C6 ZO6 Race seats
C6 ZO6 Race seats
Hey guys I know I have serached and not really found what I am looking for.. i would really appreciate you guys to post pics and pro and cons of different seats you run in your cars.. I'm 6' 200 36 waist..and tired of sliding around!!!
I installed the Corbeau FX1-Pro seats. PIA to install in the correct spatial orientation (height/angle) but it was well worth it.
http://forums.corvetteforum.com/c5-t...n-sliders.html
You are my twin.
I got a great deal on a set of Caravaggio carbon race seats. They look great and are very supportive and comfortable. However since they don't have a center cushion pass through for the crotch belts NASA made me use the standard 3 point OEM belt and sit on my sharkbar/GForce set up
Good luck
Good luck
At 6'0, 200, 36" you are almost my exact size.
I went with a Sparco Evo2 in my C5 on some custom made mounts to get it as low as possible.
It is a very good fit for me.
66L72, question on your Carravagios...did the 3 point factory seat belt still work alright with the race seats?
In other words, did the right & left lap portions of the lower belt lay flat accross your waist, or did the side of the caravaggios keep them elevated up/off of your waist? I'm 6' 190 lbs & am considering a set, & will most likely just run the stock seat belts.
IMO the carbon race seats are ridiculously overpriced. I got mine in mint condition and my body color for less $2800 with no cores. The comfort, support and workmanship are first rate though. I was quoted $600 to put the crotchbelt pass through hole in the bottom cushion although I image it would be a lot less if he put the holes in during initial construction.
Good luck
