Car turns off when I put in gear (Drive or Reverse)
Old 12-07-2009, 11:50 PM
Tyke
Tyke's Avatar
Default Car turns off when I put in gear (Drive or Reverse)
Hi experts,
Today I was going home from the store and turned on the Vette, put it in reverse (Auto Tranny) and the car turned off immediately.
It started right back up, put it in drive and again, turned off immeditely.
Did this for about 10 times and kept doing the same thing.
If I kept the car off gear I could rev the hell out of it and no problem, but as soon as I put it in gear it turned off.
So I was ready for tow truck so I called my wife to pick me up. When she got there I attemted to move the car 1 more time and it worked fine, so I drove it home. Now Im worried, I dont want to get stranded.
ANY ideas? I dont know whats going on!
Old 12-07-2009, 11:56 PM
lucky131969
lucky131969's Avatar
Originally Posted by Tyke
Hi experts,
Did she use a different key?
Old 12-08-2009, 12:20 AM
Tyke
Tyke's Avatar
No the same key. Why you think it could be the security sensor? If so why would it allow me to start it?
Old 12-08-2009, 12:28 AM
Millenium Z06
Moderator
Millenium Z06's Avatar
Sounds like a vats (security) system problem; I assume thats what an auto does when the system is engaged. On a manual, it will go to 1mph then shut off I guess an auto just needs to be put in gear.
Old 12-08-2009, 12:35 AM
lucky131969
Pull your codes and post..
Old 12-08-2009, 12:51 AM
luv my vettes
2nd Gear
luv my vettes's Avatar
Did you have the key in the ignition for a while before you turned it on??
Old 12-08-2009, 12:52 AM
Tyke
Tyke's Avatar
HEre are my codes:
B2587 Column Lock/Unlock Drive (A) H
B2592 Column Lock/Unlock Drive (B) H
B2721 PASS-Key Detection Circuit H
B2723 PASS-Key Detection Circuit H C
U1160 Loss of Communications with LDCM H
B2284 Battery #2 Fault H
B2285 Battery #2 Fault H
U1096 Loss of Communication with IPC H
U1064 Loss of Communication with BCM H
U1016 Loss of Communication with PCM H
Old 12-08-2009, 12:53 AM
Tyke
Tyke's Avatar
No, I did what I ussually do, stick key in start and go
Old 12-08-2009, 08:55 AM
lucky131969
HEre are my codes:
Based on the communication, battery, and pass key codes, it sounds like you are ready for a new ignition switch assembly.
Old 12-08-2009, 09:14 AM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Or maybe a Bill Curlee tutorial read on the rebuild if you're a reasonably mechanically inclined individual?
Old 12-08-2009, 03:07 PM
Tyke
Tyke's Avatar
I just did the Ignition repair thing from Bill Curlee...going to see if problem continues after this.
To Car turns off when I put in gear (Drive or Reverse)
Quick Reply: Car turns off when I put in gear (Drive or Reverse)
