How to adjust adjustable vacuum advance?
Old 08-25-2009, 01:07 PM
temvette72
temvette72's Avatar
Default How to adjust adjustable vacuum advance?
My HEI distributor has an adjustable vacuum advance unit. How does one go about adjusting it? It has a hexagonal shape. Is it adjusted by rotating the housing? Thanks.
temvette72
Old 08-25-2009, 01:17 PM
...Roger...
...Roger...'s Avatar
There is an allen screw inside the vacuum nipple.
Old 08-25-2009, 06:33 PM
temvette72
temvette72's Avatar
Thanks a bunch!
Temvette72
Old 08-25-2009, 07:43 PM
vetteguy75
Support Corvetteforum!
vetteguy75's Avatar
LA Events Coordinator
OK that's great, but when you turn it, exactly what happens?
Old 08-25-2009, 07:58 PM
piperkansas
piperkansas's Avatar
I'm only familiar with the adjustable can I had on a points dist. The allen screw controlled the rate and there was a seperate bracket that controlled the total amount the can could advance the timing.
Old 08-25-2009, 09:07 PM
tonyv123
tonyv123's Avatar
Heres some instructions...
http://69.20.53.62/pdf/210g2.pdf
Old 08-25-2009, 09:40 PM
...Roger...
tonyv123 s post explains it......PITA big time, I dont care for them.
Old 08-25-2009, 10:13 PM
noonie
noonie's Avatar
You also need to set the max advance with a limit plate of some sort.
Here is the Crane unit and their instructions.
http://69.20.53.62/pdf/254g.pdf
The easiest way to set the adjustables is using a hand vacuum pump on the cannister to tell you what the vacuum reading is when it opens, and checking with a timing lite.
To How to adjust adjustable vacuum advance?
Quick Reply: How to adjust adjustable vacuum advance?
