Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-10-2010, 03:13 PM   #1
WKMCD
CF Senior Member
WKMCD's Avatar
Default Darton sleeved 427 w/ L92 heads project begins
The dyno mule is getting a little tired so it's time to freshen it up. I thought about selling it and getting a C6 GS vert but I just can't justify the cost for a toy I drive 4-5k and year.
My engine was the first build in the country using the then new L92 heads. I wanted to see what could be done with the GM casting. Everyone poo poo'd the idea then but gradually came around. I've had 3 cams, stock and WCCH CNC'd heads of various compression ratios and other iterations. Everything that was done was done the make good power and keep the car very mild. The car currently makes 521/480 and drives very close to stock with massive tip in. 386RWT at 2200 RPM is nuts.
Here's the build thread from LS1tech:
http://www.ls1tech.com/forums/genera...us-plan-b.html
In talking with Shawn and Ed at Virginia Speed we decided that for the cost difference it made sense - if any can be made of any of this - to resleeve the LS2 block using Darton sleeves and increase the bore to 4.125. The only cost difference between staying a 403 and moving to a 427 is the cost of the sleeving which Shawn does in-house at VA Speed. I'll run the same crank, rods, cam, Melling oil pump, etc and top end. The extra bore will really make the L92 heads shine by unshrouding the valves.
I know Shawn and Ed will be posting pics and comments along the way. We're trying to make this an informative technical thread for those interested.
Shawn and Ed made the drive up from VA Beach this morning to pick up the cruiser. Damon (MCLEOD) came by to lend moral support. Next time I see it it will have a 427 under the hood.
Thanks guys.
At least it was sunny..
On it's way to winter in Va Beach - again.
__________________
"The Gentleman's Cruiser"
VA Speed 427 - 577RWHP/530RWT WCCH Stage 3 L92 heads and a little baby cam Trans/Diff by RKT56.com
WKMCD is offline   Reply With Quote
Old 01-10-2010, 03:53 PM   #2
c5_4_me
CF Senior Member
c5_4_me's Avatar
Best of luck. Beautiful car. It matches the snow.
c5_4_me is offline   Reply With Quote
Old 01-10-2010, 04:17 PM   #3
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Good luck. I would love it if Shawn posted photo's of the machining process as it progresses and the block is transformed.
vettenuts is offline   Reply With Quote
Old 01-10-2010, 05:52 PM   #4
phils C5 vette
CF Senior Member
phils C5 vette's Avatar
I would have came down just to counter bid McLeod's used parts dream list
__________________
www.TampaTuning.com
813-727-8720
Phil- Owner of Tampa Tuning
Corvette Camaro Truck tuner in Tampa
Meet us 6p Tampa HOOTERS located at 4420 W Gandy Blvd, Tampa December 14th.
[SIZE="5"]451.1 RWHP@ 5900 432.8 RWTQ@ 4900 [/size]
phils C5 vette is offline   Reply With Quote
Old 01-10-2010, 09:51 PM   #5
AlohaC5
Get ready to unleash Hell
St. Jude Donor '08-'09-'12
Support Corvetteforum!
AlohaC5's Avatar
Send a message via MSN to AlohaC5
Another excellent adventure (said in my best, "Bill and Ted" movie voice)! I'm looking forward to following your new 427 engine build thread with pics and seeing the results of this new TORQUE MONSTER!
AlohaC5 is offline   Reply With Quote
Old 01-11-2010, 07:40 AM   #6
WKMCD
CF Senior Member
WKMCD's Avatar
Quote:
Anyone need any stumps pulled?
Old 01-11-2010, 11:45 AM   #7
aweil
CF Senior Member
aweil's Avatar
Send a message via AIM to aweil
There is another cost that you omitted, that of pistons fwiw.
Looking forward to seeing what it will do!
aweil is offline   Reply With Quote
Old 01-11-2010, 12:18 PM   #8
allngn_c5
CF Senior Member
allngn_c5's Avatar
Kevin, what pistons are you going with and what is the targeted compression on this 427?
Should definately pick up a decent amount of hp man. Best of luck on the new project.
allngn_c5 is offline   Reply With Quote
Old 01-11-2010, 03:18 PM   #9
WKMCD
CF Senior Member
WKMCD's Avatar
Quote:
Shawn told me he's using -8cc pistons which will net approximately the same CR I'm running now with the -2cc pistons on the 4.005 bore.
BTW: I just had a long talk with Richard at WCCH (proheads.com). He's been fine tuning his port program for the L92/LS3 heads and doing some work on the chamber. He has the intake ports flowing 380CFM of great quality air with excellent low and mid lift numbers.. He said the heads should be very comparable to LS7 heads when we get them back. He's putting in a 2.200" intake valve. He's really excited to be involved with this ongoing project again. We're excited he's involved also.
Old 01-11-2010, 03:27 PM   #10
aweil
CF Senior Member
aweil's Avatar
Sonofabitch! What bore size/valve size/lift is that cylinder head flow at?
Old 01-11-2010, 03:29 PM   #11
allngn_c5
CF Senior Member
allngn_c5's Avatar
Thats some good info Kevin, thanks for sharing. So if the heads will flow 380 cfm, how much does that intake of yours flow ? I know the 4 inch tube up front is not going to be the restriction, I'm wondering if the intake is going to be it though?
Old 01-11-2010, 03:35 PM   #12
WKMCD
CF Senior Member
WKMCD's Avatar
Quote:
I know Richard usually flows at 4.030 and a 4.155. I'm not sure which bore he used but I believe he told me a .650 lift. I run a little more lift than that on the intake with the current cam.
Old 01-11-2010, 03:35 PM   #13
WKMCD
CF Senior Member
WKMCD's Avatar
The intake will remain the limiting factor. I really wished the LSx performed better on these heads.
Old 01-11-2010, 04:02 PM   #14
McLeod
CF Senior Member
McLeod's Avatar
Maybe a vendor who is stuck with an LSx intake could offer one up for a test with the reworked heads.
McLeod is offline   Reply With Quote
Old 01-11-2010, 04:04 PM   #15
WKMCD
CF Senior Member
WKMCD's Avatar
Quote:
Working on it.
Old 01-11-2010, 04:07 PM   #16
McLeod
CF Senior Member
McLeod's Avatar
Working on it.
I should have known.
Old 01-11-2010, 04:08 PM   #17
aweil
CF Senior Member
aweil's Avatar
I'm guessing that's gotta be at 4.155", but still that is a LOT of air!
Old 01-11-2010, 04:18 PM   #18
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
...............That is all..............Carry on...............
__________________
EFI SPECIALIST
Tuning, Advanced diagnostics, Emissions
HPTuners, EFIlive, Tunercat, Edit, SCT, Diablosport, Cobb, ECUFlash, WinOLS
Tuning all GMs, Ford, Mopar, Nissan GT-Rs, Evos, WRXs, Euros
email=edcmat-l1@msn.com
edcmat-l1 is online now   Reply With Quote
Old 01-11-2010, 05:53 PM   #19
WKMCD
CF Senior Member
WKMCD's Avatar
Quote:
Thanks for sharing...keep coming back.
Old 01-11-2010, 05:56 PM   #20
allngn_c5
CF Senior Member
allngn_c5's Avatar
Is ITB an option ??
Reload this Page Darton sleeved 427 w/ L92 heads project begins
Tags
4125, 427, darton, heads, itb, l92, ls1tech, ls2, resleeve, sale, sleeved, speed, tampa, virgina, wkmcd
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
