Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-04-2011, 02:27 AM   #1
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Default Anti-Venom 6 Speed Shifter Modification (Procedure)
Guys:
This modification will reduce the "notch" feeling when shifting between gears.
And allows for a more easy shift.
Its a MUST do for when you install a Short Shifter.
Easy to install and remove if you don't like it.
On my web site at the bottom:
http://ToqueZ06.com/
Anti-Venom 6 Speed Shifter Modification:
Toque
Toque is offline   Reply With Quote
Old 09-04-2011, 02:40 AM   #2
TriplBlk
CF Senior Member
TriplBlk's Avatar
Nice
TriplBlk is offline   Reply With Quote
Old 09-04-2011, 08:49 AM   #3
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Thanks for posting this up. Should help the manual transmission owners.
Vetteman Jack is offline   Reply With Quote
Old 09-04-2011, 09:18 AM   #4
C5Longhorn
CF Senior Member
C5Longhorn's Avatar
Send a message via AIM to C5Longhorn
Thanks Toque. This is a mod I haven't done yet even though I've had an aftermarket shifter for over 10 years.
I'll have to check out your website.
Rick
C5Longhorn is offline   Reply With Quote
Old 09-04-2011, 09:34 AM   #5
tbrent
CF Senior Member
tbrent's Avatar
tswoleup
nice
tbrent is offline   Reply With Quote
Old 09-04-2011, 12:54 PM   #6
Toque
Toque's Avatar
Thanks guys !
Its a real old mod talked about on here years ago.
I thought I would bring it back to life...
I have been reading the C5 section since 2000 (lurker)... signed up once I got my Z in 2004
Toque
Old 09-04-2011, 01:39 PM   #7
mariofromnewyork
*Let's GO Buffalo*
Support Corvetteforum!
mariofromnewyork's Avatar
Well Done!\\
__________________
Mario
mariofromnewyork is offline   Reply With Quote
Old 09-04-2011, 07:02 PM   #8
FYRARMS
CF Senior Member
FYRARMS's Avatar
Toque, my B&M Ripper shifts notchier than s%$@, especially 1st and Reverse. The RSD shifter I installed is almost TOO easy to shift. I am looking for something in between. You think the washer mod would help my old B&M? I plan on changing the trans fluid with Amsoil anyway, so the car will be on the lift.
__________________
'03 Z06: AFR, Comp Cams, FAST, Halltech, MSD, LG, Borla, RPS, B&M
Cars, guns, and watches... I reeeeally need to find cheaper hobbies.
FYRARMS is offline   Reply With Quote
Old 09-04-2011, 07:10 PM   #9
98DC231
CF Senior Member
Did this today on my car which had a Ripper installed by the previous owner. Was too notchy and thanks to Toque I found this procedure to be extremely easy and made all the difference in the world.
Car is more enjoyable to drive now, I can find the right gear without having to really muscle the shifter. Also going 1 to R or R to 1 is easy now.
98DC231 is offline   Reply With Quote
Old 09-04-2011, 07:23 PM   #10
FYRARMS
CF Senior Member
FYRARMS's Avatar
That's all I needed to hear! Ripper going back in! LOL
Old 09-04-2011, 11:10 PM   #11
c5sean85
CF Senior Member
c5sean85's Avatar
Quote:
Originally Posted by Toque View Post
Guys:
Toque
can you explain what you mean by notch feeling? does it make it quicker to get in gear? also how much oil will come out..
thanks
sean
c5sean85 is offline   Reply With Quote
Old 09-04-2011, 11:46 PM   #12
Qwik01
CF Senior Member
Qwik01's Avatar
Thanks Toque! I will give this a try!
Qwik01 is offline   Reply With Quote
Old 09-04-2011, 11:51 PM   #13
Toque
Toque's Avatar
Quote:
I went for a 1.5 hour cruise tonight after doing the anti-venom mod. I had my tranny rebuild done a month ago and I had it removed for the rebuild. Without the shim in there my shifter went back to feeling stiff and notchy. The Anti venom mod really loosened things up. Much easier to get into gear. More precise I find. I have tried 2 shims in the past and it felt too loose. One shim is perfect I find. Everyone is different of course. I would try one first, and two next (if you find one not enough). Its super easy to do.
Post back up what you think once you do it !
Toque
Old 09-04-2011, 11:55 PM   #14
Toque
Toque's Avatar
Glad to hear that !
Quote:
Your welcome !
Quote:
thanks
sean
With the after market short throw shifters having a shorter throw, it makes things a little more stiff shifting. The axis point in the shifter is higher than stock thus requiring more effort from the driver to get into the gears. You can really feel the neutral "notch" between the gears. Its kinda hard to explain. This loosens things up a bit for us short shifter guys...
No oil comes out at all. The oil level is well below where this detent plug is located.
Yes its quicker to get into gear too. Quicker throws between the gears for sure.
Cheap and easy !
Toque
Old 09-04-2011, 11:56 PM   #15
TriplBlk
CF Senior Member
TriplBlk's Avatar
Toque
I wonder how is mod compares to a TR6060 hmmm
I'm already wanting a Z06 trans, if it's more aggressive than the M12 Looks like I have saving to do!
Old 09-05-2011, 12:01 AM   #16
Sinister-one
CF Senior Member
Where did you buy the washer ?
Sinister-one is offline   Reply With Quote
Old 09-05-2011, 12:07 AM   #17
Toque
Toque's Avatar
Quote:
Auto Zone, or similar Auto Parts place. Common part if I remember.
Cost was less than $5 for 2x.
Go to Auto Zone and tell them.... ---> "Oil Tight" Copper Washer #65277 M20 3/4" Copper
They will have it.
Toque
Old 09-05-2011, 12:10 AM   #18
Toque
Toque's Avatar
I'm not sure what you mean. This is a mod that you can do to any 6 speed (M6 or M12) to loosen up the shifter feel.
Toque
Old 09-05-2011, 12:16 AM   #19
TriplBlk
CF Senior Member
TriplBlk's Avatar
Toque
Sry for not being clear.
The new C6 transmissions TR6060 have better hydraulics that makes shifting so easy you can literally do it with one finger! Lol
I'll have to tlk to RkT56(Rick) lol
Old 09-06-2011, 08:17 AM   #20
Toque
Toque's Avatar
I was out cruising around again again last night. WOW what an improvement. It feels perfect now !
Toque
Reload this Page Anti-Venom 6 Speed Shifter Modification (Procedure)
Tags
65277, anti, antivenom, c5, copper, corvette, ep3, mod, modification, oil, shifter, speed, tite, venom, washer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
MGW SHIFTER: I know I'm going to be tarred and feathered for this, but... vara411 C6 Corvette General Discussion 21 01-09-2014 12:40 PM
MGW Shifter/Anti-Venom Mod 4 KRUSIN C5 General 42 01-07-2014 12:08 PM
Speed up shifting? Anti-venom mod or something else? K-n C5 Z06 Discussion 13 07-10-2013 06:18 PM
Started researching anti venom Ekul61 C5 General 12 04-05-2013 07:57 AM
MGW shifter installed, wow! janky C5 Z06 Discussion 25 11-07-2012 11:39 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
