Power Steering Fluid in C6??
I have a 2005 C6 and I was wondering if you could use Pennzoil Power Steering Fluid in it. It was the only thing available at the local store and I need to fill it up. The reservoir is somewhat low! Thanks.
I use the Gm stuff, its cheap and the dealer always has it.
GM Power Steering Fluid An amber colored, light-bodied mineral oil that contains a specially developed additive package to provide good performance in power steering systems. Reduces power steering noise. Specially formulated to provide anti-corrosive and non-foaming qualities with excellent lubrication for year-round use. Size: Item #: 16 oz. 89021184 1qt. 89020661 The Pennzoil stuff says it compatible with all power steering fluid. |
Whatever you do, do NOT use the Valvoline "synthetic" PS fluid. I tried it in my C6 and had major issues to the point where the car was undriveable.
Originally Posted by bapd77
(Post 1571466679)
Originally Posted by nwc6
(Post 1571467909)
(Post 1571466679)
what i do is use my old turkey baster to extract fluid out, and refill with new i do this every year in my other cars to keep some fresh fluid in the system there's alot of heat going on in cars now-a-days so keeps everything nice and clean same goes for the brake master cyl |
(Post 1571466679)
Once again....if the auto parts store PS fluid advertises that it has anti-leak additives.......run (in my opinion). |
