Originally Posted by kwkenuf
(Post 1561380014)
I got my complete frame from Billy Dawson, Corvette Corrections.. I don't belive he makes repair sections for stock frames but I could be wrong.
58n65 |
Engine drop
A little more progress, I dropped the LS1 between the frame rails for the first time. No bling, just a 40,000 mile engine and trans from a 2002 Camaro. Went real well, no problems.
http://i43.photobucket.com/albums/e3...l003Medium.jpg http://i43.photobucket.com/albums/e3...l004Medium.jpg http://i43.photobucket.com/albums/e3...l005Medium.jpg http://i43.photobucket.com/albums/e3...l007Medium.jpg http://i43.photobucket.com/albums/e3...l008Medium.jpg |
I see you had to remove the a/c compressor and the alt to install the motor. What accessory brackets are you going to use to mount them? The t'stat housing looks a little close as well. What rear end are you using, what gears? Making progress! Have fun! :thumbs:
Nick |
The alternator will most likely go back in it's original location. I only removed it for cleaning, not due to a clearance issue. (edit: I was wrong here, see future posts) I was told that the A/C compressor would not fit in it's stock location so I removed it just so I would have no issues when I swung the engine. (I was working by myself). I haven't tried to fit it up yet but it looks like there will be interference. Others are using the S&P drive to relocate the compressor but there is also a kit made by Alf in Sand City Ca. (no web page) that places a Sanden compressor up high on the passenger side and keeps the rest of the accy. drive stock. I haven't contacted him yet to get the parts but I understand that it is a lot less $$ than the S&P drive. Oh, and for the t-stat I'll be using a straight housing from S&P. I'll post more pics when I get all that finalized. The rear end is a Dana 36 (dainty 36?) with 3.73 gears.
Been down for a while, sick like never before... shingles..... wouldn't wish it on anyone... It's been 3 weeks and I'm still not right..... :ack:
Got lots of parts in the meantime though. Hopefully this weekend I'll be installing an LS7 clutch kit, laying out the engine harness, installing the A/C compressor, alternator and accessory drive, modifying the fender wells for suspension clearance and other wise preparing the body for it's first time being placed on the frame. If my plan holds, I'll have some updated pics to post by the end of the weekend. :D |
Get Well Soon
Andy, Glad your better. I had the shingles at age 17 and it was no fun at all. Bad news is you can have them more than once. My mother-in-law is with us now, age 87 and she is in her third week with the shingles. Talked to my doctor and plan to get the shot next week.
Anyways your car is out of this world and I know you can't wait to get back on it. Keep this pics comming.:thumbs: :cheers: Earl |
Sorry man shingles suck. That is of course a medical term. Hope you feel better soon.
Progress looks good. Scott |
Get better soon as I'm enjoying your progress... It's like watching ABC's LOST only to find the next episode is two months away...
Take care and keep posting... |
:banghead: :banghead: :banghead:
Well.... I got the clutch changed out, that went great. Installed an LS2 flywheel and LS7 pressure plate and disc in addition to new hydraulics and a remote bleeder kit... http://i43.photobucket.com/albums/e3...s003Medium.jpg Swung the engine and trans back in and started to work on the accessory drive, relocating the A/C pump to the passenger top side of the engine. http://i43.photobucket.com/albums/e3...s005Medium.jpg After congratulating myself on what a fine job I did selecting the relocation kit, I started to mount up the alternator in it's stock location.... I thought somehow I had this all figured out and it would fit there (low on the drivers side). After removing the rack and pinion to get enough clearance to slide the alternator and idler pulley in there I was getting concerned because while the alternator did fit, the rag I had placed in between the frame and the alternator to protect the powder coat would not slide out, it was that tight... After looking at it for a while and figuring out how I was going to clearance the frame to give the alternator a little more room I realized that I had completely blocked access to the rack and there was no way the alternator was going to reside there. Glad I started paying attention before I got out the BFH and made some room for the alternator..... http://i43.photobucket.com/albums/e3...s006Medium.jpg Now I 'm hoping I didn't blow my money on the A/C relocation kit and I can get something to work for the alternator... 1 step forward, 2 steps back... ahh well.... On a positive note, I got my drive shaft and there was no drama with that..... While I figure out the accessory drive and wait for the parts, I'll get back to work readying the body to drop on the frame for it's first fit check. |
With considerable help from Nick D, I think we have the accessory drive figured out. I'll be using the stock LS1 Corvette power steering/alternator bracket and idler on the drivers side spaced out to accommodate the rest of the drive which is set up for Camaro drive spacing. Just got the parts ordered today from GM so it'll probably be next week before I can move forward on that.
I was going to cut my inner fender wells for suspension clearance yesterday but I don't have my core support installed yet and to use the cut template I got from Billy Dawson, it needs to be installed. Net result of this weekend..... nuttin' much..... :toetap: I'm gunna' have to start working on it more weeknights if I intend to finish before May 30... (50th birthday) |
Question!
Andy, I assume the engine came from a salvage yard. What would one have to pay for a similar engine? Sure looks sweet between those frame rails.:thumbs:
Earl |
Originally Posted by bigearl56
(Post 1562217419)
Earl |
Thanks!
Good data and thanks! My current project is going back original, but I hope I can do a C1 resto-rod next.
I also live in a neighborhood that restricts such things. Thank goodness I have a friend who let me do the dirty work at his shop. Just got it back from the paint shop and doing the assembly in my garage here at the house. As you have seen on TV we are having a late heat wave here in Va, 91 yesterday and the same thru Wed. Plan to get back on it as soon as it cools down. Thanks Again and keep those pics and good info coming. :cheers: Earl |
Andy, it is looking great, the guy who did my 65 Coupe is doing a 61 now as well. Have you visited his thread http://forums.corvetteforum.com/show....php?t=1781661
My 65 is covered under http://forums.corvetteforum.com/show....php?t=1590723 . Your running into things that he is as well on both builds. I'll keep watching both while I finish mine up. Keep up the good work. Tim |
Slowly.....
Got my exhaust manifolds back after ceramic coating. They are one year only 98 F-Body manifolds which are steel rather than cast iron. I think they look good and they are supposed to flow OK.
http://i43.photobucket.com/albums/e3...derwellm-4.jpg http://i43.photobucket.com/albums/e3...derwellm-3.jpg I also marked and cut the inner fender wells for suspension clearance. Before: http://i43.photobucket.com/albums/e3...derwellm-2.jpg And after: http://i43.photobucket.com/albums/e3...derwellm-1.jpg And mocked up the core support to drill holes in the left fender well for the core support and left extension: http://i43.photobucket.com/albums/e3...erwellmods.jpg Initial body drop this weekend? After that I've got lots of glass work to do on the firewall. I want to remove that ridge where the lower tub mates to the upper section and close and smooth out all unnecessary holes. I'll be using a Vintage Air system and Raingear wipers so the firewall should be fairly clutter free when complete..... I hate bodywork...... :ack: If you think the project has been going slow to this point, wait till you see the excuses I come up with to put off glassing, sanding and priming..... |
What a great Yarn..
Keep it coming i'm watching with interest over here in OZ.I spent two years restoring the front end of my brothers torana (Aussie Muscle car) and it bloody near killed me, but in the end it's well worth it.Keep the pictures coming,Aussiesnagz
:cool: Keep Cruizin:cool: |
Initial body drop
Put the body in place for the first time on the new frame last weekend. Just needed to cut the shifter opening for the T-56 on the way down. I haven't played with the shims yet but it's considerably different than my stock frame. On my stocker, to align the rear edge door gaps I needed a stack of shims on the rear mount locations to bring the gaps close. The way it sits now, the doors are touching the body at the rear without any shims on the rear mounts. So If I have this figured correctly, I'll have to raise the middle mounts up so the rear can go down... Someone chime in here if I've got the sequence wrong... Hopefully I'll start on that tomorrow.
http://i43.photobucket.com/albums/e3...7002Medium.jpg http://i43.photobucket.com/albums/e3...7001Medium.jpg http://i43.photobucket.com/albums/e3...7003Medium.jpg http://i43.photobucket.com/albums/e3...7004Medium.jpg After getting my doors and panels aligned, I'll start mocking up as many components as I have including chrome so I can plan the rest of the bodywork. I've got some glassing to do in the spare tire well, around the shifter hole and the center console. I also intend to reinforce the back side of the firewall so I can smooth the engine side the next time the body is off. Still waiting for my ps pump and alternator bracket to arrive but no worries there, I have plenty of work to do in the mean time. |
Looks great! Keep em coming. :cool:
Also, curious question. YOu ra into some pulley issues with the pump and rack. Do you think the new March System (pricey I'm sure) would clear with your chassis? It look like the pump may just be high enought o tuck the nose of the rack underneath but may be hard to tell. http://www.marchperformance.com/products/ls1_480px.jpg |
Originally Posted by 78Vette-SA
(Post 1562486564)
1 Attachment(s)
Thanks for the posts Andy. Looks really good. Have you decided where to put the PCM? I had mine mounted pass side engine compartment under right fender, but now I decided to put AC on and want to relocate PCM. I also have the Alf Bracket. I used the corvette front end accesories and everything else fits fine.
