All the common C5 problems that GM didn't fix
Do you guys know how many of these issues GM solved in the C5 or C6. I have experianced the following in 2 C5's and about 150k mi.
1) Rocking seat (twice) 2) Stuck clutch pedal 3) Fuel sender malfunction (twice) 4) Oil pressure sender (twice in 1 year) 5) Wobbling harmonic balancer 6) Loose axel nut 7) Column lock I have seen all of these issues many times here, did I miss any? or should I say did any miss me....Ha. Is it normal for a manufacturer to not address recurring problems like these over a 9 year production. I know LS2's have the same damper issue we have, I saw one last week. In spite of these issues I wouldn't trade my Vette for any other vehicle at twice the price, at least GM got rid of optispark. |
I'm not sure all of the issues that were fixed with the C6. I've experienced several of the problems you listed. I'll add a few that are very popular on this board...
8) Transmission leak between differential and transmission. 9) Rear window falls out of convertible top. (Been there done that. BTW, aftermarket tops are stitched!) 10) Differential leaks. (aka leaky butt) 11) Dim Auto Climate Controls 12) Headlight gears/motors fail (not a problem with a C6!) 13) Low Quality Leather Seats that crack over time. (C6 leather is much nicer) 14) Various water leaks due to weather stripping or window coming out of adjustment. 15) Convertible trunk won't pop up after time (not a hard fix, but it's still an issue). 16) Fobs wear out and stop working after a while. I've personally experienced the trunk problem, leaky transmission, window out of adjustment, badly cracked seats, wobbling harmonic balancer, erratic fuel gauge, rocking seat (wet okole seat covers seem to have cured it, maybe I just don't feel it anymore?), window glass falling out of the convertible top, and failure of the fob. I've had one or two other less common problems, like the failure of a day time run light socket and one of the adjustments on the electric seat failing. That said, I also love this car. ALL vehicles have common problems, it's only thanks to the internet that we know them all. |
I personally have only experienced two of those problems. My 97 had the rocking seat which was fixed under warranty. I had the fuel gauge problem on my 03 but that was pretty much attributed to a bad batch of gas and fixed under warranty. In 11 years haven't had any of the other problems. Don't consider them common.
Bill |
It might be worth asking the question on C6 General. A lot of C5 owners have moved on as they've bought newer Vettes.
As you say, many of those issues have regularly cropped up. For me, the list is: Door Lock control module failed (fixed under warranty) Leaky rear diff (fixed under warranty) AC Delco Battery failed (GM not interested as I had to get a new one to get back on the road) Headlight gear stripped (fixed under warranty) Erratic fuel gauge reading (Techron) Trunk lid issue (made a trunk popper) Split seam on the seat (repaired) |
I'll add delaminating door panels, bad grounds, frozen head light adjusters, sport seat bladders and fittings, horn switch. That's enough for me.
Don't forget the hazard switch fault that messes up the turn signals...
I've also had 1. rocking seat 2. hand brake replacement 3. Headlamp gear 4. Fuel senders 5. Cracked spokes in rims 6. Dim HVAC lamps 7. Vert window glass starting to separate (fixed myself, quickly and easily with Rhino glue) All of the above, with the exception of #7, was covered under warranty. My window seals leak a little in rain, but it barely ever rains here, so I've dragged my feet in doing anything about it. My lastest problem is that my steering column sounds like a donkey braying when turning it slowly (like in a parking lot, for instance). No idea what needs lubing or how to get to it. |
Originally Posted by JMc
(Post 1568775399)
My lastest problem is that my steering column sounds like a donkey braying when turning it slowly (like in a parking lot, for instance). No idea what needs lubing or how to get to it. Try this link: https://www.corvetteforum.com/techti...D=35&TopicID=1 |
Geez, I must be one lucky guy. I honestly have had no issues on my 1998. 44,000 miles and so far, bulletproof.
That sound you hear is me knocking on wood. :D :cheers: |
Only problems I had with my two C5s were the column lock, fuel guage, leaking differential and oil consumption. Each was fixed under warranty.
I'm a little worried now. I have the interior door panel de-laminating issue that I've been meaning to have serviced. My car still has a warranty but now I'm not sure if it will be covered.
I have a '99 FRC and it has a few very minor problems. Fuel sensor intermittenly goes to 3/4 on fill up instead of full, rocking seat JUST started, and my heating and A/C only comes out of my defrost and cant figure that one out. I also had a output seal leaking that was improperly diagnosed by Cartek as a tranny leak WHILE they were doing my output shafts and gears and didnt fix it so I did it mself.
Had the back window fall out of my vert 1 week after purchase ( used) dealer paid under warranty and col.lock twice also under warranty.
The only one I've had not listed is broken valve springs (4). GM TOLD ME "OH THAT'S COMMON WITH THESE"
125k DD, not a racer |
Convertible Trunk Lid
I saw your list of common C-5 problems and noticed that you had the convertible trunk lid listed. I am experiencing that problem right now. The trunk on my 99 will not pop up far enough to even get a finger underneath the edge. I have to pop the release and then close the door to push it up with the air from the door closing. Can you tell me how you fixed yours?
The rear hatch of my 02 coupe has bubbled very slightly about the corvette symbol. You can see this in bright sunlight. This is another common C5 issue. I just ignore it, doesn't really bother me at this point. Love the car, can't wait for spring to break it out.
A Couple more.
Auto Climate control Actuator problem. Outside Temperature sensor replacement. |
Every single car and all brands of cars have problems/tech bulletins and recalls! Corvette is no different from any of them.You can bet if it is mechanical it will have a problem sooner or later!
yes u did
Originally Posted by C5 LS7
(Post 1568773784)
1) Rocking seat (twice) 2) Stuck clutch pedal 3) Fuel sender malfunction (twice) 4) Oil pressure sender (twice in 1 year) 5) Wobbling harmonic balancer 6) Loose axel nut 7) Column lock I have seen all of these issues many times here, did I miss any? or should I say did any miss me....Ha. Is it normal for a manufacturer to not address recurring problems like these over a 9 year production. I know LS2's have the same damper issue we have, I saw one last week. In spite of these issues I wouldn't trade my Vette for any other vehicle at twice the price, at least GM got rid of optispark. GM is just not run right. here's a question how many of u c5 owners come time to buy another sports car will stick with a corvette? |
I will, but it will be awhile.
removable top surface delam, bad leather seats, lumbar doesnt work. but i can deal with those. still a well built car
