All broken down:
http://i54.photobucket.com/albums/g9...upsidedown.jpg Looks like it was burning some oil after all. Good shot of the tie-bar lifters. http://i54.photobucket.com/albums/g9...upheadsoff.jpg Pistons and rods out. http://i54.photobucket.com/albums/g9...ginewcrank.jpg You can see where all of the main caps were walking with stock bolts. For some reason I thought I had ARP mains. http://i54.photobucket.com/albums/g9...D/maincap1.jpg http://i54.photobucket.com/albums/g9...D/maincap2.jpg http://i54.photobucket.com/albums/g9...maincap3-1.jpg http://i54.photobucket.com/albums/g9...D/maincap4.jpg 16-18k on this LS2 chain. Being replaced with a Cloyes adjustable setup. http://i54.photobucket.com/albums/g9...mingchain1.jpg http://i54.photobucket.com/albums/g9...mingchain2.jpg Bare block ready for some serious machine work. http://i54.photobucket.com/albums/g9.../bareblock.jpg |
Nice work
Sweeeeeet :thumbs:
Nice. :cheers:
Question: I notice what appears to be an LS1 style knock sensor on the side of the block. Do you plan to change to the LS2 style when the engine is finished? I have heard (unconfirmed of course) that possibly some of the earlier LS1 KS's were not nearly as good as the later versions or the LS2 type. Other than the obvious design/mounting difference between the LS1 type and the LS2 type, do you know of any actual performance differences? A pro/cons on this? |
Originally Posted by LoneStarFRC
(Post 1572749604)
Nice. :cheers:
I just heard from Shawn.....
Sleeves going it today. :party::party: |
Jeez these guys are moving fast.
Originally Posted by ajg1915
(Post 1572751284)
I'm certainly no expert at inspecting engine mains......how can you determine by the appearance of the cap that it was walking?
Wow, I chimed in late as hell on this one. I've been out of town going on 2 weeks now. Still gone but just now getting on the forum.
Kevin! I am proud! You'd better take me for a ride in that beast when you get her back :) I didn't read through the thread, just looked at the pictures.. when do you plan on having it back? |
Wow, pretty interesting shots of the main caps moving on you, thanks for posting.
Were you the guy at ECS getting your coil overs put on while I was having my black vert street tuned? |
Originally Posted by lucky131969
(Post 1572751774)
Originally Posted by aweil
(Post 1572753167)
You can see the high/low spots and the transfer of metal as opposed to a freshly machined look.
(Post 1572753227)
Yep, that is clear. What isn't clear is why the wear would be in an arc. I would expect the disparity to be linear.
(Post 1572753308)
Maybe the mill tooling marks when the caps/block were machined were in an arc? I'm not an expert, I just know a little bit. I'll ask my machine shop guy next time I talk to him.
Originally Posted by TheDingo
(Post 1572753025)
Originally Posted by Chevy Guy
(Post 1572753132)
(Post 1572753227)
The small areas of "clean" or burnished metal are just visible in various places. One example is the area directly around the bolt holes where, upon torquing down the caps, the metal directly around the bolt holes is being "stretched" slightly as the bolt pulls upward on the block and the aluminum block material becomes "burnished" against the steel main cap from vibration/movement over time. I'm thinking that the "arc" visible in the pics were actually from the original machining of the surface and are (in this case) made more visible by the "dirty" oil at the microscopic level when opened back up. The "movement" is so slight, probably on the order of .0001 or so (or in that range), maybe less, that there would not be a discernible "direction" pattern as such. I guess the thrust forces are being applied in a more random or even circular manner, i.e. front-back, side-to-side, depending on applied power and rpm, etc. Interesting. Hope that makes sense, cause even if it doesn't, that's my story and I'm sticking to it. :rofl: |
Originally Posted by WKMCD
(Post 1572754914)
I would expect it to all done in 3-4 weeks. We'll get together. :thumbs:
You really can't see the fretting in those pictures.The fretting from cap walk is actually metal transfer from one surface to the other.The arcs are from the block machining.
I got some good machining pic over on LS1Tech-i'll post them over here tomorrow night |
