Originally Posted by RandolphB
(Post 1578731283)
I haven't tried changing the fluid in the transmission yet. Was told it was done in December at dealer before we got the car.....but think it best to do myself to be sure....
Originally Posted by Toque
(Post 1578602470)
Guys:
This modification will reduce the "notch" feeling when shifting between gears. And allows for a more easy shift. Its a MUST do for when you install a Short Shifter. Easy to install and remove if you don't like it. On my web site at the bottom: http://ToqueZ06.com/ Anti-Venom 6 Speed Shifter Modification: Toque |
Originally Posted by glfrmrk
(Post 1591110862)
Does the trans need to be in a specific gear during the mod? I am using ramps to raise the rear of the car. Thanks, Mark.
(Post 1591110862)
I never had anyone ask me though. Its a good question ! :D:thumbs: It should work in or out of gear I would think. But as he said above... Neutral would likely be best. Good luck ! Toque |
(Post 1591113717)
I don't think it matters.... I think mine was in neutral. I'm not sure though.
Originally Posted by bjones7131
(Post 1591113998)
I am told this will make no difference on stock shifter, i know i tried it on my stock shifter and saw no differance, go figure.
Toque |
How exactly does it work?
And will it work similarly on a C6? with a MGW?
Just did this mod today while installing my Corsa Xtreme. IT IS AWESOME. It made my MGW so much easier to manuever. Sure, not quite as notchy, but feels infinitely better. Just used one washer and don't plan on changing that.
Hey Mark! I'm back! FULLY back Monday when I pick up my new '02 coupe!
As for the this thread, the anti venom reduces the pressure of the spring that holds the linkage in place in a particular gear. My moving the ball further 'out' it exerts less pressure. I did it on my Z, with the stock shifter and it works great. I think I used 1 spacer. I also took 1 3/4 out of my shift handle, making it a shorter shifter. I was very happy with the results. |
anyone have the specs on the washer? thickness, and OD and ID?
thanks |
https://www.corvetteforum.com/forums...od-washer.html
20 mm copper drain plug washer ( on another thread >>>>3/4" ID brass washer approx 1/16" thick ) I went to the big rig truck center and bought what I needed. |
Originally Posted by Georgies
(Post 1594653105)
thanks Gasket Thickness (mm): 1.25 mm Inside Diameter (in): 0.807 In. Outside Diameter (In): 1.071 In. |
Wow, this seems like a cool/easy/cheap mod to do. I have the MGW short shifter and like how it has the shorter throw, but just a bit to "notchy" for me.
I plan on doing this soon and I'll check back with the results. On a side note....by doing this mod, will it hurt anything in the transmission or clutch related? |
Originally Posted by tnmotown
(Post 1595620016)
I plan on doing this soon and I'll check back with the results. On a side note....by doing this mod, will it hurt anything in the transmission or clutch related? Only potential downside is a slightly higher possibly of the transmission popping out of gear... I have had this done for 2 years and have not come out of gear one single time. |
(Post 1595620016)
I plan on doing this soon and I'll check back with the results. On a side note....by doing this mod, will it hurt anything in the transmission or clutch related? I have found through trial and error, that a heavier shift knob makes it that much smoother ! do not use the white hurst ball junk, it's just that, and rattles .... enjoy! |
The link takes me to photos of 3 cars?
To those who have done this mod - is there any reason Not to use a 20mm aluminum crush washer instead of brass? I already have a ton of those laying around. Thanks.
Originally Posted by Matthewstorm
(Post 1595849915)
then scroll down to AntiVenom mod Toque |
(Post 1595853559)
click on my corvette picture
then scroll down to AntiVenom modToque |
Originally Posted by chasboy
(Post 1595854901)
Hey Mark, how you doing!!!???
