - 08 A6 - (2871) 12.244 @ 117.83 - 74Vette - 08 M6 - (4617) |
Slow
I feel slow but any way here are mine.
2008 LS3 with Varram, A6, stock Goodyear runflats, Mar evening outside temp about 80 degrees. 12.863 at 113.26 |
Good post BTW !
Mine is a stock 2008 LS3 with NPP. best time is 12.8 at 115 MPH. My problem is ( probably like everybody else) the first 60'......i'm soooo slow of getting out the box.... I'm shopping for some mags and tires i could swap befor going to the track.... |
Bone-stock '08 coupe, A6, NPP, 2.73 gears at Englishtown last July- 12.74 @113.5. Hot, sunny day, temps in low 90's.
Bone stock '08, NPP, Z51 (2.73 rear), A6, in drive (no paddle shifting), 80*F August day, 93 octane gas, only run the car has ever seen:
12.6 @ 114 mph Edit: It's interesting to read about people having issue with hooking up. I never even got a tire chirp from a dead stop to full throttle. Ran 1/4 mile with all nannnys "on". |
I ran our 09 stock and with 325s out back, stock tires my best times were 12.8 at 113 and with the 325s 12.5 at 115. What I find hard to do is to get a good launch with the stock converter, seems above 2k the Vette wants to move with the foot brake on. I can not get the 60 times under 2 seconds, I was able to do better in my stock MN6 99 C5 in the 60 times 1.8, though my times were never 12.5, best stock was 12.7 at 114.
Originally Posted by wolfdogs
(Post 1579506442)
Limiting the Corvette to 1/4 mile is like shooting a .308 sniper rifle at the local pistol range, or running an offshore sport racing boat on your local lake. Plus, you will invariably find yourself in the company of camaros and the toyota-supra-dragon-nos-NAWS crowd. :hide: |
(Post 1579506442)
They'd be mid/hi-150s for bone stock cars. Seen a lot of them run. |
Originally Posted by Rock'n Blue 08
(Post 1574988475)
Less power loss to the ground with manual. Side by side rolling the manual
is faster. Auto's on the other hand come out of the hole better with their ability to lay the power off the line. Some people can't drive a stick. So results vary! The previous chart has 24 listings, of which 6 are M6 and 18 are A6. A6 is quicker mostly in drag racing. |
