kick panel speakers in my 81
ok so i can find tons of stuff for kick panel speakers for the older C-3's. Anyone put speakers in the kick panel of an 81 82 ??
Many have. If you know about speaker mounting you will know what to do with what has been posted- most applies to yours too.
:cheers: |
I dont know about speaker mounting. Thats why im looking for some advice. the search tool on this site is king of tuff.
Kick location: 4X6 fit easily, maybe 5x7 & some 5 1/4 can be fitted.
A mounting plate must be used to make a "box" to separate the front from back sound waves to prevent cancellation for better bass. The speaker should be solidly mounted so that the movement of the speaker cone is translated into sound rather than any movement of the speaker. |
I put 6.5 in lower kick panels. My feet don't hit them but I did add a spacer. I want 6.5 for better bass response throught the car and not just from the subwoofer
http://i3.photobucket.com/albums/y70...edale/ds-1.jpg http://i3.photobucket.com/albums/y70...e/trans005.jpg |
Looks good!
:cheers: FYI There is not enough airspace behind to optimize 5.25. Tested 6.5 anyway & it wasn't better than 5.25. In doors, the 6.5 had better bass. |
http://i3.photobucket.com/albums/y70...e/trans005.jpg[/QUOTE]
Where can I pick up one of those invisible shifters:rofl: |
Originally Posted by turbojet
(Post 1573408966)
:rofl: Yes, this was a pic I took when I was changing from 4 speed to 5 speed. |
Originally Posted by Ganey
(Post 1573405604)
Looks good!
You need to cut a hole for the speaker used in something like MDF, plywood, metal etc. to make a mounting plate which should be used to make a "box" to separate the front from back sound waves to prevent cancellation for better bass.
vettfixr has a topic w/ pics. http://forums.corvetteforum.com/c3-t...-up-death.html |
Nice work Ganey !
Wow !
The inside looks very sharp :thumbs: Please post a picture of your baby. Tks S80 |
If you are talking about the topic link, that's Al vettfixer pics.
I have Kenwood eXcelon mask CD, 5.25 components hidden behind factory kick panels & amp. in back center compartment. http://ganeys.home.sprynet.com/K%20eXcelon.JPG Mask- face flips over to look like no radio. Removed the dash speakers & tested w/ DPDT switched dome tweeters which worked great or leave open w/o speakers. |
