kick panel speakers in my 81
Old 03-11-2010, 08:03 PM
riarms
riarms's Avatar
Default kick panel speakers in my 81
ok so i can find tons of stuff for kick panel speakers for the older C-3's. Anyone put speakers in the kick panel of an 81 82 ??
Old 03-11-2010, 08:56 PM
Ganey
Ganey's Avatar
Many have. If you know about speaker mounting you will know what to do with what has been posted- most applies to yours too.
Old 03-12-2010, 09:23 AM
riarms
riarms's Avatar
I dont know about speaker mounting. Thats why im looking for some advice. the search tool on this site is king of tuff.
Old 03-12-2010, 09:42 AM
Ganey
Ganey's Avatar
Kick location: 4X6 fit easily, maybe 5x7 & some 5 1/4 can be fitted.
A mounting plate must be used to make a "box" to separate the front from back sound waves to prevent cancellation for better bass.
The speaker should be solidly mounted so that the movement of the speaker cone is translated into sound rather than any movement of the speaker.
Old 03-13-2010, 09:17 AM
spedaleden
spedaleden's Avatar
I put 6.5 in lower kick panels. My feet don't hit them but I did add a spacer. I want 6.5 for better bass response throught the car and not just from the subwoofer
Old 03-13-2010, 09:48 AM
Ganey
Ganey's Avatar
Looks good!
FYI
There is not enough airspace behind to optimize 5.25. Tested 6.5 anyway & it wasn't better than 5.25.
In doors, the 6.5 had better bass.
Old 03-13-2010, 04:37 PM
turbojet
turbojet's Avatar
[/QUOTE]
Where can I pick up one of those invisible shifters
Old 03-14-2010, 10:15 AM
spedaleden
spedaleden's Avatar
Originally Posted by turbojet
Where can I pick up one of those invisible shifters[/QUOTE]
Yes, this was a pic I took when I was changing from 4 speed to 5 speed.
Old 03-15-2010, 10:05 AM
riarms
riarms's Avatar
Originally Posted by Ganey
Looks good!
FYI
Thanks for the help. I guess its not an easy thing to get those speakers in. Do you know of anyone that makes these mounting brackets or is that something that has to be done to the speaker used. I know different size would mean different bracket.
Old 03-15-2010, 10:42 AM
Ganey
Ganey's Avatar
You need to cut a hole for the speaker used in something like MDF, plywood, metal etc. to make a mounting plate which should be used to make a "box" to separate the front from back sound waves to prevent cancellation for better bass.
vettfixr has a topic w/ pics.
http://forums.corvetteforum.com/c3-t...-up-death.html
Old 03-15-2010, 12:00 PM
Spitfire80
Spitfire80's Avatar
Default Nice work Ganey !
Wow !
The inside looks very sharp
Please post a picture of your baby.
Tks
S80
Old 03-15-2010, 12:24 PM
Ganey
Ganey's Avatar
If you are talking about the topic link, that's Al vettfixer pics.
I have Kenwood eXcelon mask CD, 5.25 components hidden behind factory kick panels & amp. in back center compartment.
Mask- face flips over to look like no radio.
Removed the dash speakers & tested w/ DPDT switched dome tweeters which worked great or leave open w/o speakers.
To kick panel speakers in my 81
Quick Reply: kick panel speakers in my 81
