Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-09-2006, 05:22 AM   #1
RDave
Junior Member
Default Hp and torque ratings of Mk IV Ls6 crate?
I wondered if anyone had the specs for the above crate engine which had a compression ratio of 10.2:1 which was in between the 1970 Chevelle LS6's 11:1 and the 1971 Corvette LS6's 9:1.
I found this on the web:
"I'm looking at a 6th edition 1988 Chevolet Power Book right now with the following listed:
366250 Engine Asm, 454 CID (Typical of 1970 Corvette) Less Exh manifolds, distr & clutch. Open chamber CI heads with Closed chamber design piston. 10.2:1 CR, LS-6"
but there were no HP and torque ratings listed.
RDave
RDave is offline   Reply With Quote
Old 10-10-2006, 05:29 AM   #2
RDave
Junior Member
Default The Specs were the same as the 1970 LS6 Chevelle..
A friend emailed me this:
Engine part # 366250
Stamped XAA above timing chain cover
Displacement 454
HP 450@ 5600rpms
CR 10.2:1
Bore and stroke 4.25 x 4.00
cam shaft solid lifter flat tappet 3904362 advertized lift intake/exhaust
0.500"/o.500"
I am asuming the torque was the same as the Chevelle LS6 also.
RDave
Old 10-10-2006, 07:46 AM   #3
427Hotrod
CF Senior Member
427Hotrod's Avatar
I saw some dyno tests on them in Hot Rod a long time ago...they made beween 425-440 or so on engine dyno. The later versions of them actually went to a hyd flat tappet copy of the LS-6 cam with non adjustable valvetrain. In the dyno tests they were essentially a dead heat between the two cams. But they were only revving to 5200-5500 rpm or so.
JIM
427Hotrod is offline   Reply With Quote
Old 10-10-2006, 09:30 AM   #4
RDave
Junior Member
Quote:
JIM
Hi Jim,
I saw an old Hot Rod test where they dyno'ed a Mark IV LS6 Crate engine and got 437 HP.
I was still curious at what GM rated the torque for this engine at, with the 1970 Chevelle LS6 coming in at 500ft lbs with an 11.25:1 compression ratio and the 1971 Corvette LS6 coming in at 475 ft lbs with a 9:1 compression ratio.
RDave
Reload this Page Hp and torque ratings of Mk IV Ls6 crate?
Tags
1971, 366250, 454, chevy, corvette, crate, dyno, engine, horsepower, hp, lq4, ls6, ratings, specs, toque, xaa
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
