emergency hood release cable - EASY with pics
Old 07-30-2009, 07:44 PM
ottawabarber
ottawabarber's Avatar
Default emergency hood release cable - EASY with pics
My hood release cable has worked fine since I bought my 88' but many threads here have mentioned horror stories of a broken cable and not being able to get the hood open.
One great solution that has been discussed here was a set of emergency release cables in the wipers area.
I decided to make a pair for mine and thought I would take some photo's to share for people like me who find a photo or drawing often times more understandable than only words.
Total cost was $7.00 !! 1/16" wire cable at .69 cents a foot, and one package of Cable Clamps and Stops and state tax. The clamps are aluminum and need to be hit with a hammer against a steel bar to crimp the cable properly.
Here is the location of the existing factory installed cable. Adjacent to the cable connection is a small opening that allows the 1/16" cable to go through.
This next one is a close up of the clamps I used.
Since I was using 1/16 cable I decided to drill a 1/8" hole through the rubber guard below the wipers to allow free movement. I tried to make the cable lay as straight as possible. This photo is the cable before being cut and the stop being put on.
These next two photo's show the cables completed, and the last is a close up of the connection. I intend to paint them black to make them blend in and not be so noticable.
Total time 30 minutes (a guy has to sip some malt beverage on a job like this )
I now have a great piece of mind knowing if my primary cable fails, I can still gain access to the underhood to fix it.
Hope this is helpful for some of you
Larry
The following 2 users liked this post by ottawabarber:
gwagg (02-04-2016), RICK ATKINS (08-12-2019)
Old 07-30-2009, 08:06 PM
Razor89
Razor89's Avatar
That's exactly what I did a couple of years ago.
I have never needed to use them but they do work great!
Smart and cheap mod to do to any old car with a cable release. I put one my dad's corsica a few years back and we have had to use it a couple of times.
Old 07-30-2009, 08:16 PM
jimg's'93
jimg's'93's Avatar
Nice job and a great write-up!
Eakster
Eakster's Avatar
Nice pics - thank you
Old 07-30-2009, 08:24 PM
Calderone
Calderone's Avatar
thanks,excellent,i just put some black zip ties yesterday just in case !
Garand1 (03-17-2022)
Old 07-30-2009, 09:07 PM
pologreen1
pologreen1's Avatar
cool, I used black to hide mine more.
Old 07-30-2009, 09:21 PM
1bdvet
1bdvet's Avatar
Received 4,505 Likes on 3,590 Posts
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Looks good!
Old 07-30-2009, 09:41 PM
betyelou
betyelou's Avatar
Simple and effective. great job.
Old 07-30-2009, 10:03 PM
samsonb
samsonb's Avatar
Don't order the ones from Ecklers. They will rust.
Old 07-30-2009, 10:11 PM
pkazsr
pkazsr's Avatar
Cruise-In X Veteran
St. Jude Donor '09
:o I have all the parts to install the release in my tool box. They have been in there for 2+ years.
Old 07-30-2009, 10:22 PM
mrmtrtrnd
Support Corvetteforum!
mrmtrtrnd's Avatar
Thanks for the post, this was a job I was going to do in the spring and forgot. It's on my list now. Good job putting the pictures and info together.
Old 07-31-2009, 06:53 AM
ottawabarber
Thanks everyone Glad that you found this useful.
I agree with the fact they should be black, that is why in my details I said I only had to paint them black to be finished. It was too windy the day I did this to attempt to paint them.
Old 07-31-2009, 07:23 AM
Epimax
Epimax's Avatar
It's been one of those things I keep putting off, but need to do!
Excellent writeup and pics!
Old 07-31-2009, 07:38 AM
runner140*
runner140*'s Avatar
Nice job and good pic's. I had an 18" black zip tie for years....now I use a pull cable like yours but never had the emergency to use.
Old 07-31-2009, 08:45 AM
jimmers
jimmers's Avatar
Thats exactly what I did to mine least year.
Old 07-31-2009, 09:06 AM
pianoguy
pianoguy's Avatar
Nice job! I'm lazy and bought some of the ready-made cables, but it's a little project that's well worth doing, BEFORE it's needed ;-)
Old 07-31-2009, 10:04 AM
jimmymack
jimmymack's Avatar
St. Jude Donor '09-'10-'11,'13-'14-'15-'16-'17-'18-'19-'20-'21,'22-'23-'24
X2 But a great writeup and pics, good job
To emergency hood release cable - EASY with pics
Old 07-31-2009, 08:03 PM
kenv
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Thanks for the write up
Old 07-31-2009, 08:40 PM
hip
hip's Avatar
Default emergency hood cable
I installed my emergency cables last night, My hood cable broke Sunday. I pulled RF tire & pulled some bolts out of wheel well. I then used long screwdriver to push hood latch open. I went to good ole Wally world last night & bought 2, 12" 50 lb fishing leaders for .$50 snapped each 1 on to each hood latch. It works great. I thought since my hood release cable was new there would be no problem, luckly I was home when release cable came off.
Old 07-31-2009, 08:48 PM
wnafly
wnafly's Avatar
Excellent!! thanks for the pics too
Quick Reply: emergency hood release cable - EASY with pics
