Hp and torque ratings of Mk IV Ls6 crate?
I wondered if anyone had the specs for the above crate engine which had a compression ratio of 10.2:1 which was in between the 1970 Chevelle LS6's 11:1 and the 1971 Corvette LS6's 9:1.
I found this on the web: "I'm looking at a 6th edition 1988 Chevolet Power Book right now with the following listed: 366250 Engine Asm, 454 CID (Typical of 1970 Corvette) Less Exh manifolds, distr & clutch. Open chamber CI heads with Closed chamber design piston. 10.2:1 CR, LS-6" but there were no HP and torque ratings listed. RDave |
The Specs were the same as the 1970 LS6 Chevelle..
A friend emailed me this:
Engine part # 366250 Stamped XAA above timing chain cover Displacement 454 HP 450@ 5600rpms CR 10.2:1 Bore and stroke 4.25 x 4.00 cam shaft solid lifter flat tappet 3904362 advertized lift intake/exhaust 0.500"/o.500" I am asuming the torque was the same as the Chevelle LS6 also. RDave |
I saw some dyno tests on them in Hot Rod a long time ago...they made beween 425-440 or so on engine dyno. The later versions of them actually went to a hyd flat tappet copy of the LS-6 cam with non adjustable valvetrain. In the dyno tests they were essentially a dead heat between the two cams. But they were only revving to 5200-5500 rpm or so.
JIM |
JIM I saw an old Hot Rod test where they dyno'ed a Mark IV LS6 Crate engine and got 437 HP. I was still curious at what GM rated the torque for this engine at, with the 1970 Chevelle LS6 coming in at 500ft lbs with an 11.25:1 compression ratio and the 1971 Corvette LS6 coming in at 475 ft lbs with a 9:1 compression ratio. RDave |
