HUD not showing speed, only RPM
I just bought my 2003 Z06 about a month ago..the Heads up display was working fine, and now the other day the digital speed readout is gone, but the RPM's still show at the top.. Is this a fuse or bulb or does the entire unit have to be replaced??
Did you try cycling through the different display options?
Originally Posted by Blue 92
(Post 1572700779)
Did you try press and hold? Press and release cycles the gauges.
Page 3-18 here: http://www.gmpartshouse.com/download...03corvette.pdf |
(Post 1572701584)
Thanks man, that was what happened, i must have held the page button for a second too long..it works fine now
Originally Posted by DomZ06
(Post 1572704028)
Another case closed!
lol
I just had the same problem, read the link posted and went out to try it and sure enough that was all it was. This forum is AWESOME and so are its members! Thanks, once again. :cheers:
