Replacement Optispark and Water pump install (1992 LT1)
21 Attachment(s)
A little background story:
A few month's back, my '92 developed a very strange "hesitation" problem which would show up a few seconds after the car started running - only to last a few seconds - then disappear all together. I couldn't figure it out and needless to say, it drove me nuts. Even though the car drove just fine after the initial stumble, I was determined to figure out what the problem was and fix it even if it was just a minor annoyance. Over the next few month's, I purchased and installed a new set of Bosch III injectors. A Walbro 255 High Performance fuel pump. New filter and a new fuel pressure regulator. The problem remained. :toetap: I then turned to the ignition system and replaced the coil and module and still no dice. The car had new plug wires and O2 sensors put on a few month's back the same time I installed my long tube headers. I'd run out of ignition parts to replace... Except for one that is... From the get-go, everybody told me it was my opti-spark, but I was stubborn and didn't want to hear any of it. I've had plenty of experience with opti-spark failures in the past with other LT1 equipped vehicles I've owned and while the "hesitation" symptom was indeed a common tell-tale sign of a bad opti, the fact that this stumble only lasted a brief few seconds only to disappear until the next day left me thinking the issue had to be something besides the opti-spark. Well, after running out of ideas (as well as parts to replace) I bit the bullitt and went out and purchased a new Delco opti-spark. It occurred to me at that point, that since I had to remove the now 17 year old water pump to get to the opti-spark, I may as well buy a new pump to go along with it. No sense in doing things half-@ssed, I always like to say. After doing a bit of research, I decided to go with an electric water pump instead. The Meziere HD electric pump to be exact. I honestly didn't expect it to be worth much, (if any) horse power, but the idea of having a pump being able to circulate the same amount of coolant throughout my system regardless of the RPM I was at, I found very appealing. The factory mechanical pump doesn't circulate coolant very well at low RPM. My Vette has always run a bit hotter than I'm comfortable with, especially when sitting in stop-and-go traffic. Although I'm aware the LT1's were designed to run at higher temperatures, I still didn't like seeing my coolant temperature rising to 210' in traffic. The electric pump in my opinion, would do a better job at cooling my engine during "real world" conditions (aka: stop-and-go). If I could manage to pick up a few more horses with the electric pump, all the better, but it's not the reason I decided to go electric. Anyways, after getting all the parts, I slowly began the project. What was originally supposed to be a "Saturday afternoon job" ended up turning into a month long project. Work was hectic and I'd never have enough time to get to my car. An hour here. A few minutes there.... It just seemed to take forever. :( I managed to snap off a few pictures each time I'd get a chance to work on the car and figured I'd post them up for all of you to see. I used to always document the work I did on my car's over the years but most of the info I recorded has long been lost/deleted over the years as I went from owning one car to the next. (I wish I still had all that info) Hopefully, some of you can use the information in the following posts and make use of some of the pictures I've taken for future projects of your own. So here goes... Let me know if there's any interest in further updates, otherwise I'll save myself the time and keep this stuff for my self :leaving: OPTI-SPARK & WATER PUMP INSTALL (PART 1) Attachment 48157451 Attachment 48157452 Attachment 48157453 Attachment 48157454 Attachment 48157455 Attachment 48157456 Attachment 48157457 Attachment 48157458 Attachment 48157459 Attachment 48157460 Attachment 48157461 Attachment 48157462 Attachment 48157463 Attachment 48157464 Attachment 48157465 Attachment 48157466 Attachment 48157467 Attachment 48157468 Attachment 48157469 Attachment 48157470 http://i616.photobucket.com/albums/t...i/IMG_0483.jpg Attachment 48157471 |
20 Attachment(s)
OPTI-SPARK & WATER PUMP INSTALL (PART 3)
Attachment 48157408 Attachment 48157409 Attachment 48157410 Attachment 48157411 Attachment 48157412 Attachment 48157413 Attachment 48157414 Attachment 48157415 Attachment 48157416 Attachment 48157417 Attachment 48157418 Attachment 48157419 Attachment 48157420 http://i616.photobucket.com/albums/t...%20opti/z3.jpg Attachment 48157421 Attachment 48157422 Attachment 48157423 Attachment 48157424 Attachment 48157425 Attachment 48157426 http://i616.photobucket.com/albums/t...%20opti/z7.jpg Attachment 48157427 ---------------- ---------------- - LT1C4 :flag: |
I have 70K on my 92, but want to drive it cross country next summer, so for peace of mind I plan on doing this job in the winter. this thread will be very helpvful. thanks.
Excellent thread!! A++ thank you!!
That is an awesome write up!
Dex-cool :eek:
Great job and thanks for taking the time to post your pics. This will help me when I do this to my 93'.
Mike |
Fantastic! Puts the Haynes Manual to shame.
I knew someone would comment on the Dex Cool. It is not the recommended coolant for your engine. GM didn't change to Dex Cool til 95, I think.
I would have removed the water pump drive shaft. It is a pain but removes a potential oil leak. If you remove the knock sensor(s) it will reduce the mess when you remove the water pump. I would put on new hoses and belt if they are more than 4-5 years old. Otherwise a nice job!! :thumbs: |
great write up! i just did one little while ago on changing the brake booster, but this is even better then mine! im saving it just incase...
Excellent write-up and pictorial. I would only add that I did not have to remove the TB at all, and it was hardly in the way as I recall.
Great pictures and an outstanding narrative :thumbs: Very nice of you to take the time, it will surely be helpful for anyone attempting this in the future. Thanks :cheers:
Originally Posted by jimmymack
(Post 1572042482)
Originally Posted by jimg's'93
(Post 1572042226)
I will add this is a good time to replace plug wires and if you need to replace your seals in your timing cover ! Also if keeping the stock Watter Pump tap out the weep hole on the bottom and put a fitting and hose so when it fails the opti doesn't get drenched. I cheated and used a plastic vacuum fitting just pushed in which will still reduce the amount falling on the OPTI by 98 percent. I am planing on a electric WP on my Hot Rod but I was wondering about how the timing cover hole is plugged off ??? Here is another link that has some useful pointers on replacing those seals to prevent oil leaks. http://www.impalasuperstore.com/nais...TOPIC_ID=30984 I just had to redue my sons Camaro cause the seal was nicked when the WP was installed ! Get brave guys and learn to do things with help from friends and the forum cause no one loves your car like you do and you can do some serious cleaning at the same time. Also these engines are a snap to pull if you have the lift ! |
Nice writeup :thumbs:
(Post 1572042226)
Very Nice write up and Great pics ! This will surely come in handy the next time my friend asks me to help change his opti or waterpump . I'll just email him the link and say your welcome :cool:
And hes not using dex cool. it is Dex cool 'approved' coolant. :thumbs::cheers: |
Thanks I will save this.
I have a seal up front leaking (one of the three I think in the timing chain cover)so everthing must come off. I just don't know if I should replace the opti???? 72,000 miles |
Originally Posted by Road Agent
(Post 1572038389)
Dex-cool :eek:
Originally Posted by tblt44
(Post 1572045982)
