2008 - Tremec TR-6060 Manual transmission
Well, a few people have mentioned this. The 2008 C6 will use the
Tremec TR-6060 M6 transmission rather than the T56. here's the Tremec light-duty manual transmission line up; * Light-duty transmissions ** Tremec T-5 transmission ** Tremec T-45 transmission ** Tremec TK0 transmission ** Tremec TR-3550 transmission ** Tremec T-56 transmission ** Tremec TR-3450 transmission ** Tremec TR-3650 transmission ** Tremec TR-4050 transmission ** Tremec TR-6060 transmission You might want to download this before it gets pulled off the web. http://www.conacyt.mx/Estimulosfisca...S3A-2005-3.pdf I see a 650 lbs*ft torque rating. ======================================== ===== Then there is the LS3: OK, let's look at the two different 3V head designs that use a single internal camshaft. I am reasonably sure that the LS3 will use a variation of what is shown in patent 6505589 but I wonder what the valvetrain will look like. From Figs. 1 and 2 in 6505589, you can see that the head is designed for direct injection from the top of the combustion chamber. Patent 6505591 details an intricate way to simultaneously actuate the exhaust valves while maintaining space for the DI at the top of the combustion chamber. Patent 6668546, Fig. 5, shows the combustion chamber of both the single and dual internal camshaft designs from a ways back. http://www.freepatentsonline.com/6505589.pdf (DI port is #68 in drawings) http://www.freepatentsonline.com/6505591.pdf http://www.freepatentsonline.com/6668546.pdf (Look at Figure 5) Here's the new valvetrain. As you can see, there is no longer any place to put the central injection DI injectors. http://www.freepatentsonline.com/6962134.pdf This could mean many things. First, that no 3V head will get central injection. It could also mean that there will be a DI version and a non DI version of the heads. Lastly, GM could have decided to abandon low pressure, air assisted DI for high pressure side injection. Someone needs to spill the beans here ... |
:thumbs:
Dude ... you are one great detective ...
Thanks for the research and a great post!!!! :thumbs:
Great info. Much thanks.:thumbs:
ye ha
makes me glad that I have my sights set on an '08. Better manual trans by far in all respects by the look of it . Who knows on the engine I understand it's already in some GM suvs like Tahoe so the C6 won't be the first. Now if they could just come up with a better clutch to pair up with this MUCH better transmission. So the GT 500 has this trans NOW? Let's see, that means the GT 500 has a better trans than the C6 I believe. thanks for the info I am getting excited-the C6 is maturing ps...if this proves to be true imagine the push that will be on next year to move out the 07s with manual transmissions. The difference might be greater than that of the 4 speed auto vs the 6 speed auto. Who would want a C6 with a T56 in the 07 with the 08 just around the corner? |
Well, as long as this thread is talking about 2008, let's
think about something besides the LS3 and TR-6060. The aluminum frame will have been in production for two years by the time the 2008's roll out. Spreading the aluminum frame across the line-up would be simple and low risk. If there is a slight stiffness shortfall, they could add back the 10kg needed to match the stiffness of the steel frame. Otherwise they could insert internal stiffeners into the frame. http://www.freepatentsonline.com/20050279049.pdf Doing this, though, would really take the exclusivity from the Z06. However, it is not clear what the fate of the "Z06" is in 2008. The Z06 introduced the magnesium front crossmember to the C6. Minimally, it would be easy to move this across the line-up. Also, they could easily switch the rear crossmember to magnesium. The front license plate attachment could certainly use a bit of re-engineering. Mileage. The base car will be moving from a 6.0L to a 6.2L engine and from a 2V to 3V valvetrain. That can't help mileage any. There are two obvious cures for this disease. Decrease vehicle mass and/or increase engine thermal efficiency. I would translate that into aluminum frame and/or direct injection. OK, what about this new blue? The old "Mulsanne Blue" looks like Nassau Blue to me. Here are some of the older blue colors. There are more but I've lost my motivation here! http://images.google.com/images?q=co...=Search+Images http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search http://images.google.com/images?svnu...22&btnG=Search |
Originally Posted by OregonC6
ye ha
makes me glad that I have my sights set on an '08. Better manual trans by far in all respects by the look of it . Who knows on the engine I understand it's already in some GM suvs like Tahoe so the C6 won't be the first. Now if they could just come up with a better clutch to pair up with this MUCH better transmission. So the GT 500 has this trans NOW? Let's see, that means the GT 500 has a better trans than the C6 I believe. thanks for the info I am getting excited-the C6 is maturing ps...if this proves to be true imagine the push that will be on next year to move out the 07s with manual transmissions. The difference might be greater than that of the 4 speed auto vs the 6 speed auto. Who would want a C6 with a T56 in the 07 with the 08 just around the corner? So many 05-07 owners on here that love their rides, have had no problems and with awesome performance. Yet you manage to put that down and compare it to a rumour about a new model year. Whatever... |
think about something besides the LS3 and TR-6060. The aluminum frame will have been in production for two years by the time the 2008's roll out. Spreading the aluminum frame across the line-up would be simple and low risk. If there is a slight stiffness shortfall, they could add back the 10kg needed to match the stiffness of the steel frame. Otherwise they could insert internal stiffeners into the frame. http://www.freepatentsonline.com/20050279049.pdf Doing this, though, would really take the exclusivity from the Z06. However, it is not clear what the fate of the "Z06" is in |
I posted this months ago! In the Vette forum and in the Camaro forum.
But only 2 or 3 people would believe me? There will be a new red and a new blue coming out also! I've driven the GT 500 with the T-6060 and it's light years ahead of the T-56. Tim http://forums.corvetteforum.com/show....php?t=1487266 http://forums.corvetteforum.com/show...1510395&page=2 |
I stated in my first sentence that the TR-6060 comments have
been said before. What I offered that is new is some confirmation by one of the principals; Tremec. There are countless unsubstatiated comments made on this forum. Confirmation by a principal is the only way that the general audience has to know what's real and what isn't. As to the LS3, I've read virtually every number from 410 hp through 450 hp, by increments of 5 hp - and then some. How are we supposed to know if your 430-440hp is right? There was a recent post that the Saleen folks say the engine has 450hp. Is the LS3 a direct or port injection engine? |
been said before. What I offered that is new is some confirmation by one of the principals; Tremec. There are countless unsubstatiated comments made on this forum. Confirmation by a principal is the only way that the general audience has to know what's real and what isn't. As to the LS3, I've read virtually every number from 410 hp through 450 hp, by increments of 5 hp - and then some. How are we supposed to know if your 430-440hp is right? There was a recent post that the Saleen folks say the engine has 450hp. Is the LS3 a direct or port injection engine? :cheers: So Runge, how firm is the likelyhood of a 3V head on the LS3? I don't think we're going to see direct injection just yet. |
Great info as usual.
Hey, study the technical specs and compare the transmissions yourself
Originally Posted by C5~Missle
What a stupid post. Whats wrong with the current T56? It's rated and handles the current power and more with no problems? Why is the new one "much better". Please enlighten us with your technical knowledge on this. Most complaints are about the shifter, not the tansmission.
So many 05-07 owners on here that love their rides, have had no problems and with awesome performance. Yet you manage to put that down and compare it to a rumour about a new model year. Whatever... I hope that if this new trans goes into the 08 GM decides to upgrade the clutch. Hey, I love the C6. I don't love the feel of the clutch though and others have reported serious problems. Yes, the shifter could be improved too. I still love the C6. My 05 runs just fine too. The main reason I did not and will not buy an 07 is that I want the roof problem to be fixed and PROVEN to be fixed-not just said to be fixed. Now I find out the major upgrades of trans and engine may be in the works for 08 and I am happy. Read the technical specs and compare the transmissions. Decide for yourself if the 6060 is superior to the T56 and by how much or not at all. You are a smart guy so study the details. By the way, there does not have to be anything 'wrong' with the current trans or anything else on the car for it to be improved upon. There is nothing wrong with the steel frame but I'd sure go for the Z06 aluminum frame in the base car and would consider it much better. Same for the brakes. Nothing wrong with the base brakes but Z51 is better right? Nothing wrong with Z51 brakes but Z06 is MUCH better right? Nothing wrong with the T56 but .....now it's your turn to study the specs and decide for yourself. I happen to think it is clearly better and all I know is what I've read and studied. It's self education about something I knew nothing about before. I tend to do that a lot. Like, hey, I don't know much about this so I'll research it and form an educated opinion. Just like that. what the heck seems a simple approach to me so now you do the same.... all IMO, if your opinions differ that is just fine. You may be right I may be wrong. If I am wrong I will do penance and repent mightily. I promise. |
engine and from a 2V to 3V valvetrain. That can't help mileage any. There are two obvious cures for this disease. Decrease vehicle mass and/or increase engine thermal efficiency. I would translate that into aluminum frame and/or direct injection. The LS3 is supposed to have VVT for emissions and AFM/DOD for gas mileage just like the new Camaro. I still think the 2V L92 heads will be used instead of those 3V heads which could show up on the C7 in 2012. The L92 heads are pretty cheap and are being used in the GM trucks such as the VortechMax 6.0L (L76) and in the Denali line and the Escalades, so GM is already making alot of these new rectangular port heads (L92) based off the LS7 heads. Also GM has a L76/L92 car intake that is supposed to be released from GM Performance Parts any time now, already available in Australia, for the L92 heads which means GM plans to put the heads into cars in the future. ;) So why would GM introduce a more expensive, more parts to break, and unproven 3V head in a mid-cycle Corvette? :nono: I think Direct Injection won't be available either until the C7. The ZO6 will still be around with a LS7 with (maybe) a slight bump in hp for '08. |
Will new/better mean better performance as in lower ET's or just a higher HP/TQ capacity????
Tom |
Thanks, guys, for the interesting research and comments. I love my OLD 2006 C6, but I always look forward to the refinements that come with new model years. It's part of the fun.
Jeep |
Improving the Breed . . .
So, who here would turn down a 1967 427 Corvette in showroom condition, if it happened to appear under your (Late December Holiday Season Celebration) tree ? ? ? :D
