Corvette Forum
Go Back   Corvette Forum > Off Topic > F-Body General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2007, 05:30 PM   #1
TomcatMF
Junior Member
Default LS7 in 4th gen Camaro?
Has anybody ever done this? I noticed Katech has an LS7 package for F-body, and I was wondering if anyone had done such a thing to their camaro.
BTW my car is a '97 SS with the LT1 motor.
TomcatMF is offline   Reply With Quote
Old 11-14-2007, 06:51 PM   #2
02MillenniumVette
CF Senior Member
02MillenniumVette's Avatar
Its been done before.
http://forums.corvetteforum.com/show....php?t=1724637
02MillenniumVette is offline   Reply With Quote
Old 11-14-2007, 06:51 PM   #3
Mojave
CF Senior Member
Mojave's Avatar
Swapping an LS7 into an LS1 f-body would be quite simple. You could use the stock wiring harness, trans, mounts, etc, etc. Swapping into an LT1 car would be a lot harder, since the mounts, wiring, trans, etc, are not the same.
For the cost of an LS7, you could build a hell of an LSx motor. LS7's were 14K last I checked, and that will buy a lot of motor.
Mojave is offline   Reply With Quote
Old 11-15-2007, 12:07 PM   #4
02MillenniumVette
CF Senior Member
The Katech LS7 and the GM LS7 are two different engines. I know the thread I posted was a GM LS7. Im pretty sure the Katech engine can be bolted up to the LT1 F-body fairly easy also. This is quoted off of their website and it doesnt specify the LT1 or LS1 F-body.
Quote:
F-body and Y-body applications available.
Old 11-15-2007, 12:27 PM   #5
Mojave
CF Senior Member
Mojave's Avatar
Quote:
The LS1 and LT1 T-56 trans are not interchangeable. While the trans internals are the same (well, almost, 93 was different), the bell housing (specifically the clutch setup) are not the same at all. LT1 uses a pull style pressure plate, where as the LS1 uses a more traditional push style pressure plate. Using an LT1 trans on ANY LSx motor will require changing a lot of parts on the trans, including the input shaft IIRC.
If you are dead set on putting an LSx motor into a LT1 f-body, it is much, much easier to just sell the LT1 trans and get an LS1 trans.
Old 11-15-2007, 03:39 PM   #6
TomcatMF
Junior Member
I'm not dead set on it. I was just curious about it. I think I'll just keep saving my money up for the C6 Z06. The cost of the Katech install is more than my car is worth anyway. Plus I'm not even sure if it would pass smog here in California.
Old 11-15-2007, 06:36 PM   #7
02MillenniumVette
CF Senior Member
Quote:
Thats the best way to go.
Old 11-28-2007, 01:31 AM   #8
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
No it can't. As mentioned the trans is different. Motor mounts are different. You would have hood clearance issues. and a host of other issues.
Jeffvette is offline   Reply With Quote
Old 11-28-2007, 10:28 AM   #9
02MillenniumVette
CF Senior Member
Quote:
I saw Mojave's post.
Old 11-28-2007, 11:53 AM   #10
Mojave
CF Senior Member
Mojave's Avatar
Yeah, you're too slow, Jeff!
Old 12-04-2007, 11:54 AM   #11
Katech_Jason
Premium Supporting Vendor
Katech_Jason's Avatar
Send a message via AIM to Katech_Jason
We did it in 2006.
http://www.ls1tech.com/forums/showthread.php?t=496186
That is incorrect. We simply enhance GM's LS7 engine. The LS7 can be "bolted up" to the LT1 F-body fairly easily, you are correct. However the integration and the things you need to change to get it to work in a LT1 F-body would not make it worthwhile. You are better off starting with an LS1 F0body.
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Performance
__________________________________
http://www.katechperformance.com
YOUTUBE
FACEBOOK
MAILING LIST
Katech_Jason is offline   Reply With Quote
Old 12-04-2007, 04:42 PM   #12
02MillenniumVette
CF Senior Member
Quote:
Originally Posted by Katech View Post
We did it in 2006.
Old 01-25-2008, 08:21 PM   #13
t.renz791
CF Senior Member
Send a message via AIM to t.renz791
That 10 bolt astro van rear end they stuck in 3rd and 4th gen F Bods would not be long for this world with an LS7 under the hood.
t.renz791 is offline   Reply With Quote
Old 02-04-2008, 04:09 PM   #14
use2bl8
CF Senior Member
use2bl8's Avatar
Send a message via MSN to use2bl8
For less than cost of an LS7: I got an 402, LS2 block, 4" crank, forged pistons, AFR 255cc heads, Fast 90, NW 90 TB, 42lb injectors. But down 478rwhp through an built auto trans.
Quote:
Yup, I'm looing for a 12-bolt.
use2bl8 is offline   Reply With Quote
Reload this Page LS7 in 4th gen Camaro?
Tags
4th, body, builds, camaro, corvette, fourth, gen, generation, hoods, ls2, ls7, lt1, motor, swap, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
