Originally Posted by rickneworleansla
(Post 1578165526)
I think I'm going to get me this tonight from Walmart. Whats the best way to secure it to the latch?
http://i.walmartimages.com/i/p/00/04...48_180X180.jpg |
Originally Posted by tntwolt
(Post 1581153540)
for some reason i can`t open the pics, i get a red "x". any help with this?
found a pic in thread, now i know what its supposed to look like. have not yet hooked up withany C4 guys to share info about our cars
Can someone upload new pictures of this Mod? The original ones are dead. |
Originally Posted by Railroadman
(Post 1580807198)
http://i453.photobucket.com/albums/q...r/100_4888.jpg
Yes it's an old thread but a helpful one - hopefully the moderators will keep it open since we have a whole lot of new C-4 owners who have not yet done this. Others may have better pics but here's mine - color coordinated to the car no less! :thumbs: |
It is a great idea.:smash::smash::smash:
Originally Posted by pkazsr
(Post 1570973952)
:o I have all the parts to install the release in my tool box. They have been in there for 2+ years.
(Post 1581235480)
Three years later, (Just like this thread), the parts are still there.
Hey, maybe you never will need them. Or, maybe the old one will break just as you try to open the hood to put out that fire you just discovered! :willy: |
emergency release
Here's some pics of how I did mine. Same basic plan as others but i reconfigured my attachment point to beef it up. Cut some metal line to run my cable through.
http://i1185.photobucket.com/albums/...k/IMAG0318.jpg http://i1185.photobucket.com/albums/...k/IMAG0323.jpg http://i1185.photobucket.com/albums/...k/IMAG0136.jpg http://i1185.photobucket.com/albums/...k/IMAG0137.jpg :flag: Happy 4th |
^ Great pics! Thanks!
(Post 1581235581)
We're holding the thread open until you finally do it! :lol:
Hey, maybe you never will need them. Or, maybe the old one will break just as you try to open the hood to put out that fire you just discovered! :willy: 1) When I think of it it is 3:00 am 2) Usually I believe if it aint broke don't fix it. When I try to do preventive maintenance on the Vette a $50 fix turns out to be a $500 repair. |
(Post 1581236988)
I have 2 problems about getting it done.
Odd, I don't see any photos in the OP's post.
Originally Posted by Raptor_1
(Post 1581447818)
Usually the forum has a "45 day rule" which says if a thread is that long without a post, you start a new one instead of reviving the old. In this case the mods have (wisely IMHO) allowed the old one to stay alive as it contains so much good info. Welcome, and if you are a C-4 owner you might want to think about doing that modification as some day, some where, the old one will break. |
this seems like an inexpensive, smart mod to do.
Originally Posted by John.87
(Post 1581449092)
The cable retainer on my car doesn't look like the the ones in the photo.
It doesn't have that extra slot. I used a couple pieces of duck decoy cord about 15" long, slid the one end through the clip beside the original cables, tied a couple of knots to secure them and tied a loop in the other end that lays under the wipers. Does the job just fine. :) |
Corvette hood release
:cheers:
Originally Posted by ottawabarber
(Post 1570972259)
My hood release cable has worked fine since I bought my 88' but many threads here have mentioned horror stories of a broken cable and not being able to get the hood open.
One great solution that has been discussed here was a set of emergency release cables in the wipers area. I decided to make a pair for mine and thought I would take some photo's to share for people like me who find a photo or drawing often times more understandable than only words. Total cost was $7.00 !! 1/16" wire cable at .69 cents a foot, and one package of Cable Clamps and Stops and state tax. The clamps are aluminum and need to be hit with a hammer against a steel bar to crimp the cable properly. Here is the location of the existing factory installed cable. Adjacent to the cable connection is a small opening that allows the 1/16" cable to go through. http://starvedrockcorvettes.com/clampSU.jpg This next one is a close up of the clamps I used. http://starvedrockcorvettes.com/clampB.jpg Since I was using 1/16 cable I decided to drill a 1/8" hole through the rubber guard below the wipers to allow free movement. I tried to make the cable lay as straight as possible. This photo is the cable before being cut and the stop being put on. http://starvedrockcorvettes.com/clamp4.jpg These next two photo's show the cables completed, and the last is a close up of the connection. I intend to paint them black to make them blend in and not be so noticable. Total time 30 minutes (a guy has to sip some malt beverage on a job like this :cheers: ) I now have a great piece of mind knowing if my primary cable fails, I can still gain access to the underhood to fix it. http://starvedrockcorvettes.com/clamp3.jpg http://starvedrockcorvettes.com/clamp8.jpg http://starvedrockcorvettes.com/clamp9.jpg Hope this is helpful for some of you :flag: :cheers: Larry |
I used some steel fishing leaders on both sides and crimped the loops at the ends, then run the other ends to the middle of the hood on each side and crimped some loops again for something to pull on, I dare that hood cable to break!!:D
the only thing to beware of is the e-cable getting caught in the hood pin locater hole. I used mine e-cable a few times, then the :no -start condition happened. Pulled the cables. . drivers side popped the hood. Pass side was trapped in the locator hole, broke when I put the muscle to it. Had to buy the "tool" to pop the hood. 25 bucks.PIA to use. Got it to finally work. New hood cables on the way and bought some stranded wire this time for the e cables.. Oh, fixed the fuel pump problem too,lol.
