How to adjust adjustable vacuum advance?
My HEI distributor has an adjustable vacuum advance unit. How does one go about adjusting it? It has a hexagonal shape. Is it adjusted by rotating the housing? Thanks.
temvette72:cheers: |
There is an allen screw inside the vacuum nipple.
Thanks a bunch!
Temvette72:cheers: |
Originally Posted by DWncchs
(Post 1571263099)
Originally Posted by vetteguy75
(Post 1571267538)
OK that's great, but when you turn it, exactly what happens?:thumbs:
(Post 1571267538)
You also need to set the max advance with a limit plate of some sort.
Here is the Crane unit and their instructions. http://69.20.53.62/pdf/254g.pdf The easiest way to set the adjustables is using a hand vacuum pump on the cannister to tell you what the vacuum reading is when it opens, and checking with a timing lite. |
