Car turns off when I put in gear (Drive or Reverse)
Hi experts,
Today I was going home from the store and turned on the Vette, put it in reverse (Auto Tranny) and the car turned off immediately. It started right back up, put it in drive and again, turned off immeditely. Did this for about 10 times and kept doing the same thing. If I kept the car off gear I could rev the hell out of it and no problem, but as soon as I put it in gear it turned off. So I was ready for tow truck so I called my wife to pick me up. When she got there I attemted to move the car 1 more time and it worked fine, so I drove it home. Now Im worried, I dont want to get stranded. ANY ideas? I dont know whats going on!:eek: |
Originally Posted by Tyke
(Post 1572360978)
Hi experts,
No the same key. Why you think it could be the security sensor? If so why would it allow me to start it?
Sounds like a vats (security) system problem; I assume thats what an auto does when the system is engaged. On a manual, it will go to 1mph then shut off I guess an auto just needs to be put in gear.
(Post 1572361199)
Did you have the key in the ignition for a while before you turned it on??
HEre are my codes:
B2587 Column Lock/Unlock Drive (A) H B2592 Column Lock/Unlock Drive (B) H B2721 PASS-Key Detection Circuit H B2723 PASS-Key Detection Circuit H C U1160 Loss of Communications with LDCM H B2284 Battery #2 Fault H B2285 Battery #2 Fault H U1096 Loss of Communication with IPC H U1064 Loss of Communication with BCM H U1016 Loss of Communication with PCM H :thumbs: |
Originally Posted by luv my vettes
(Post 1572361412)
(Post 1572361419)
HEre are my codes:
Originally Posted by lucky131969
(Post 1572362743)
Based on the communication, battery, and pass key codes, it sounds like you are ready for a new ignition switch assembly.
:cheers: |
Originally Posted by BLOWNBLUEZ06
(Post 1572362889)
Or maybe a Bill Curlee tutorial read on the rebuild if you're a reasonably mechanically inclined individual?
:cheers: |
