Pop up headlight Problem
Last fall, my headlight motor sounded like a meat grinder - but the lights did not pop up. I installed the brass gear - I've had nothing but problems with that "fix" - the lights would wind down so tight they would not pop up. The only way to get them to work was to manually loosen them, and then the lights would work for one or two times. I'm still working on getting that fixed. I have the ACA HID lights, and yes, they are installed properly.
Now, (when the lights pop up/down), both sides would pop up, then the drivers side goes down, click the switch OFF, the passenger side goes down, then the driver's side opens. I know the lights are connected the proper way from last fall, so there is nothing connected "backwards". Anybody have any ideas? Thanx in advance.... D. |
sounds like your popup motor housings are coming apart.
Will I be able to tell by looking at them? If the motor housings are coming apart - does that mean I need to spend $$ to buy the new headlight motors?
they're kinda hard to tell unless you pull them out.
you don't need new ones, just secure them with a dickman clamp or DIY with small screws. |
I'll take them out in a few days when I get back home. Thanx
D. |
1 Attachment(s)
It could be a number of things but a cheap and easy one to start with if you've already replaced the gears is this one:
Number: 00-08-42-002 Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators) Model Year: 2000 Chevrolet Corvette Condition Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly. Correction Important The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator. Attachment 48155705 Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual. Parts Information Part Number Description Qty Per Vehicle 11505463 Washer 3 16524060 Insulator 2 |
Thanx for the diagram! I'll see if I can get the parts. Hope it works.
D. |
The washers are $9.15 EACH plus tax.
The insulators are DISCONTINUED. Any more ideas? |
Originally Posted by Low Ufo
(Post 1573769362)
they're just washers. 20 for a dollar at home depot. check that your motors are not coming apart for free first. |
Originally Posted by jdmvette
(Post 1573771098)
:rofl:
they're just washers. 20 for a dollar at home depot. check that your motors are not coming apart for free first. I'll have the Vette home next week and I'll take another look at the motors! |
The driver side motor epoxy job was starting to let go. I used a hose clamp to hold the motor together.... you don't even notice it! In addition, I added the washers.
So far..... no problems. |
Glad you got the problem resolved. I know I'm late but thought I would share this information in case it can help others. A friend had a similar problem and posted a detailed fix with pics.
Click here for the original thread.
Originally Posted by MikeC4
(Post 1567940200)
To Larry....... thanks again for posting a vid of my "winky".
To TheRadioFlyer.....Thanks for the disassembly procedure. I especially like the fact that I didn't have to remove the entire driver side Headlamp assembly to fix the 2 problems that where lurking beneath. 1) The plastic cover that is GLUED on over the nylon gear had popped off. This was a huge GM blunder when they changed from cast aluminum cover('97 to '99 models), which uses 3 screws to secure the cover, to a completely plastic housing for the motor/worm gear and nylon gear(2000 to 2004). The nylon gear will push against the cover, and it is only a matter of time before the pressure breaks the GLUE bond......and I don't care what kind of magic glue there is out there, it will not hold. 2) As per GM service bulletin, motor should be offset with washers so that the armature which raises and lowers the light makes better contact with the limiter tabs. There were enough customer complaints regarding faulty operation of the driver side Headlamp to issue this bulletin, and how to correct the problem. I took some pics and added notes on what I did to fix both of the above design flaws, as well as how to eliminate the need for GLUE for the motor housing cover. http://img383.imageshack.us/img383/7...ration2ii4.jpg http://img508.imageshack.us/img508/764/p2tabswapqy9.jpg http://img383.imageshack.us/img383/6...otorcappe5.jpg http://img521.imageshack.us/img521/2...rwraptisd8.jpg http://img508.imageshack.us/img508/6...fitmentta8.jpg http://img508.imageshack.us/img508/4...iefinalmi7.jpg http://img508.imageshack.us/img508/2...roffsetqa5.jpg http://img521.imageshack.us/img521/8...fsetquanz7.jpg Job Completed. Took me about 2 hours, but I move real slooooooooooooooooooow.........otherwise I get more "honey do's" when I go into the house !!! (-; Another benefit was that I could better align the body colored headlamp cover, as the folks at GM did a poor job on this as well. This adjustment is done by maneauvering the cover directly under the body panel to adjust/equalize the top/bottom/left/right gap clearance . http://img508.imageshack.us/img508/9...stalledrn8.jpg The following pic is out of sequence, but I did want to show the 2 critical pivot bolts that hold the light assembly to the..........car http://img266.imageshack.us/img266/5...otboltsmw4.jpg Below are the only tools required for this job: http://img529.imageshack.us/img529/6...ightfixcq6.jpg Take a look at the following picture. This is what you will never have to mess with again!!The "wrap tie" method will eliminate the need for GLUE, can be done without removal from car, and will surely last a very long time !! But if you like the GLUE method, here's a pic I found in the DIY section.... http://img383.imageshack.us/img383/8...man2008nq0.jpg |
That brass gear fix didn't work for my 97 Formula. I ended up with the same issues you're having. The headlight would go down and wind down too tight to reopen, and then finally the epoxy wore and the housing came apart.
The best fix, in my honest opinion, is getting another headlight motor unit. I'd try the above zip-tie trick first though. But that brass gear doesn't have enough give which is why it gets too tight. I can imagine using a resistor between the line would fix that but it'd slow the motor down a bit. |
pop up light thanks
Thank you for the pics and description of how to repair the one eyed popup headlight problem. I would not have tried it without the help.
I added two washers and I think three would be better. |
Pop up headlights
Looks like I am not the only one with this problem. I replaced my gears with the brass ones as well. Could never get the adjustment right as far as having these headlights pop up on their own. I usually wind up popping the hood and loosing the manual gear drive a bit to get both headlights to pop up. I don't seem to have more trouble with one side then the other for some reason. I also had my housing covers come off over time. I have tried some other epoxies as well. If it happens again I may try the cable tie method shown in photo graphic detail here.
Todd |
Originally Posted by tfrankmt
(Post 1580572067)
Todd So I got lucky. I can imagine that the nylon gears would be stripped before long. So where can I buy more nylon stops? |
Originally Posted by dutch911
(Post 1587776174)
It appears that there are three nylon "stops" that the headlight housing bumps as it goes up and down. Two on top and one below the gear housing. My driver's headlight would go up fine but going down it would make a terrible racket as it hit the closed position. Looking at the bottom white nylon stop, it was notched about 4mm at one point. I pulled it off and flipped it around and reconnected the power. Headlights go up and down with no complaints.
(Post 1587776396)
Dammit. Not-so-lucky. Now the headlight goes down with no problem or noise but doesn't go up with the switch action. Passenger side up and down no problem or noise. On the drivers side when the switch is activated, the manual control knob takes a brief slow turn about 1/4 rotation counter-clockwise (the direction you turn it if you want to raise the headlight). If I manually give it a little twist counter-clockwise before actuating the switch, it goes fine. The resistance is kinda snug for about a quarter turn then quite loose. If I turn it to the loose part, it will go up just fine with the switch. Perhaps I need to replace the stop as it is tightening the ....manual control?... too much when it puts the headlight down?
sounds like that nylon stop is shot; you can try 5/16" or 3/8" gas line cut to the size of the stop or slightly larger and try that in its place. I got some at a local auto store based on the advice on another related thread. It worked for me. Make sure both the stops on the mount for the headlight motor have this or good (new) nylon stops. Its not you, its just a crappy design. :cheers: |
:My pop up head light work fine except when I shut them off the pop up go down but then drive side pop up goes up I rebutted it but the same thing
