Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2009, 11:38 PM   #1
LT1*C4
CF Senior Member
LT1*C4's Avatar
Default Replacement Optispark and Water pump install (1992 LT1)
A little background story:
A few month's back, my '92 developed a very strange "hesitation" problem which would show up a few seconds after the car started running - only to last a few seconds - then disappear all together. I couldn't figure it out and needless to say, it drove me nuts.
Even though the car drove just fine after the initial stumble, I was determined to figure out what the problem was and fix it even if it was just a minor annoyance. Over the next few month's, I purchased and installed a new set of Bosch III injectors. A Walbro 255 High Performance fuel pump. New filter and a new fuel pressure regulator.
The problem remained.
I then turned to the ignition system and replaced the coil and module and still no dice. The car had new plug wires and O2 sensors put on a few month's back the same time I installed my long tube headers. I'd run out of ignition parts to replace...
Except for one that is...
From the get-go, everybody told me it was my opti-spark, but I was stubborn and didn't want to hear any of it. I've had plenty of experience with opti-spark failures in the past with other LT1 equipped vehicles I've owned and while the "hesitation" symptom was indeed a common tell-tale sign of a bad opti, the fact that this stumble only lasted a brief few seconds only to disappear until the next day left me thinking the issue had to be something besides the opti-spark.
Well, after running out of ideas (as well as parts to replace) I bit the bullitt and went out and purchased a new Delco opti-spark. It occurred to me at that point, that since I had to remove the now 17 year old water pump to get to the opti-spark, I may as well buy a new pump to go along with it. No sense in doing things half-@ssed, I always like to say.
After doing a bit of research, I decided to go with an electric water pump instead. The Meziere HD electric pump to be exact. I honestly didn't expect it to be worth much, (if any) horse power, but the idea of having a pump being able to circulate the same amount of coolant throughout my system regardless of the RPM I was at, I found very appealing.
The factory mechanical pump doesn't circulate coolant very well at low RPM. My Vette has always run a bit hotter than I'm comfortable with, especially when sitting in stop-and-go traffic. Although I'm aware the LT1's were designed to run at higher temperatures, I still didn't like seeing my coolant temperature rising to 210' in traffic. The electric pump in my opinion, would do a better job at cooling my engine during "real world" conditions (aka: stop-and-go). If I could manage to pick up a few more horses with the electric pump, all the better, but it's not the reason I decided to go electric.
Anyways, after getting all the parts, I slowly began the project. What was originally supposed to be a "Saturday afternoon job" ended up turning into a month long project. Work was hectic and I'd never have enough time to get to my car. An hour here. A few minutes there.... It just seemed to take forever.
I managed to snap off a few pictures each time I'd get a chance to work on the car and figured I'd post them up for all of you to see. I used to always document the work I did on my car's over the years but most of the info I recorded has long been lost/deleted over the years as I went from owning one car to the next. (I wish I still had all that info)
Hopefully, some of you can use the information in the following posts and make use of some of the pictures I've taken for future projects of your own.
So here goes...
Let me know if there's any interest in further updates, otherwise I'll save myself the time and keep this stuff for my self
OPTI-SPARK & WATER PUMP INSTALL (PART 1)
Click the image to open in full size.
LT1*C4 is offline   Reply With Quote
Old 11-03-2009, 11:39 PM   #2
LT1*C4
CF Senior Member
LT1*C4's Avatar
OPTI-SPARK & WATER PUMP INSTALL (PART 2)
Old 11-03-2009, 11:40 PM   #3
LT1*C4
CF Senior Member
LT1*C4's Avatar
OPTI-SPARK & WATER PUMP INSTALL (PART 3)
- LT1C4
Old 11-04-2009, 12:02 AM   #4
92PGC
CF Senior Member
92PGC's Avatar
I have 70K on my 92, but want to drive it cross country next summer, so for peace of mind I plan on doing this job in the winter. this thread will be very helpvful. thanks.
92PGC is offline   Reply With Quote
Old 11-04-2009, 01:07 AM   #5
blizzam
CF Member
Excellent thread!! A++ thank you!!
blizzam is offline   Reply With Quote
Old 11-04-2009, 02:10 AM   #6
kangi
CF Senior Member
kangi's Avatar
That is an awesome write up!
kangi is offline   Reply With Quote
Old 11-04-2009, 05:40 AM   #7
Road Agent
CF Senior Member
Dex-cool
Road Agent is offline   Reply With Quote
Old 11-04-2009, 06:11 AM   #8
npbassman
CF Senior Member
npbassman's Avatar
Great job and thanks for taking the time to post your pics. This will help me when I do this to my 93'.
Mike
npbassman is offline   Reply With Quote
Old 11-04-2009, 10:21 AM   #9
Sidney004
CF Senior Member
Fantastic! Puts the Haynes Manual to shame.
Sidney004 is offline   Reply With Quote
Old 11-04-2009, 01:38 PM   #10
MK 82
CF Senior Member
MK 82's Avatar
I knew someone would comment on the Dex Cool. It is not the recommended coolant for your engine. GM didn't change to Dex Cool til 95, I think.
I would have removed the water pump drive shaft. It is a pain but removes a potential oil leak.
If you remove the knock sensor(s) it will reduce the mess when you remove the water pump.
I would put on new hoses and belt if they are more than 4-5 years old.
Otherwise a nice job!!
MK 82 is offline   Reply With Quote
Old 11-04-2009, 01:52 PM   #11
littlesk8cracker
CF Senior Member
littlesk8cracker's Avatar
great write up! i just did one little while ago on changing the brake booster, but this is even better then mine! im saving it just incase...
littlesk8cracker is offline   Reply With Quote
Old 11-04-2009, 02:05 PM   #12
jimg's'93
CF Senior Member
jimg's'93's Avatar
Send a message via Yahoo to jimg's'93
Excellent write-up and pictorial. I would only add that I did not have to remove the TB at all, and it was hardly in the way as I recall.
jimg's'93 is offline   Reply With Quote
Old 11-04-2009, 02:34 PM   #13
jimmymack
CF Senior Member
St. Jude Donor '09-'10-'11-'13-'14
jimmymack's Avatar
jimmcgoldrick
Great pictures and an outstanding narrative Very nice of you to take the time, it will surely be helpful for anyone attempting this in the future. Thanks
jimmymack is offline   Reply With Quote
Old 11-04-2009, 05:07 PM   #14
betyelou
CF Senior Member
betyelou's Avatar
Quote:
Excellant write-up and pics. this will surely make the changing of WP and opti much easier.
betyelou is offline   Reply With Quote
Old 11-04-2009, 05:57 PM   #15
larry00
CF Senior Member
larry00's Avatar
Larry Hedge
Quote:
Good Pic's ! I didn't have to remome mine on my 95 either !
I will add this is a good time to replace plug wires and if you need to replace your seals in your timing cover !
Also if keeping the stock Watter Pump tap out the weep hole on the bottom and put a fitting and hose so when it fails the opti doesn't get drenched. I cheated and used a plastic vacuum fitting just pushed in which will still reduce the amount falling on the OPTI by 98 percent.
I am planing on a electric WP on my Hot Rod but I was wondering about how the timing cover hole is plugged off ???
Here is another link that has some useful pointers on replacing those seals to prevent oil leaks.
http://www.impalasuperstore.com/nais...TOPIC_ID=30984
I just had to redue my sons Camaro cause the seal was nicked when the WP was installed !
Get brave guys and learn to do things with help from friends and the forum cause no one loves your car like you do and you can do some serious cleaning at the same time.
Also these engines are a snap to pull if you have the lift !
larry00 is offline   Reply With Quote
Old 11-04-2009, 07:02 PM   #16
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice writeup
me too
__________________
Polo Green 95 LT1 6-spd
383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske coilovers/Wilwood 6pot brakes
NCCC Governor/Membership/WebMaster: www.baystatecorvetteclub.com
BrianCunningham is offline   Reply With Quote
Old 11-04-2009, 07:24 PM   #17
5abivt
CF Senior Member
5abivt's Avatar
Very Nice write up and Great pics ! This will surely come in handy the next time my friend asks me to help change his opti or waterpump . I'll just email him the link and say your welcome
And hes not using dex cool. it is Dex cool 'approved' coolant.
5abivt is offline   Reply With Quote
Old 11-04-2009, 08:02 PM   #18
tblt44
CF Senior Member
tblt44's Avatar
Thanks I will save this.
I have a seal up front leaking (one of the three I think in the timing chain cover)so everthing must come off.
I just don't know if I should replace the opti???? 72,000 miles
__________________
1995 Black on Black, Auto, 3.07 gears, Corsa exhaust, K & N filter, Throttle Body Bypass,Taylor spiro pro wires,NGK G platinum plugs,Goodyear Eagle F1 GS-D3 tires,Pioneer radio and speakers ,Mobil 1 5W-30 oil W/Pure 1 filter
tblt44 is offline   Reply With Quote
Old 11-04-2009, 08:08 PM   #19
94vettelover2
CF Senior Member
Quote:
Originally Posted by Road Agent View Post
Dex-cool
Dexcool is garbageOtherwise awesome,awesome postI wish Alldata was this detailed.I hope everyone starts doing this,this is great!Is the 1994 to 1996 set-up the same?-meaning you can't screw up getting the distibutor rotor on wrong location/pointing direction?I could watch stuff/posts like this all daylove it.Those headers looked very nice.Why no painted red intake or throttle air foil?Those foils add 10horsepowerSeriously though,very nice engine bay-CLEAN
94vettelover2 is offline   Reply With Quote
Old 11-04-2009, 08:16 PM   #20
94vettelover2
CF Senior Member
If I was you & had the money,this to me would mean upgrade time- cam,timing chain,electric waterpump,new opti,roller rockers,valve springs,ported intake(painted red of course).To me this would be the perfect time to do everything "while your there".I don't know for sure,but am guessing 100 hp increase from this.More if you have headers/exhaust work done.Anyone agree/disagree with this much power increase?Oh & an airfoil
Reload this Page Replacement Optispark and Water pump install - Part 1 (includes pictures)
Tags
1994, 94, c6, corvette, hole, installation, leaking, meziere, opti, optispark, pump, removal, replacement, spark, vette, water, weep, write
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The new wheels just came in... LT1*C4 C4 General Discussion 53 06-30-2014 04:11 PM
New ARH stainless headers & Xpipe have arrived... LT1*C4 C4 Tech/Performance 90 02-28-2014 10:21 PM
Supercharging an LT1 Corvette LT1*C4 C4 Forced Induction/Nitrous 53 02-12-2014 12:51 AM
Hot off the press: Pic's of my '92 lowered with new wheels. LT1*C4 C4 General Discussion 65 05-08-2013 09:02 PM
Just finished installing a set of Bosch III's (pictures and small write-up within) LT1*C4 C4 Tech/Performance 48 01-08-2013 06:40 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
