Securing car in an enclosed trailer?
I used my enclosed trailer for the first time on a trip to South Carolina. On my open trailer I used over-the-wheel straps and never had a problem. On the trip to SC I used 2 over-the-wheel straps in the front and 2 T-hook connections in the rear using the factory slots - both front and rear were crossed. The hand brake was not engaged and the car was in neutral. With this configuration the car would loosen up the straps very quickly and move around. Also the left rear hook connector punched a hole in the trailer floor. So how are you guys securing your C5s in an enclosed trailer? I'd appreciate first hand experience here, no theories.
t-hooks placed in the jacking puck holes. and 5000lbs straps
http://www.northerntool.com/images/p...3309048_lg.gif from Northerntool or any tow truck supply place then cross the straps in an X pattern X X Right front hole to left front tie down point left front hole to right front tie down point Straps over the wheels can still allow the car to roll. You do not want your car in gear on a trailer as your car will rock slightly Straps on the A-arms WILL eventully bend the A-arm. Some ppl allow their car to use its suppension by strapping down to the wheels. IMHO, I dont like that feeling. I have my car very secure to the deck so it will not go anywhere http://img.photobucket.com/albums/v1...rontstraps.jpg http://img.photobucket.com/albums/v1...rearstraps.jpg |
A variation of the "over the tire" way to tie down is this. Use 24" axle straps and place them through the wheel. Crisscross the tie down staps and attached them to axle staps. I marked my wheels with tape to see if there was any shifting...none was found. The car still rides on its own suspension and pulling the trailer is much smoother. I have been using this method for over three years and 35000 miles in an enclosed trailer. Of course, I never drive over 80.
T-hooks are a great way to go. SOme people strap the a-arms without problems.
VR :cheers: |
Well, cannot help with the mounting point on the trailer, that obviously must be beefy enough. I used a rental 8' x 20' dual axle trailer to haul down my 'vette to Lingenfelter and back with a strap looped throught each wheel back to the connection points-no "X". Tightened them to snug and then put the car in gear with the parking brake on. Worked great for me.
