Wheel studs
Old 11-06-2011, 11:23 AM
GS023
GS023's Avatar
Default Wheel studs
Anyone have a good source for extended length wheel studs? Want to stay with the stock C4 metric diameter but need something longer.
Old 11-06-2011, 11:36 AM
Aardwolf
Aardwolf's Avatar
I put up some part numbers of what I'm using, with pix on how they fit in this old thread of mine:
http://forums.corvetteforum.com/c4-t...ion-parts.html
Old 11-06-2011, 12:06 PM
GS023
GS023's Avatar
Thanks, thats what I will get.
Old 11-06-2011, 02:22 PM
CHJ In Virginia
CHJ In Virginia's Avatar
There are several sources for high strength / longer wheel studs. You might try Doug Rippie Motorsports - forum vendor. Also check out ARP - American Racing Products / wheel studs. They are available through a lot of vendors such as Summit Racing.
Old 11-06-2011, 03:28 PM
VanSpeed
VanSpeed's Avatar
You can try your local Chevy or any GM dealers parts counter and get these:
22551491 GM long 12mm wheel stud with rounded end
Brian
Old 11-06-2011, 03:37 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
DRM! Call Randy.
Jim
Old 11-06-2011, 11:43 PM
rasrboy
rasrboy's Avatar
Originally Posted by Painrace
DRM! Call Randy.
Jim
Joe, I ordered mine from Randy at DRM years ago for my C4 racer.
Aaron
Old 11-07-2011, 07:38 AM
davidfarmer
davidfarmer's Avatar
here is the ARP parts list
http://www.davidfarmerstuff.com/apr-wheel-stud.pdf
Old 11-07-2011, 11:25 AM
c4cruiser
c4cruiser's Avatar
I'll be replacing all the studs on my C4 over the winter using the ARP studs. I have been using generic lugnuts as I can get them pretty cheap thru my shop.
But is there any reason to use hardened or higher grade lugnuts? Is there something like a lug nut in metric grade 10.8? I've never had a problem using stock lugnuts for autocross (aftermarket ZR-1 wheels and A6's) and occasional track days.
To Wheel studs
Quick Reply: Wheel studs
