Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-31-2009, 10:43 PM   #1
C5 LS7
CF Senior Member
C5 LS7's Avatar
Default All the common C5 problems that GM didn't fix
Do you guys know how many of these issues GM solved in the C5 or C6. I have experianced the following in 2 C5's and about 150k mi.
1) Rocking seat (twice)
2) Stuck clutch pedal
3) Fuel sender malfunction (twice)
4) Oil pressure sender (twice in 1 year)
5) Wobbling harmonic balancer
6) Loose axel nut
7) Column lock
I have seen all of these issues many times here, did I miss any? or should I say did any miss me....Ha. Is it normal for a manufacturer to not address recurring problems like these over a 9 year production. I know LS2's have the same damper issue we have, I saw one last week. In spite of these issues I wouldn't trade my Vette for any other vehicle at twice the price, at least GM got rid of optispark.
C5 LS7 is offline   Reply With Quote
Old 01-31-2009, 11:11 PM   #2
71vetteinva
CF Senior Member
I'm not sure all of the issues that were fixed with the C6. I've experienced several of the problems you listed. I'll add a few that are very popular on this board...
8) Transmission leak between differential and transmission.
9) Rear window falls out of convertible top. (Been there done that. BTW, aftermarket tops are stitched!)
10) Differential leaks. (aka leaky butt)
11) Dim Auto Climate Controls
12) Headlight gears/motors fail (not a problem with a C6!)
13) Low Quality Leather Seats that crack over time. (C6 leather is much nicer)
14) Various water leaks due to weather stripping or window coming out of adjustment.
15) Convertible trunk won't pop up after time (not a hard fix, but it's still an issue).
16) Fobs wear out and stop working after a while.
I've personally experienced the trunk problem, leaky transmission, window out of adjustment, badly cracked seats, wobbling harmonic balancer, erratic fuel gauge, rocking seat (wet okole seat covers seem to have cured it, maybe I just don't feel it anymore?), window glass falling out of the convertible top, and failure of the fob.
I've had one or two other less common problems, like the failure of a day time run light socket and one of the adjustments on the electric seat failing.
That said, I also love this car. ALL vehicles have common problems, it's only thanks to the internet that we know them all.
71vetteinva is offline   Reply With Quote
Old 02-01-2009, 02:11 AM   #3
Bill Dearborn
Bill Dearborn's Avatar
I personally have only experienced two of those problems. My 97 had the rocking seat which was fixed under warranty. I had the fuel gauge problem on my 03 but that was pretty much attributed to a bad batch of gas and fixed under warranty. In 11 years haven't had any of the other problems. Don't consider them common.
Bill
Bill Dearborn is offline   Reply With Quote
Old 02-01-2009, 02:17 AM   #4
DeeGee
DeeGee's Avatar
Dave Gledhill David Gledhill
It might be worth asking the question on C6 General. A lot of C5 owners have moved on as they've bought newer Vettes.
As you say, many of those issues have regularly cropped up. For me, the list is:
Door Lock control module failed (fixed under warranty)
Leaky rear diff (fixed under warranty)
AC Delco Battery failed (GM not interested as I had to get a new one to get back on the road)
Headlight gear stripped (fixed under warranty)
Erratic fuel gauge reading (Techron)
Trunk lid issue (made a trunk popper)
Split seam on the seat (repaired)
__________________
http://deegee-media.webnode.com/
2002 A4 Convertible, Mag Red II
Euro head and tail lights, Z06 screens, frame savers and rocker rails, Pioneer AVIC X1R nav/DVD player, EE catch can.
Tattershall Castle, England *** **** **** *** Las Vegas, NV
Jet Noise, the sound of freedom!
DeeGee is offline   Reply With Quote
Old 02-01-2009, 02:48 AM   #5
Camjamsdad
CF Senior Member
St. Jude Donor '13
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicycle.
I'll add delaminating door panels, bad grounds, frozen head light adjusters, sport seat bladders and fittings, horn switch. That's enough for me.
Camjamsdad is offline   Reply With Quote
Old 02-01-2009, 03:06 AM   #6
JMc
CF Senior Member
JMc's Avatar
Location: "This is not a psychotic episode, but a cleansing moment of clarity."
Don't forget the hazard switch fault that messes up the turn signals...
I've also had
1. rocking seat
2. hand brake replacement
3. Headlamp gear
4. Fuel senders
5. Cracked spokes in rims
6. Dim HVAC lamps
7. Vert window glass starting to separate (fixed myself, quickly and easily with Rhino glue)
All of the above, with the exception of #7, was covered under warranty.
My window seals leak a little in rain, but it barely ever rains here, so I've dragged my feet in doing anything about it.
My lastest problem is that my steering column sounds like a donkey braying when turning it slowly (like in a parking lot, for instance). No idea what needs lubing or how to get to it.
JMc is offline   Reply With Quote
Old 02-01-2009, 03:15 AM   #7
DeeGee
DeeGee's Avatar
Quote:
There's a fix for that
Try this link:
http://www.corvetteforum.com/techtip...D=35&TopicID=1
Old 02-01-2009, 09:09 AM   #8
2CRUZIN
CF Senior Member
2CRUZIN's Avatar
Geez, I must be one lucky guy. I honestly have had no issues on my 1998. 44,000 miles and so far, bulletproof.
That sound you hear is me knocking on wood.
2CRUZIN is offline   Reply With Quote
Old 02-01-2009, 09:09 AM   #9
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Only problems I had with my two C5s were the column lock, fuel guage, leaking differential and oil consumption. Each was fixed under warranty.
Vetteman Jack is offline   Reply With Quote
Old 02-01-2009, 09:55 AM   #10
Black04Z06
CF Senior Member
I'm a little worried now. I have the interior door panel de-laminating issue that I've been meaning to have serviced. My car still has a warranty but now I'm not sure if it will be covered.
Black04Z06 is offline   Reply With Quote
Old 02-01-2009, 10:37 AM   #11
JDaniel
Senior Badass!
St. Jude Donor '08-'09
Support Corvetteforum!
JDaniel's Avatar
I have a '99 FRC and it has a few very minor problems. Fuel sensor intermittenly goes to 3/4 on fill up instead of full, rocking seat JUST started, and my heating and A/C only comes out of my defrost and cant figure that one out. I also had a output seal leaking that was improperly diagnosed by Cartek as a tranny leak WHILE they were doing my output shafts and gears and didnt fix it so I did it mself.
JDaniel is offline   Reply With Quote
Old 02-01-2009, 10:43 AM   #12
ecoman
CF Senior Member
ecoman's Avatar
Had the back window fall out of my vert 1 week after purchase ( used) dealer paid under warranty and col.lock twice also under warranty.
ecoman is offline   Reply With Quote
Old 02-01-2009, 11:37 AM   #13
Old Rotor Head
CF Senior Member
Old Rotor Head's Avatar
Send a message via AIM to Old Rotor Head
The only one I've had not listed is broken valve springs (4). GM TOLD ME "OH THAT'S COMMON WITH THESE"
125k DD, not a racer
Old Rotor Head is offline   Reply With Quote
Old 02-01-2009, 09:35 PM   #14
cushingfamily
Junior Member
cushingfamily's Avatar
Default Convertible Trunk Lid
I saw your list of common C-5 problems and noticed that you had the convertible trunk lid listed. I am experiencing that problem right now. The trunk on my 99 will not pop up far enough to even get a finger underneath the edge. I have to pop the release and then close the door to push it up with the air from the door closing. Can you tell me how you fixed yours?
cushingfamily is offline   Reply With Quote
Old 02-01-2009, 10:18 PM   #15
motogib1
CF Senior Member
The rear hatch of my 02 coupe has bubbled very slightly about the corvette symbol. You can see this in bright sunlight. This is another common C5 issue. I just ignore it, doesn't really bother me at this point. Love the car, can't wait for spring to break it out.
motogib1 is offline   Reply With Quote
Old 02-01-2009, 10:42 PM   #16
tr911
CF Senior Member
tr911's Avatar
A Couple more.
Auto Climate control Actuator problem.
Outside Temperature sensor replacement.
tr911 is offline   Reply With Quote
Old 02-01-2009, 10:49 PM   #17
rebelheart
CF Senior Member
rebelheart's Avatar
Every single car and all brands of cars have problems/tech bulletins and recalls! Corvette is no different from any of them.You can bet if it is mechanical it will have a problem sooner or later!
rebelheart is offline   Reply With Quote
Old 02-02-2009, 10:25 AM   #18
2003 electronblue
CF Senior Member
2003 electronblue's Avatar
Default yes u did
6) Loose axel nut
7) Column lock
the big one for me was the differencial seals and gaskets, turns out most c5's left the factory with this problem..along with the pistonslap..gm just never cared. this is why the c6 vettes are not selling..alot of former c5 owners are not rebuying the vette..
GM is just not run right. here's a question how many of u c5 owners come time to buy another sports car will stick with a corvette?
2003 electronblue is offline   Reply With Quote
Old 02-02-2009, 10:37 AM   #19
ksvette74
CF Senior Member
I will, but it will be awhile.
ksvette74 is offline   Reply With Quote
Old 02-02-2009, 11:02 AM   #20
Bad97ta
CF Senior Member
Bad97ta's Avatar
removable top surface delam, bad leather seats, lumbar doesnt work. but i can deal with those. still a well built car
__________________
Vararam, Yanks SS3600, 3.42s, B & B catback 12.4 1/4 @ 109 mph
Bad97ta is offline   Reply With Quote
Reload this Page All the common C5 problems that GM didn't fix
Tags
c5, climate, common, comon, control, cool, corvette, door, drivers, fixing, gage, inoperative, lock, lumbar, pressere, problem, problems, window
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
